summaryrefslogtreecommitdiff
path: root/cpukit/libnetworking/rtems/rtems_showmbuf.c (follow)
AgeCommit message (Collapse)Author
2020-04-16Canonicalize config.h includeSebastian Huber
Use the following variant which was already used by most source files: #ifdef HAVE_CONFIG_H #include "config.h" #endif
2018-09-10network: Use kernel/user space header filesSebastian Huber
Add and use <machine/rtems-bsd-kernel-space.h> and <machine/rtems-bsd-user-space.h> similar to the libbsd to avoid command line defines and defines scattered throught the code base. Simplify cpukit/libnetworking/Makefile.am. Update #3375.
2016-04-22network: Fix warningsSebastian Huber
2012-05-11Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed.
2011-03-02Use <sys/queue.h> instead of <rtems/bsd/sys/queue.h.Ralf Corsepius
2007-05-10Include <rtems/bsd/sys/queue.h> instead of <sys/queue.h>.Ralf Corsepius
2005-02-02Include config.h.Ralf Corsepius
1998-08-20Added CVS IdsJoel Sherrill
1998-08-19Base filesJoel Sherrill
