2017-11-10 | dhcpcd: Don't ignore interface on transient errors. | Christian Mauderer | |
In case of WPA on a WiFi interface, the interface isn't yet ready when the dhcpcd starts. Sending a packet during that time returns with a ENOBUFS. That caused the interface to be ignored. On the upstream repository of dhcpcd, that transient error (and some others) are already ignored. | |||
2017-10-20 | dhcpcd: Honour file descriptor maximum | Sebastian Huber | |
2016-05-30 | Directly use <sys/time.h> provided by Newlib | Sebastian Huber | |
2014-01-30 | DHCPCD(8): Add MASTER_ONLY option | Sebastian Huber | |
2014-01-30 | DHCPCD(8): Disable script support | Sebastian Huber | |
2014-01-30 | DHCPCD(8): Add getopt_long_r() support | Sebastian Huber | |
2014-01-30 | DHCPCD(8): Add RTEMS program support | Sebastian Huber | |
2014-01-30 | DHCPCD(8): Use select() instead of pselect() | Sebastian Huber | |
2014-01-30 | DHCPCD(8): Add config.h | Sebastian Huber | |
2014-01-30 | DHCPCD(8): Add namespace header | Sebastian Huber | |
2014-01-30 | DHCPCD(8): Add automatically generated files | Sebastian Huber | |
2014-01-30 | DHCPCD(8): Import | Sebastian Huber | |
Import DHCPCD(8) from: http://roy.marples.name/projects/dhcpcd/ The upstream sources can be obtained via: fossil clone http://roy.marples.name/projects/dhcpcd The imported version is 2014-01-29 19:46:44 [6b209507bb]. |
