2020-04-28 | doxygen: Switch @brief and @ingroup | Sebastian Huber | |
This order change fixes the Latex documentation build via Doxygen. | |||
2014-03-21 | Change all references of rtems.com to rtems.org. | Chris Johns | |
2012-12-21 | libmisc: Doxygen Enhancement Task #1 | Mathew Kallada | |
2012-05-11 | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | |
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed. | |||
2011-02-01 | 2011-02-01 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | |
* libmisc/Makefile.am: Add stringto/stringtolongdouble.c. * libmisc/stringto/stringtolongdouble.c: New. |
