#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
Apparently killinfo() is not defined by POSIX, glibc or FreeBSD. Rename
killinfo() to _POSIX_signals_Send() to cleary mark it as an internal
function.
Move implementation specific parts of pthread.h and pthread.inl into new
header file pthreadimpl.h. The pthread.h contains now only the
application visible API.
http://www.google-melange.com/gci/task/view/google/gci2012/8022219
This file contains the parts of <rtems/posix/psignal.h> that are only
necessary for the POSIX API implementation.
* posix/Makefile.am, posix/src/kill.c, posix/src/killinfo.c: Split file
and resolved copyright information.
* posix/src/kill_r.c: New file.
