* | Update company name | Sebastian Huber | 2023-05-19 | 1 | -1/+1 |
| | | | | | The embedded brains GmbH & Co. KG is the legal successor of embedded brains GmbH. | ||||
* | spec: Fix formatting | Sebastian Huber | 2023-05-08 | 1 | -1/+1 |
* | spec: Use ${.:/step} | Sebastian Huber | 2023-05-08 | 1 | -23/+23 |
* | spec: Update message manager specification | Frank Kühndel | 2021-09-14 | 1 | -0/+18 |
* | spec: Rename test case action attributes | Sebastian Huber | 2021-02-04 | 1 | -80/+80 |
| | | | | The new attribute keys make it easier to write test cases. | ||||
* | validation: Move actions to separate functions | Sebastian Huber | 2021-02-04 | 1 | -2/+4 |
* | validation: Remove prologue/epilogue in test cases | Sebastian Huber | 2021-02-04 | 1 | -2/+0 |
* | spec: Avoid test prologue/epilogue in test cases | Sebastian Huber | 2021-02-04 | 1 | -2/+3 |
* | validation: Add context and fixture to test case | Sebastian Huber | 2021-02-04 | 1 | -1/+5 |
* | spec: Fix attribute validation test | Sebastian Huber | 2020-09-18 | 1 | -3/+3 |
* | spec: Group items by component | Sebastian Huber | 2020-09-16 | 1 | -0/+278 |
