* | Update company name | Sebastian Huber | 2023-05-19 | 1 | -1/+1 |
| | | | | | The embedded brains GmbH & Co. KG is the legal successor of embedded brains GmbH. | ||||
* | spec: Add requirement for RTEMS_NO_TIMEOUT | Sebastian Huber | 2023-05-08 | 1 | -2/+0 |
* | spec: Add interface function links | Sebastian Huber | 2021-11-18 | 1 | -0/+2 |
* | spec: Update due to score API changes | Sebastian Huber | 2021-11-11 | 1 | -4/+3 |
* | spec: Add requirement texts | Sebastian Huber | 2021-09-08 | 1 | -1/+3 |
* | validation: Add ${.:/test-context-type} | Sebastian Huber | 2021-08-17 | 1 | -1/+1 |
| | | | | | Add and use ${.:/test-context-type} and ${.:/test-context-instance} substitutions. | ||||
* | validation: Support freestanding test cases | Sebastian Huber | 2021-07-30 | 1 | -0/+1 |
* | spec: Add and use software architecture components | Sebastian Huber | 2021-05-28 | 1 | -1/+3 |
* | validation: Assign run parameters early | Sebastian Huber | 2021-04-19 | 1 | -1/+0 |
| | | | | | This allows to use the run parameters in the setup/teardown fixture methods. | ||||
* | spec: Update due to renamed header | Sebastian Huber | 2021-04-12 | 1 | -1/+1 |
* | spec: Update due to API changes | Sebastian Huber | 2021-04-08 | 1 | -9/+9 |
* | spec: Use tc-support.h | Sebastian Huber | 2021-03-22 | 1 | -63/+13 |
* | spec: Canonicalize directives | Sebastian Huber | 2021-03-19 | 1 | -22/+23 |
| | | | | Use common wording and the new templates for action requirements. | ||||
* | spec: Improve or fix wording | Sebastian Huber | 2021-03-11 | 1 | -1/+1 |
* | spec: Improve event send/receive | Sebastian Huber | 2021-03-01 | 1 | -1/+36 |
| | | | | Add a condition for a NULL pointer for the event set to receive. | ||||
* | spec: Use EARS syntax | Sebastian Huber | 2021-02-19 | 1 | -14/+17 |
| | | | | Avoid the term "There shall". | ||||
* | spec: Fix event send/receive validation | Sebastian Huber | 2020-10-12 | 1 | -2/+17 |
* | spec: Use rtems_task_construct() | Sebastian Huber | 2020-09-17 | 1 | -14/+25 |
* | spec: Group items by component | Sebastian Huber | 2020-09-16 | 1 | -0/+1001 |
