* | c-user: Fix use of lower and higher priority | Sebastian Huber | 2021-09-15 | 1 | -2/+2 |
* | c-user: Clarify task priorities | Sebastian Huber | 2021-09-15 | 3 | -12/+16 |
* | c-user: Define lower and higher priority | Sebastian Huber | 2021-09-15 | 1 | -5/+32 |
* | c-user: Fix message manager documentation | Sebastian Huber | 2021-09-15 | 1 | -9/+10 |
| | | | | | | | Remove bogus return status from rtems_message_queue_receive(). Clarify rtems_message_queue_flush(). Close #4508. | ||||
* | c-user: Clarify rtems_extension_create() | Sebastian Huber | 2021-09-15 | 1 | -3/+7 |
* | c-user: Add "Cache Manager" chapter | Sebastian Huber | 2021-09-13 | 4 | -0/+782 |
| | | | | | | | | | | | | | | | | | | | | | | The Cache Manager directives are available via <rtems.h>. Document most of them in the Classic API Guide. Not documented are the following directive since the API is not yet stable: * rtems_cache_coherent_allocate() * rtems_cache_coherent_free() * rtems_cache_coherent_add_area() Not documented are the following directive since the directives are not implemented on maintained platforms: * rtems_cache_freeze_data() * rtems_cache_freeze_instruction() * rtems_cache_unfreeze_data() * rtems_cache_unfreeze_instruction() Close #4513. | ||||
* | eng: Fix wording in specification items | Sebastian Huber | 2021-09-13 | 1 | -14/+14 |
* | eng: Add hidden interface group membership | Sebastian Huber | 2021-09-10 | 1 | -0/+14 |
| | | | | Update #3715. | ||||
* | eng: Make interface definitions optional | Sebastian Huber | 2021-09-10 | 1 | -36/+45 |
* | eng: Add interface params/return to typedefs | Sebastian Huber | 2021-09-10 | 1 | -0/+11 |
* | eng: Simplify interface return specification | Sebastian Huber | 2021-09-10 | 1 | -8/+13 |
* | c-user: Document time of day constraints | Sebastian Huber | 2021-09-06 | 1 | -4/+15 |
| | | | | Close #4338. | ||||
* | eng: Remove bogus coding rule | Sebastian Huber | 2021-09-02 | 1 | -2/+0 |
| | | | | | Declaring functions used only through function pointers as inline makes absolutely no sense at all. | ||||
* | c-user: Add LIFO to glossary | Sebastian Huber | 2021-09-02 | 1 | -1/+9 |
* | eng: Document use of BSP family for defaults | Sebastian Huber | 2021-08-30 | 2 | -4/+8 |
| | | | | Update #4468. | ||||
* | bsps/raspberrypi: Change firmware version, add SPI & I2C support | pranav | 2021-08-18 | 1 | -6/+45 |
* | c-user: Add "Kernel Character I/O Support" chapter | Sebastian Huber | 2021-08-03 | 7 | -8/+465 |
| | | | | Close #4482. | ||||
* | eng: Add freestanding test cases | Sebastian Huber | 2021-08-03 | 1 | -0/+6 |
* | user/imxrt: Add notes about problems with EVB | Christian Mauderer | 2021-07-29 | 1 | -0/+9 |
| | | | | | There are some possible problems with the i.MXRT1050 evaluation board. Make some notes about that in the BSP manual. | ||||
* | c-user: Remove _Internal_errors_What_happened | Sebastian Huber | 2021-07-28 | 1 | -3/+2 |
| | | | | This global object no longer exists. | ||||
* | c-user: Document interrupt manager extensions | Sebastian Huber | 2021-07-27 | 2 | -72/+2714 |
| | | | | Close #3269. | ||||
* | README: Added centOS 8 instructions | Stephen Clark | 2021-07-20 | 1 | -0/+11 |
| | | | | Added some instructions for setting up CentOS 8. | ||||
* | README: Minor clarifications and fixes | Stephen Clark | 2021-07-20 | 1 | -24/+25 |
| | | | | | | Fixed some minor typographical errors. Updated a dead link. Reworded some sentences for clarity. | ||||
* | user/bsps/aarch64: Minor formatting fix | Stephen Clark | 2021-07-15 | 2 | -6/+10 |
| | | | | | Fixed formatting error in user/bsps/aarch64/a53.rst and user/bsps/aarch64/xilinx-zynqmp.rst. | ||||
* | xilinx-zynqmp.rst: Documented SDIO driver | Stephen Clark | 2021-07-15 | 1 | -0/+14 |
| | | | | Added documentation for SDIO driver. | ||||
* | user: Update ZynqMP network configuration | Kinsey Moore | 2021-07-15 | 1 | -8/+3 |
| | | | | | Network configuration is now automatic and requires no user configuration. | ||||
* | rtems-docs: remove Eclipse Manual | Ray Garza | 2021-07-06 | 35 | -479/+0 |
| | | | | | Due to RTEMS 6 no longer using the Make build system and instead using Waf (Eclipse does not offer Waf support), this guide is being removed. | ||||
* | user/bsps/imxrt: Info about ARM PLL frequency | Christian Mauderer | 2021-07-02 | 1 | -0/+20 |
| | | | | Update #4180 | ||||
* | user/bsps/imxrt: Fix typo | Christian Mauderer | 2021-07-02 | 1 | -1/+1 |
* | user/bsps: Update ZynqMP for hardware BSPs | Kinsey Moore | 2021-07-01 | 1 | -8/+49 |
| | | | | | | Update the ZynqMP documentation for the new hardware BSP variants including information about booting, boot image generation, and networking. | ||||
* | user/bsps: add aarch64 xilinx-versal | Gedare Bloom | 2021-06-22 | 2 | -0/+40 |
* | user: Fixed typo to build hello application | Ida Delphine | 2021-06-15 | 1 | -1/+1 |
* | c-user: Use a common phrase for pointer parameters | Sebastian Huber | 2021-06-15 | 15 | -159/+163 |
| | | | | | | | Mention the type of the pointer in the parameter description. Use the more general term "object" instead of "variable". Update #3993. | ||||
* | user: add bsps/aarch64/a72.rst | Gedare Bloom | 2021-06-08 | 2 | -0/+36 |
* | user: fix typo in aarch64/a53.rst | Gedare Bloom | 2021-06-08 | 1 | -1/+1 |
* | Update Compliance Tracking CSV file to fix minor bugs | Joel Sherrill | 2021-06-04 | 2 | -873/+874 |
* | eng/vc-authors: Add section on migrating personal repo to top-level | Vijay Kumar Banerjee | 2021-05-30 | 1 | -0/+46 |
* | c-users: Add rtems_*mutex_try_lock | Christian Mauderer | 2021-05-28 | 1 | -0/+35 |
| | | | | Closes #4440. | ||||
* | bsps/imxrt: Remove superfluous options from dtc | Christian Mauderer | 2021-05-28 | 1 | -1/+1 |
| | | | | | | | | | | | The -@ option adds symbols that are used when applying an overlay. RTEMS doesn't support overlays or re-parsing of device trees. So the symbols only increase the size of the binary. The same is true for the padding. It would be useful if the device tree is changed during run time which is not supported in RTEMS. Update #4180 | ||||
* | c-user: Document new rtems_task_delete() error | Sebastian Huber | 2021-05-27 | 1 | -0/+3 |
| | | | | Close #4414. | ||||
* | Fix the bibtex extension configure test | Chris Johns | 2021-05-21 | 1 | -2/+4 |
* | Fix the linux specific include | Chris Johns | 2021-05-21 | 1 | -4/+4 |
* | posix-compliance: Update to include POSIX 1003.1-2017 (Issue 7). | Joel Sherrill | 2021-05-17 | 4 | -1379/+1395 |
* | posix-compliance/posix_rst.py: Use proper names of standards in headings | Joel Sherrill | 2021-05-17 | 1 | -18/+18 |
* | user/bld/index.rst: removed references to legacy network config options | Harrison Edward Gerber | 2021-05-16 | 1 | -7/+0 |
* | c-user: Constify rtems_task_wake_when() | Sebastian Huber | 2021-05-12 | 1 | -1/+1 |
| | | | | Update #4406. | ||||
* | c-user: Clarify rtems_task_get_priority() | Sebastian Huber | 2021-05-12 | 1 | -2/+2 |
* | c-user: Document rtems_task_set_scheduler() errors | Sebastian Huber | 2021-05-12 | 1 | -2/+22 |
* | c-user: Add task priority glossary terms | Sebastian Huber | 2021-05-12 | 1 | -3/+38 |
* | c-user: Change format of external function refs | Sebastian Huber | 2021-05-08 | 1 | -1/+1 |
