This adds a vprintf handler that can be used to suppress all outputs of
the libbsd.
Some applications (like the civetweb web server) still use functions
that are deprecated by openssl. If OPENSSL_NO_DEPRECATED is defined,
openssl will not provide these functions. This patch removes the define
so that the functions are available.
Using panic() with interrupts disabled could lead to an additional error
(INTERNAL_ERROR_BAD_THREAD_DISPATCH_ENVIRONMENT) due to a potentially
blocking output.
In case no "dr_mode" property is present in the device tree, then
default to USB host mode. This is necessary to support the Cyclone V
SoC Development Kit.
Support device tree of Cyclone V SoC Development Kit.
Close #3290.
Update #3264.
Update #2843.
The issue is this:
static int dpaa_eth_macless_probe(struct platform_device *_of_dev)
INIT_LIST_HEAD(&priv->dpa_fq_list);
err = dpa_fq_probe_macless(dev, &priv->dpa_fq_list, RX);
if (!err)
TX);
if (err < 0)
goto fq_probe_failed;
/* Add the FQs to the interface, and make them active */
/* For MAC-less devices we only get here for RX frame queues
* initialization, which are the TX queues of the other
* partition.
* It is safe to rely on one partition to set the FQ taildrop
* threshold for the TX queues of the other partition
* because the ERN notifications will be received by the
* partition doing qman_enqueue.
err = dpa_fqs_init(dev, &priv->dpa_fq_list, true);
if (err < 0)
goto fq_alloc_failed;
The priv->dpa_fq_list contains a list of FQ_TYPE_RX_PCD and FQ_TYPE_TX
items. I don't understand what the "For MAC-less devices we only get
here for RX frame queues initialization" means in this context. The
td_enable == true in dpa_fqs_init(). So, we have:
int dpa_fq_init(struct dpa_fq *dpa_fq, bool td_enable)
if (dpa_fq->fq_type == FQ_TYPE_TX ||
dpa_fq->fq_type == FQ_TYPE_TX_CONFIRM ||
dpa_fq->fq_type == FQ_TYPE_TX_CONF_MQ) {
initfq.we_mask |= QM_INITFQ_WE_OAC;
if (td_enable) {
initfq.we_mask |= QM_INITFQ_WE_TDTHRESH;
qm_fqd_taildrop_set(&initfq.fqd.td,
DPA_FQ_TD, 1);
initfq.fqd.fq_ctrl = QM_FQCTRL_TDE;
The td_enable == true && dpa_fq->fq_type == FQ_TYPE_TX causes later:
int qman_init_fq(struct qman_fq *fq, u32 flags, struct qm_mcc_initfq *opts)
if (opts && (opts->we_mask & QM_INITFQ_WE_OAC)) {
/* And can't be set at the same time as TDTHRESH */
if (opts->we_mask & QM_INITFQ_WE_TDTHRESH)
return -EINVAL;
This aborts the initialization of the MAC-less driver. I don't
understand why this path doesn't happen on the SDK Linux system.
Update #3277.
Update #3277.
http://git.freescale.com/git/cgit.cgi/ppc/sdk/linux.git
Commit 1ae843c08261402b2c35d83422e4fa1e313611f4 (fsl-sdk-v2.0-1703).
Update #3277.
Update #3277.
Update #3277.
Update #3277.
Update #3277.
Update #3277.
Update #3277.
Update #3277.
Determine interrupt cells via device tree.
Update #3277.
Translate address in of_address_to_resource().
Update #3277.
Update #3277.
Update #3277.
Update #3277.
Update #3277.
Update #3277.
Update #3277.
Update #3277.
Update #3277.
This was accidentally committed.
This reverts commit 97a98f6cd767b3a68279890488c7b451788f84f4.
This reverts commit cc7a8d87e7307db738bf39ab1ca3ce1053f1c163.
Update #3132.
