* | spec: Fix powerpc in test caseHEADmaster | Sebastian Huber | 2024-04-17 | 1 | -1/+1 |
| | | | | The powerpc context switch restores the interrupt state. | ||||
* | spec: Fix synchronization issues | Sebastian Huber | 2024-04-17 | 1 | -0/+1 |
* | spec: Specify the global construction for aarch64 | Sebastian Huber | 2024-04-17 | 3 | -0/+3 |
* | spec: Improve bad thread dispatch validation | Sebastian Huber | 2024-04-17 | 1 | -9/+59 |
* | spec: Specify Xilinx TTC clock driver | Sebastian Huber | 2024-04-17 | 9 | -1/+273 |
* | spec: Move clock driver group | Sebastian Huber | 2024-04-17 | 3 | -5/+5 |
* | spec: Move device driver group | Sebastian Huber | 2024-04-17 | 2 | -2/+2 |
* | spec: Add tests for compiler builtins | Sebastian Huber | 2024-04-06 | 1 | -14/+207 |
| | | | | | | | On the arm target, __udivmoddi4() cannot be fully tested through normal integer divisions. Update #3716. | ||||
* | spec: Avoid -Wundef warnings in API header | Sebastian Huber | 2024-03-23 | 3 | -6/+18 |
* | spec: Fix CONFIGURE_TICKS_PER_TIMESLICE constraint | Sebastian Huber | 2024-03-21 | 1 | -1/+1 |
| | | | | Update #4986. | ||||
* | spec: Fix typo | Sebastian Huber | 2024-01-26 | 1 | -1/+1 |
* | spec: Document assert-in-set action | Sebastian Huber | 2024-01-26 | 1 | -0/+4 |
* | spec/cache/coherent: Add return value for add area | Kinsey Moore | 2024-01-26 | 1 | -2/+10 |
| | | | | | | This changes the return type for rtems_cache_coherent_add_area from void to rtems_status_code so that the function can report errors when they occur. | ||||
* | spec: Support more BSPs in validation test | Sebastian Huber | 2023-12-19 | 1 | -6/+3 |
| | | | | | | Use the new functions RaiseSoftwareInterrupt() and ClearSoftwareInterrupt() which may use a BSP-specific support for software generated interrupts (see TM27_INTERRUPT_VECTOR_ALTERNATIVE). | ||||
* | spec: Add JFFS2 delayed write task priority | Kinsey Moore | 2023-12-19 | 1 | -0/+22 |
| | | | | | | | This adds the configuration option used to select the JFFS2 delayed write task priority to be used when operating on NAND flash. Updates #4961 | ||||
* | spec: Fix enabled-by | Sebastian Huber | 2023-11-27 | 3 | -3/+3 |
* | spec: Add runtime performance limits | Sebastian Huber | 2023-11-27 | 2 | -0/+122 |
* | spec: Remove superfluous includes | Sebastian Huber | 2023-11-23 | 1 | -4/+0 |
* | spec: Improve MrsP specification | Sebastian Huber | 2023-11-23 | 4 | -37/+44 |
| | | | | | | | | For uniprocessor configurations, the selection of RTEMS_MULTIPROCESSOR_RESOURCE_SHARING results in a priority ceiling mutex. Build the MrsP validation tests only if RTEMS_SMP is enabled. | ||||
* | spec: Fix typo in name | Sebastian Huber | 2023-11-21 | 6 | -6/+6 |
* | spec: Specify thread dispatch detail | Sebastian Huber | 2023-11-21 | 2 | -1/+100 |
* | spec: Fix memory benchmark configurations | Sebastian Huber | 2023-11-21 | 12 | -0/+24 |
* | spec: Make SMP memory benchmarks optional | Sebastian Huber | 2023-11-21 | 10 | -10/+10 |
* | spec: Add SIS descriptions | Sebastian Huber | 2023-11-21 | 2 | -6/+14 |
* | spec: Add Gaisler board descriptions | Daniel Hellstrom | 2023-11-21 | 2 | -6/+150 |
* | spec: Add runtime performance limits | Sebastian Huber | 2023-11-21 | 2 | -0/+122 |
* | spec: Update performance limits for gr712rc | Sebastian Huber | 2023-11-21 | 3 | -1706/+1854 |
| | | | | | Using the DSU for the CPU counter implementation changed the performance limits. | ||||
* | spec: Adjust target hashes | Sebastian Huber | 2023-11-21 | 4 | -4/+4 |
| | | | | | Using the DSU for the clock driver and the CPU counter implementation changed the target hashes of the GR712RC. | ||||
* | spec: Add missing verb | Sebastian Huber | 2023-11-21 | 1 | -4/+4 |
* | spec: Fix typos | Sebastian Huber | 2023-11-21 | 2 | -4/+4 |
* | spec: Validate user interfaces | Sebastian Huber | 2023-11-21 | 1 | -0/+17 |
* | spec: Validate build options | Sebastian Huber | 2023-11-21 | 1 | -0/+29 |
* | spec: Validate C interfaces | Sebastian Huber | 2023-11-21 | 5 | -8/+89 |
* | spec: Validate compiler interfaces | Sebastian Huber | 2023-11-21 | 1 | -0/+43 |
* | spec: Validate documentation interfaces | Sebastian Huber | 2023-11-21 | 1 | -0/+43 |
* | spec: Validate implementation interfaces | Sebastian Huber | 2023-11-21 | 1 | -0/+347 |
* | spec: Add valid by construction analysis | Sebastian Huber | 2023-11-21 | 1 | -0/+329 |
* | spec: Fix enabled-by | Sebastian Huber | 2023-11-21 | 2 | -2/+2 |
* | spec: Fix validation test for microblaze | Sebastian Huber | 2023-11-07 | 1 | -0/+17 |
* | spec: Improve thread idle bodies test | Sebastian Huber | 2023-11-07 | 1 | -4/+15 |
* | spec: More unit tests for compiler builtins | Sebastian Huber | 2023-11-03 | 1 | -5/+346 |
* | spec: Test CPU performance | Sebastian Huber | 2023-10-12 | 4 | -0/+134 |
| | | | | | | | | | Measure the runtime of 1000 no-operation instructions. This may help to investigate runtime measurement variations which do not result from code generation or source code changes. The runtime measurement of a function which does nothing and just returns gives an estimate of the measurement overhead. | ||||
* | spec: Unit tests for compiler builtins | Sebastian Huber | 2023-10-12 | 2 | -0/+499 |
* | spec: Use validation links for unit tests | Sebastian Huber | 2023-10-12 | 3 | -3/+3 |
* | spec: Support powerpc in test case | Sebastian Huber | 2023-10-12 | 1 | -0/+17 |
* | spec: Clarify performance requirement | Sebastian Huber | 2023-09-26 | 1 | -2/+3 |
* | spec: Compatibility for other RTEMS versions | Sebastian Huber | 2023-09-26 | 3 | -6/+12 |
| | | | | | | Make some performance tests compatible to other RTEMS versions which do not allow changing the priority of a task which owns a priority inheritance mutex. | ||||
* | spec: Simplify partition performance test | Sebastian Huber | 2023-09-26 | 1 | -2/+1 |
| | | | | Do not depend on <rtems/chain.h>. | ||||
* | spec: Specify interrupt service detail | Sebastian Huber | 2023-09-26 | 3 | -0/+219 |
* | spec: Improve RTEMS_DEFINE_GLOBAL_SYMBOL() tests | Sebastian Huber | 2023-09-18 | 1 | -0/+21 |
| | | | | | Assign the symbol address to an object. Check that it has the expected value. |
