This avoids a dependency on the non-standard libxml2 module.
brains GmbH.
Updates #3053.
+ include
+ tmck
+ tmfine01
+ tmonetoone
+ tmtimer01
Updates #3053.
Updates #3053.
Updates #4625.
#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
Update #3382
Update #3170.
Update #3199.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
call to printk.
Updates #3170.
Use a red-black tree instead of delta chains.
Close #2344.
Update #2554.
Update #2555.
Close #2606.
Test run performed on T4240 running at 1667MHz in uni-processor
configuration.
Update #2554.
