#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
Update #3706
Do not allocate the scheduler control structures from the workspace.
This is a preparation step for configuration of clustered/partitioned
schedulers on SMP.
Rename _Scheduler_simple_Update() in _Scheduler_default_Update().
Rename _Scheduler_simple_Allocate() in _Scheduler_default_Allocate().
Rename _Scheduler_simple_Free() in _Scheduler_default_Free().
Move implementation specific parts of schedulerpriority.h and
schedulerpriority.inl into new header file schedulerpriorityimpl.h. The
schedulerpriority.h contains now only the application visible API.
Add missing includes. Remove superfluous includes.
Move declaration of _Priority_Bit_map to prioritybitmap.inl since this
variable is used only here.
Remove second declaration of _Priority_Major_bit_map.
comments in the RTEMS source.
http://www.google-melange.com/gci/task/view/google/gci2012/7976215
PR 1743/cpu
* sapi/include/confdefs.h, score/Makefile.am, score/preinstall.am: Add
Simple Priority Scheduler as complement to existing Deterministic
Priority Scheduler. This scheduler serves both as an example and as a
lighter weight implementation for smaller systems.
* score/include/rtems/score/schedulersimple.h,
score/inline/rtems/score/schedulersimple.inl,
score/src/schedulersimple.c, score/src/schedulersimpleblock.c,
score/src/schedulersimpleenqueue.c,
score/src/schedulersimpleenqueuefirst.c,
score/src/schedulersimpleextract.c,
score/src/schedulersimplereadyqueueenqueue.c,
score/src/schedulersimplereadyqueueenqueuefirst.c,
score/src/schedulersimpleschedule.c,
score/src/schedulersimpleunblock.c, score/src/schedulersimpleyield.c:
New files.
