Closes #2442.
closes #2447.
updates #2453.
This avoids conflicting machine options for compile only tests.
* boards/rtems-microblaze-nosim.exp, boards/rtems-sparc64-nosim.exp:
New files.
* boards/rtems-lm32-lm32_evr.exp: Correct cpu flags.
* boards/rtems-m68k-uC5282.exp: Link differently so the right multilib is used.
* boards/rtems-avr-avrtest.exp, boards/rtems-h8300-h8sim.exp,
boards/rtems-i386-qemu.exp, boards/rtems-lm32-lm32_evr.exp,
boards/rtems-m32c-m32csim.exp, boards/rtems-m32r-m32rsim.exp,
boards/rtems-m68k-uC5282.exp, boards/rtems-mips-jmr3904.exp,
boards/rtems-powerpc-psim.exp, boards/rtems-powerpc-qemuppc.exp,
boards/rtems-sh-simsh1.exp, boards/rtems-sparc-sis.exp: Add -i
argument to invocation of simulator.
* boards/rtems-lm32-lm32_evr.exp: New file.
* boards/rtems-m68k-uC5282.exp: Correct name of simulator.
* boards/rtems-arm-edb7312.exp: Add -i option.
* boards/rtems-m68k-uC5282.exp: New file. Add uC5282 support.
* boards/rtems-i386-qemu.exp: Rename most qemu scripts to match the BSP
name. qemu-leon2 not renamed since we prefer tsim for it.
* ChangeLog, boards/rtems-arm-edb7312.exp, boards/rtems-arm-nosim.exp,
boards/rtems-avr-avrtest.exp, boards/rtems-avr-nosim.exp,
boards/rtems-bfin-nosim.exp, boards/rtems-h8300-h8sim.exp,
boards/rtems-i386-qemu.exp, boards/rtems-m32c-m32csim.exp,
boards/rtems-m32r-m32rsim.exp, boards/rtems-m68k-nosim.exp,
boards/rtems-mips-jmr3904.exp, boards/rtems-powerpc-psim.exp,
boards/rtems-sh-simsh1.exp, boards/rtems-sparc-sis.exp: Correct
invocation of common simulator scripts.
* boards/rtems-arm-edb7312.exp, boards/rtems-arm-nosim.exp,
sim,options
* boards/rtems-mips-jmr3904.exp: Fix typo.
* ChangeLog: New file.
* dejagnu/boards/rtems-arm-edb7312.exp,
dejagnu/boards/rtems-arm-nosim.exp,
dejagnu/boards/rtems-avr-avrtest.exp,
dejagnu/boards/rtems-avr-nosim.exp,
dejagnu/boards/rtems-bfin-nosim.exp,
dejagnu/boards/rtems-h8300-h8sim.exp,
dejagnu/boards/rtems-i386-qemu.exp,
dejagnu/boards/rtems-m32c-m32csim.exp,
dejagnu/boards/rtems-m32r-m32rsim.exp,
dejagnu/boards/rtems-m68k-nosim.exp,
dejagnu/boards/rtems-mips-jmr3904.exp,
dejagnu/boards/rtems-powerpc-psim.exp,
dejagnu/boards/rtems-sh-simsh1.exp,
dejagnu/boards/rtems-sparc-sis.exp: Recent changes require more
variables to be included in board cflags and ldflags.
* gcc/do_one, gcc/test_driver: Start at least building toolsets even if
we cannot run tests on them yet.
* dejagnu/boards/rtems-avr-nosim.exp: New file.
* dejagnu/boards/rtems-i386-qemu.exp,
gcc/testsuite/ada/acats/Makefile.rtems: Switch to using qemu script
from this tree.
dejagnu/boards/rtems-sparc-sis.exp,
gcc/testsuite/ada/acats/Makefile.rtems: Eliminate version specific
file names.
* test_driver: Incorporate do_cpus so it is no longer needed
* dejagnu/boards/rtems-m32r-m32rsim.exp: New file.
* do_one: Build RTEMS multilib so Ada builds.
* dejagnu/boards/rtems-powerpc-psim.exp: add -l 180.
* dejagnu/boards/rtems-avr-avrtest.exp: New file.
