#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
Do not adjust the stack pointer, since this is already done by the
restor instruction.
Update #2270.
Move CPU_Interrupt_frame related defines to <rtems/score/cpuimpl.h>.
Update #2809.
Rename SPARC-specific CPU_Minimum_stack_frame to
SPARC_Minimum_stack_frame. Rename SPARC-specific
CPU_MINIMUM_STACK_FRAME_SIZE to SPARC_MINIMUM_STACK_FRAME_SIZE.
Update #2809.
Implement _CPU_Context_validate() and _CPU_Context_volatile_clobber().
Update #2270.
