#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
comments in the RTEMS source.
http://www.google-melange.com/gci/task/view/google/gci2012/8013205
Add
o _Nios2_MPU_Get_region_descriptor(), and
o _Nios2_MPU_Set_region_registers().
* nios2-mpu-configuration.c, nios2-mpu-descriptor.c,
nios2-mpu-disable-protected.c, nios2-mpu-reset.c: New files.
* rtems/score/nios2-utility.h, nios2-context-initialize.c: Added
support for the memory protection unit (MPU).
