#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
Update #3706
Thread priority changes may append or prepend the thread to its priority
group on the scheduler ready queue. Previously, a separate priority
value and a prepend-it flag in the scheduler node were used to propagate
a priority change to the scheduler.
Now, use an append-it bit in the priority control and reduce the plain
priority value to 63 bits.
This change leads to a significant code size reduction (about 25%) of
the SMP schedulers. The negligible increase of the standard priority
scheduler is due to some additional shift operations
(SCHEDULER_PRIORITY_MAP() and SCHEDULER_PRIORITY_UNMAP()).
Before:
text filename
136 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulersimpleblock.o
464 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulersimplechangepriority.o
24 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulersimple.o
108 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulersimpleschedule.o
292 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulersimpleunblock.o
264 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulersimpleyield.o
text filename
280 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerpriorityblock.o
488 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerprioritychangepriority.o
200 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerpriority.o
164 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerpriorityschedule.o
328 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerpriorityunblock.o
200 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerpriorityyield.o
text filename
24112 arm-rtems5/c/imx7/cpukit/score/src/libscore_a-scheduleredfsmp.o
text filename
37204 sparc-rtems5/c/gr740/cpukit/score/src/libscore_a-scheduleredfsmp.o
text filename
42236 powerpc-rtems5/c/qoriq_e6500_32/cpukit/score/src/libscore_a-scheduleredfsmp.o
After:
text filename
272 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulersimplechangepriority.o
text filename
208 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerpriority.o
332 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerpriorityunblock.o
text filename
18860 arm-rtems5/c/imx7/cpukit/score/src/libscore_a-scheduleredfsmp.o
text filename
28520 sparc-rtems5/c/gr740/cpukit/score/src/libscore_a-scheduleredfsmp.o
text filename
32664 powerpc-rtems5/c/qoriq_e6500_32/cpukit/score/src/libscore_a-scheduleredfsmp.o
Only register ask for help requests in the scheduler unblock and yield
operations. The actual ask for help operation is carried out during
_Thread_Do_dispatch() on a processor related to the thread. This yields
a better separation of scheduler instances. A thread of one scheduler
instance should not be forced to carry out too much work for threads on
other scheduler instances.
Update #2556.
Update #2556.
Changed for consistency with other scheduler operations.
Update #2556.
Return a thread in need for help for the following scheduler operations
- unblock,
- change priority, and
- yield.
A thread in need for help is a thread that encounters a scheduler state
change from scheduled to ready or a thread that cannot be scheduled in
an unblock operation. Such a thread can ask threads which depend on
resources owned by this thread for help.
The _Scheduler_Yield() was called by the executing thread with thread
dispatching disabled and interrupts enabled. The rtems_task_suspend()
is explicitly allowed in ISRs:
http://rtems.org/onlinedocs/doc-current/share/rtems/html/c_user/Interrupt-Manager-Directives-Allowed-from-an-ISR.html#Interrupt-Manager-Directives-Allowed-from-an-ISR
Unlike the other scheduler operations the locking was performed inside
the operation. This lead to the following race condition. Suppose a
ISR suspends the executing thread right before the yield scheduler
operation. Now the executing thread is not longer in the set of ready
threads. The typical scheduler operations did not check the thread
state and will now extract the thread again and enqueue it. This
corrupted data structures.
Add _Thread_Yield() and do the scheduler yield operation with interrupts
disabled. This has a negligible effect on the interrupt latency.
The function to change a thread priority was too complex. Simplify it
with a new scheduler operation. This increases the average case
performance due to the simplified logic. The interrupt disabled
critical section is a bit prolonged since now the extract, update and
enqueue steps are executed atomically. This should however not impact
the worst-case interrupt latency since at least for the Deterministic
Priority Scheduler this sequence can be carried out with a wee bit of
instructions and no loops.
Add _Scheduler_Change_priority() to replace the sequence of
- _Thread_Set_transient(),
- _Scheduler_Extract(),
- _Scheduler_Enqueue(), and
- _Scheduler_Enqueue_first().
Delete STATES_TRANSIENT, _States_Is_transient() and
_Thread_Set_transient() since this state is now superfluous.
With this change it is possible to get rid of the
SCHEDULER_SMP_NODE_IN_THE_AIR state. This considerably simplifies the
implementation of the new SMP locking protocols.
Do not allocate the scheduler control structures from the workspace.
This is a preparation step for configuration of clustered/partitioned
schedulers on SMP.
Scheduler operations must be free of a global scheduler context to
enable partitioned/clustered scheduling.
Add call to _Scheduler_Schedule() in missing path after
_Thread_Set_transient() in _Thread_Change_priority(). See also
sptests/spintrcritical19.
Add thread parameter to _Scheduler_Schedule(). This parameter is
currently unused but may be used in future SMP schedulers.
Do heir selection in _Scheduler_Schedule(). Use
_Scheduler_Update_heir() for this in the particular scheduler
implementation.
Add and use _Scheduler_Generic_block().
Move implementation specific parts of thread.h and thread.inl into new
header file threadimpl.h. The thread.h contains now only the
application visible API.
Remove superfluous header file includes from various files.
Move implementation specific parts of schedulersimple.h and
schedulersimple.inl into new header file schedulersimpleimpl.h. The
schedulersimple.h contains now only the application visible API.
The yielding thread of the yield operation is now specified by a
parameter. The tick operation may be performed for each executing
thread in a SMP configuration.
comments in the RTEMS source.
http://www.google-melange.com/gci/task/view/google/gci2012/7970221
* score/inline/rtems/score/schedulersimple.inl,
score/src/schedulersimpleyield.c: Fix violations of naming
convention.
PR 1743/cpu
* sapi/include/confdefs.h, score/Makefile.am, score/preinstall.am: Add
Simple Priority Scheduler as complement to existing Deterministic
Priority Scheduler. This scheduler serves both as an example and as a
lighter weight implementation for smaller systems.
* score/include/rtems/score/schedulersimple.h,
score/src/schedulersimple.c, score/src/schedulersimpleblock.c,
score/src/schedulersimpleenqueue.c,
score/src/schedulersimpleenqueuefirst.c,
score/src/schedulersimpleextract.c,
score/src/schedulersimplereadyqueueenqueue.c,
score/src/schedulersimplereadyqueueenqueuefirst.c,
score/src/schedulersimpleschedule.c,
score/src/schedulersimpleunblock.c, score/src/schedulersimpleyield.c:
New files.
