#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
Added a mmap file handler to struct _rtems_filesystem_file_handlers_r.
Updated each file handler object to support the default mmap handler.
Updated mmap() to call the mmap handler for MAP_SHARED.
Added a mmap file handler for shm
Added support for MAP_ANON in mmap().
Updates #2859
Implement ctime and mtime updates according to POSIX. The ctime is
mapped to the FAT create time and date. The mtime is mapped to the FAT
last modified time and date. For the atime use the mtime for
simplicity.
The readv() and writev() support was implemented in terms of multiple
calls to the read and write handlers. This imposes a problem on device
files which use an IO vector as single request entity. For example a
low-level network device (e.g. BPF(4)) may use an IO vector to create
one frame from multiple protocol layers each with its own IO vector
entry.
The fat_file_datasync() read every cluster of the file into the cache
and then synchronized it step-by-step. For unmodified buffers this is a
non-operation. For modified buffers this will wake-up the swapout task
which performs then a single buffer write operation. This is usually
quite inefficient. Firstly we do single buffer writes, secondly we
may perform a lot of unnecessary read operations (for huge files this is
really bad), and thirdly this leads likely to cache evictions.
The synchronization procedure is replaced by a simple
rtems_bdbuf_sync_dev(). This has the side-effect that also buffers not
related to the file are synchronized, but since the modified list is
normally short this should be acceptable.
According to POSIX the lseek() function shall not, by itself, extend the
size of a file.
Remove the size field of rtems_libio_t. A file has only one size but
may have multiple open file descriptors. Thus a file size field in the
file descriptor may lead to inconsistencies.
New default handlers rtems_filesystem_default_lseek_file() and
rtems_filesystem_default_lseek_directory().
o A new data structure rtems_filesystem_global_location_t was
introduced to be used for
o the mount point location in the mount table entry,
o the file system root location in the mount table entry,
o the root directory location in the user environment, and
o the current directory location in the user environment.
During the path evaluation global start locations are obtained to
ensure that the current file system instance will be not unmounted in
the meantime.
o The user environment uses now reference counting and is protected
from concurrent access.
o The path evaluation process was completely rewritten and simplified.
The IMFS, RFS, NFS, and DOSFS use now a generic path evaluation
method. Recursive calls in the path evaluation have been replaced
with iteration to avoid stack overflows. Only the evaluation of
symbolic links is recursive. No dynamic memory allocations and
intermediate buffers are used in the high level path evaluation. No
global locks are held during the file system instance specific path
evaluation process.
o Recursive symbolic link evaluation is now limited by
RTEMS_FILESYSTEM_SYMLOOP_MAX. Applications can retrieve this value
via sysconf().
o The device file system (devFS) uses now no global variables and
allocation from the workspace. Node names are allocated from the
heap.
o The upper layer lseek() performs now some parameter checks.
o The upper layer ftruncate() performs now some parameter checks.
o unmask() is now restricted to the RWX flags and protected from
concurrent access.
o The fchmod_h and rmnod_h file system node handlers are now a file
system operation.
o The unlink_h operation has been removed. All nodes are now destroyed
with the rmnod_h operation.
o New lock_h, unlock_h, clonenod_h, and are_nodes_equal_h file system
operations.
o The path evaluation and file system operations are now protected by
per file system instance lock and unlock operations.
o Fix and test file descriptor duplicate in fcntl().
o New test fstests/fsnofs01.
There existed no calling function for this handler.
* libfs/src/dosfs/msdos_handlers_dir.c,
libfs/src/dosfs/msdos_handlers_file.c, libfs/src/imfs/imfs_fifo.c,
libfs/src/imfs/imfs_handlers_device.c,
libfs/src/imfs/imfs_handlers_directory.c,
libfs/src/imfs/imfs_handlers_link.c,
libfs/src/imfs/imfs_handlers_memfile.c,
libfs/src/imfs/miniimfs_init.c, libfs/src/rfs/rtems-rfs-rtems-dev.c,
libfs/src/rfs/rtems-rfs-rtems-dir.c,
libfs/src/rfs/rtems-rfs-rtems-file.c: Turn NULLs into default
handlers.
* libcsupport/include/rtems/libio.h: Add rtems_off64_t for
internal use. Update the internal off_t to the 64bit offset.
* libnetworking/lib/ftpfs.c, libnetworking/lib/tftpDriver.c,
libfs/src/nfsclient/src/nfs.c, libfs/src/imfs/imfs_fifo.c,
libfs/src/imfs/memfile.c, libfs/src/imfs/imfs_directory.c,
libfs/src/imfs/imfs.h, libfs/src/imfs/deviceio.c: Change off_t to
rtems_off64_t.
* libmisc/shell/main_msdosfmt.c: Add an info level so the format
code can tell the user what is happening. Add more options to
control the format configuration.
* libfs/src/dosfs/msdos_format.c: Add a print function to display
the format progress and print statements. Select a better default
cluster size depending on the size of the disk. This lowers the
size of the FAT on large disks. Read and maintain the MRB
partition information.
* libfs/src/dosfs/dosfs.h, libfs/src/dosfs/fat.h,
libfs/src/dosfs/fat_file.c, libfs/src/dosfs/fat_file.h,
libfs/src/dosfs/msdos.h, libfs/src/dosfs/msdos_conv.c,
libfs/src/dosfs/msdos_create.c, libfs/src/dosfs/msdos_file.c,
libfs/src/dosfs/msdos_init.c, libfs/src/dosfs/msdos_initsupp.c,
libfs/src/dosfs/msdos_misc.c, libfs/src/dosfs/msdos_mknod.c: Add
long file name support. Change off_t to rtems_off64_t.
reduce size of data area.
IMFS: Fixed creation of symbolic links to avoid a compiler warning.
DOSFS: Use LibBlock instead of read() to read the boot record.
* src/dosfs/dosfs.h, src/dosfs/fat.h, src/dosfs/fat_fat_operations.h,
src/dosfs/fat_file.h, src/dosfs/msdos.h, src/dosfs/msdos_create.c,
src/dosfs/msdos_dir.c, src/dosfs/msdos_eval.c,
src/dosfs/msdos_file.c, src/dosfs/msdos_free.c,
src/dosfs/msdos_fsunmount.c, src/dosfs/msdos_handlers_dir.c,
src/dosfs/msdos_handlers_file.c, src/dosfs/msdos_init.c,
src/dosfs/msdos_initsupp.c, src/dosfs/msdos_misc.c,
src/dosfs/msdos_mknod.c, src/dosfs/msdos_node_type.c,
src/imfs/deviceio.c, src/imfs/imfs.h, src/imfs/imfs_chown.c,
src/imfs/imfs_config.c, src/imfs/imfs_creat.c, src/imfs/imfs_debug.c,
src/imfs/imfs_directory.c, src/imfs/imfs_eval.c,
src/imfs/imfs_fchmod.c, src/imfs/imfs_fcntl.c,
src/imfs/imfs_fdatasync.c, src/imfs/imfs_free.c,
src/imfs/imfs_fsunmount.c, src/imfs/imfs_getchild.c,
src/imfs/imfs_gtkn.c, src/imfs/imfs_handlers_device.c,
src/imfs/imfs_handlers_directory.c, src/imfs/imfs_handlers_link.c,
src/imfs/imfs_handlers_memfile.c, src/imfs/imfs_init.c,
src/imfs/imfs_initsupp.c, src/imfs/imfs_link.c,
src/imfs/imfs_mknod.c, src/imfs/imfs_mount.c, src/imfs/imfs_ntype.c,
src/imfs/imfs_readlink.c, src/imfs/imfs_rmnod.c,
src/imfs/imfs_stat.c, src/imfs/imfs_symlink.c,
src/imfs/imfs_unixstub.c, src/imfs/imfs_unlink.c,
src/imfs/imfs_unmount.c, src/imfs/imfs_utime.c, src/imfs/ioman.c,
src/imfs/linearfile.c, src/imfs/memfile.c, src/imfs/miniimfs_init.c:
URL for license changed.
* DOS filesystem including FAT12, FAT16, and FAT32 support submitted.
* src/dosfs, src/dosfs/Makefile.am, src/dosfs/stamp-h2.in,
src/dosfs/config.h.in, src/dosfs/dosfs.h, src/dosfs/fat.c,
src/dosfs/fat.h, src/dosfs/fat_fat_operations.c,
src/dosfs/fat_fat_operations.h, src/dosfs/fat_file.c,
src/dosfs/msdos_dir.c, src/dosfs/msdos_eval.c, src/dosfs/msdos_file.c,
src/dosfs/msdos_free.c, src/dosfs/msdos_fsunmount.c,
src/dosfs/msdos_handlers_dir.c, src/dosfs/msdos_handlers_file.c,
src/dosfs/msdos_init.c, src/dosfs/msdos_initsupp.c,
src/dosfs/msdos_misc.c, src/dosfs/msdos_mknod.c,
src/dosfs/msdos_node_type.c, src/dosfs/.cvsignore: New files.
* configure.ac, src/Makefile.am, wrapup/Makefile.am: Modified to
reflect addition.
