* | spec: Fix variable type | Sebastian Huber | 2023-08-09 | 1 | -1/+1 |
| | | | | This fixes test failures on targets using short enums. | ||||
* | spec: Remove superfluous include | Sebastian Huber | 2023-07-31 | 1 | -1/+0 |
* | spec: Add task entry glossary term | Sebastian Huber | 2023-07-25 | 2 | -3/+4 |
* | spec: Remove superfluous ';' | Sebastian Huber | 2023-07-21 | 7 | -20/+20 |
* | spec: Fix typo | Sebastian Huber | 2023-07-20 | 1 | -1/+1 |
* | spec/wake-after: Update references to intervals | Kinsey Moore | 2023-07-20 | 1 | -12/+16 |
| | | | | | | | | | | rtems_task_wake_after takes a parameter in terms of a count of clock ticks and not a measure in a subunit of seconds. This updates documentation to reflect that and recommends clock_nanosleep() for applications requiring sleep for a time-based duration instead of a count of clock ticks. Updates #4772 | ||||
* | Update company name | Sebastian Huber | 2023-05-19 | 118 | -118/+118 |
| | | | | | The embedded brains GmbH & Co. KG is the legal successor of embedded brains GmbH. | ||||
* | spec: Reference types in construct directives | Sebastian Huber | 2023-05-09 | 1 | -1/+2 |
* | spec: Use ${.:/step} | Sebastian Huber | 2023-05-08 | 2 | -17/+17 |
* | spec: Add subsitution keys | Sebastian Huber | 2023-05-08 | 1 | -1/+1 |
* | spec: Use ${xzy:/spec} for item references | Sebastian Huber | 2023-05-08 | 1 | -1/+1 |
* | spec: Reorganize performance runtime limits | Sebastian Huber | 2023-05-08 | 10 | -1838/+0 |
| | | | | | Add a dedicated item for performance runtime limits and use the general linking mechanism to associate limits and tests. | ||||
* | spec: Replace enum Event with defines | Sebastian Huber | 2023-03-17 | 1 | -6/+6 |
| | | | | | There is a Doxygen limitation that all compound names (enum, struct, class, union, group) within a project must be unique. | ||||
* | spec: Place test suites in design groups | Sebastian Huber | 2023-03-14 | 13 | -0/+26 |
* | validation: Derive names from item UIDs | Sebastian Huber | 2023-02-16 | 13 | -13/+0 |
| | | | | | Use the item UID converted to CamelCase for Doxygen group names and testsuite names. | ||||
* | spec: Add header file references | Sebastian Huber | 2023-02-14 | 1 | -3/+3 |
* | spec: Add CONFIGURE_IDLE_TASK_STORAGE_SIZE | Sebastian Huber | 2022-10-11 | 13 | -0/+26 |
* | spec: Add types to macros | Sebastian Huber | 2022-10-04 | 1 | -4/+8 |
* | spec: Unify interface functions and macros | Sebastian Huber | 2022-10-04 | 1 | -6/+14 |
* | spec: Add "memory-benchmark" item type | Sebastian Huber | 2022-09-28 | 13 | -13/+13 |
* | spec: Move Classic API maximum priority item | Sebastian Huber | 2022-09-02 | 3 | -1/+29 |
* | spec: Use priority inheritance for thread join | Sebastian Huber | 2022-07-28 | 3 | -50/+47 |
* | spec: Document new task delete behaviour | Sebastian Huber | 2022-07-28 | 1 | -7/+23 |
* | spec: Clarify scheduler of created task | Sebastian Huber | 2022-03-30 | 5 | -5/+154 |
* | spec: Use individual names for ident tests | Sebastian Huber | 2022-03-30 | 1 | -24/+3 |
* | spec: Update performance limits | Sebastian Huber | 2022-01-24 | 10 | -1198/+1458 |
* | spec: Update performance limits | Sebastian Huber | 2022-01-12 | 10 | -470/+210 |
* | spec: Fix stack corruption in test case | Sebastian Huber | 2021-12-22 | 2 | -3/+33 |
* | spec: Add limits from HW runs to performance tests | Frank Kühndel | 2021-12-08 | 10 | -9/+663 |
* | spec: Fix formatting | Sebastian Huber | 2021-12-04 | 4 | -14/+14 |
* | spec: Add limits to time performance tests | Frank Kühndel | 2021-12-03 | 10 | -10/+1184 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | This patch adds limits to all currently existing time performance tests. When the measured time during the execution of these tests is within the range specified by these limits, the test result will be OK. The limit data is provided for the following architecture and environments (the tests can only pass when executed in the same setting): * SPARC Instruction Set Simulator: + GR721RC SMP + GR721RC UNI + GR740 SMP + GR740 UNI * Hardware boards: + GR721RC SMP + GR721RC UNI + GR740 SMP + GR740 UNI With the exception of GR721RC SMP, the input data of the hardware boards contained only measurement data for three tests: * spec/rtems/part/req/perf-get-buffer.yml * spec/rtems/part/req/perf-get-no-buffer.yml * spec/rtems/part/req/perf-return-buffer.yml The other tests where still under development when the test runs where made. The test logs (input data) from the simulator runs where taken around 2021-11-28. The test logs from the hardware are completed at 2021-11-21 with the exception of the GR721RC UNI which completed 2021-11-16 and GR721RC SMP which completed 2021-12-02. | ||||
* | spec: Adjust link role for some design groups | Sebastian Huber | 2021-12-01 | 1 | -1/+1 |
* | spec: Add requirements to groups | Sebastian Huber | 2021-12-01 | 1 | -0/+2 |
* | spec: Add memory benchmarks to groups | Sebastian Huber | 2021-12-01 | 13 | -0/+26 |
* | spec: Add performance requirements | Sebastian Huber | 2021-11-26 | 11 | -3/+570 |
* | spec: Reduce sample count | Sebastian Huber | 2021-11-26 | 1 | -1/+1 |
* | spec: Add performance requirements | Sebastian Huber | 2021-11-25 | 2 | -2/+65 |
* | spec: Add performance requirements | Sebastian Huber | 2021-11-25 | 2 | -0/+45 |
* | spec: Fix enabled-by of rtems_task_self() | Sebastian Huber | 2021-11-25 | 1 | -2/+1 |
* | spec: Use RTEMS_WHO_AM_I for rtems_task_ident() | Sebastian Huber | 2021-11-19 | 2 | -13/+18 |
* | spec: Specify RTEMS_CONFIGURED_MINIMUM_STACK_SIZE | Sebastian Huber | 2021-11-19 | 2 | -0/+29 |
* | spec: Specify RTEMS_MINIMUM_PRIORITY | Sebastian Huber | 2021-11-19 | 2 | -0/+25 |
* | spec: Specify RTEMS_MINIMUM_STACK_SIZE | Sebastian Huber | 2021-11-19 | 2 | -0/+28 |
* | spec: Specify RTEMS_NO_PRIORITY | Sebastian Huber | 2021-11-19 | 2 | -0/+32 |
* | spec: Specify RTEMS_SELF | Sebastian Huber | 2021-11-19 | 2 | -0/+58 |
* | spec: Validate alignment constants | Sebastian Huber | 2021-11-19 | 2 | -1/+13 |
* | spec: Improve acfg specification | Sebastian Huber | 2021-11-19 | 1 | -1/+2 |
| | | | | Rework BSP provided configuration settings. | ||||
* | spec: Clarify RTEMS_MINIMUM_STACK_SIZE | Sebastian Huber | 2021-11-18 | 2 | -2/+17 |
* | spec: Avoid magic number | Sebastian Huber | 2021-11-18 | 1 | -1/+1 |
* | spec: Add interface function links | Sebastian Huber | 2021-11-18 | 3 | -0/+6 |
