#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
The RTEMS build of Newlib includes implementations of all exec*()
variants. They rely on the _execve() support method. RTEMS already
had this and it returned ENOSYS. There is no functional change.
closes #2537.
http://www.google-melange.com/gci/task/view/google/gci2012/7958218
* posix/Makefile.am: Add _execve() so we can use newlib posix support
directory and eliminate code in RTEMS.
* posix/src/_execve.c: New file.
