#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
Update #2843.
Update #2388.
Close #2700.
The __FILE__ prevents reproducible builds.
Similar to the task priority option, the new CPU affinity
option is first controlled by the RPCI specific rpciodCpuset
option. If that is not set, it uses the global network task config.
If that is also not set, it falls back to not setting the affinity
at all, using all CPUs.
* libfs/src/nfsclient/src/rpcio.c: Misc. 64bit fixes.
* libfs/src/nfsclient/src/rpcio.c: Warning removal.
Cast pointers to uintptr_t instead of long.
xids are uint32_t not u_long.
* libfs/src/nfsclient/src/rpcio.c, libfs/src/nfsclient/src/rpcio.h:
Use rpcprog_t for "program args", use rpcvers_t for "version args".
Use address to rpciod in calls to rxWakeupCB.
libfs/src/nfsclient/src/cexphelp.c,
libfs/src/nfsclient/src/dirutils.c,
libfs/src/nfsclient/src/nfs.modini.c,
libfs/src/nfsclient/src/nfsTest.c,
libfs/src/nfsclient/src/rpcio.modini.c,
libfs/src/nfsclient/src/sock_mbuf.c,
libfs/src/nfsclient/src/xdr_mbuf.c,
libfs/src/rfs/rtems-rfs-bitmaps-ut.c,
libfs/src/rfs/rtems-rfs-bitmaps.c,
libfs/src/rfs/rtems-rfs-block.c,
libfs/src/rfs/rtems-rfs-buffer-bdbuf.c,
libfs/src/rfs/rtems-rfs-buffer-devio.c,
libfs/src/rfs/rtems-rfs-buffer.c,
libfs/src/rfs/rtems-rfs-dir-hash.c, libfs/src/rfs/rtems-rfs-dir.c,
libfs/src/rfs/rtems-rfs-file-system.c,
libfs/src/rfs/rtems-rfs-file.c, libfs/src/rfs/rtems-rfs-format.c,
libfs/src/rfs/rtems-rfs-group.c, libfs/src/rfs/rtems-rfs-inode.c,
libfs/src/rfs/rtems-rfs-link.c, libfs/src/rfs/rtems-rfs-mutex.c,
libfs/src/rfs/rtems-rfs-rtems-dev.c,
libfs/src/rfs/rtems-rfs-rtems-dir.c,
libfs/src/rfs/rtems-rfs-rtems-file.c,
libfs/src/rfs/rtems-rfs-rtems-utils.c,
libfs/src/rfs/rtems-rfs-rtems.c, libfs/src/rfs/rtems-rfs-shell.c,
libfs/src/rfs/rtems-rfs-trace.c: Add HAVE_CONFIG_H support to let
files receive configure defines.
* libcsupport/src/__times.c, libfs/src/nfsclient/src/nfsTest.c,
libfs/src/nfsclient/src/rpcio.c: Convert calls to legacy routine
rtems_clock_get( RTEMS_CLOCK_GET_xxx, ..) to rtems_clock_get_xxx().
* libfs/src/nfsclient/src/rpcio.c: Correct breakage introduced by Joel
removing asserts with side-effects.
* libfs/src/nfsclient/src/nfs.c, libfs/src/nfsclient/src/rpcio.c:
Remove some warnings. Using ASSERT/assert macros confuses gcc who is
unsure actions take place. More importantly if you ever compiled with
NDEBUG set wrong, intended actions would not occur. Likely I did not
catch all of these.
* configure.ac, libfs/Makefile.am: Add nfsclient to cpukit. Although
the use of RPC/XDR could be an issue, the code does build multilib
across all targets. There are a few remaining warnings to deal with.
* libfs/src/nfsclient/.cvsignore, libfs/src/nfsclient/ChangeLog.slac,
libfs/src/nfsclient/LICENSE, libfs/src/nfsclient/Makefile.am,
libfs/src/nfsclient/README, libfs/src/nfsclient/preinstall.am,
libfs/src/nfsclient/rfc1094.txt,
libfs/src/nfsclient/proto/mount_prot.h,
libfs/src/nfsclient/proto/mount_prot.x,
libfs/src/nfsclient/proto/mount_prot_xdr.c,
libfs/src/nfsclient/proto/nfs_prot.h,
libfs/src/nfsclient/proto/nfs_prot.x,
libfs/src/nfsclient/proto/nfs_prot_xdr.c,
libfs/src/nfsclient/src/librtemsNfs.h, libfs/src/nfsclient/src/nfs.c,
libfs/src/nfsclient/src/nfsTest.c, libfs/src/nfsclient/src/rpcio.c,
libfs/src/nfsclient/src/rpcio.h,
libfs/src/nfsclient/src/xdr_mbuf.c: New files.
