path: root/cpukit/score/src/watchdogremove.c (follow)
* Update company nameSebastian Huber2023-05-201-1/+1
| | | | | The embedded brains GmbH & Co. KG is the legal successor of embedded brains GmbH.
* cpukit/: Scripted embedded brains header file clean upJoel Sherrill2022-03-101-6/+0
| | | | Updates #4625.
* score/src/[t-z]*.c: Change license to BSD-2Joel Sherrill2022-02-281-3/+22
| | | | Updates #3053.
* score: Canonicalize Doxygen @file commentsSebastian Huber2020-12-021-1/+2
| | | | | | Use common phrases for the file brief descriptions. Update #3706.
* doxygen: Switch @brief and @ingroupSebastian Huber2020-04-281-1/+2
| | | | This order change fixes the Latex documentation build via Doxygen.
* doxygen: Rename Score* groups in RTEMSScore*Sebastian Huber2019-04-041-1/+1
| | | | Update #3706
* score: Replace watchdog handler implementationSebastian Huber2016-03-041-155/+17
| | | | | | | | | Use a red-black tree instead of delta chains. Close #2344. Update #2554. Update #2555. Close #2606.
* score: Fix watchdog removalSebastian Huber2015-12-211-1/+10
| | | | | | | | | Under certain conditions a new watchdog was inserted with a wrong and very large delta interval due to an incomplete iterator update. Bug was introduced by 1ccbd052910ed16131c74b0d5595c8a94066942d. Close #2501.
* score: Delete unused state WATCHDOG_REMOVE_ITSebastian Huber2015-06-131-5/+1
* score: Move _Watchdog_Tickle()Sebastian Huber2015-05-191-1/+66
| | | | | | | Make internal function _Watchdog_Remove_it() static to avoid accidental usage. Update #2307.
* score: Add Watchdog_IteratorSebastian Huber2015-05-191-15/+56
| | | | | | | | | | Rewrite the _Watchdog_Insert(), _Watchdog_Remove() and _Watchdog_Tickle() functions to use iterator items to synchronize concurrent operations. This makes it possible to get rid of the global variables _Watchdog_Sync_level and _Watchdog_Sync_count which are a blocking point for scalable SMP solutions. Update #2307.
* score: Add _Watchdog_Acquire|Release|Flash()Sebastian Huber2015-05-191-3/+3
| | | | Update #2307.
* score: Add header to _Watchdog_Remove()Sebastian Huber2015-05-191-0/+1
| | | | | | | | Add watchdog header parameter to _Watchdog_Remove() to be in line with the other operations. Add _Watchdog_Remove_ticks() and _Watchdog_Remove_seconds() for convenience. Update #2307.
* score: Create watchdog implementation headerSebastian Huber2013-07-221-1/+1
| | | | | | Move implementation specific parts of watchdog.h and watchdog.inl into new header file watchdogimpl.h. The watchdog.h contains now only the application visible API.
* score misc: Clean up Doxygen (GCI 2012)Alex Ivanov2012-11-281-10/+7
| | | | | | This patch is a task from GCI 2012 which improves the Doxygen comments in the RTEMS source. https://google-melange.appspot.com/gci/task/view/google/gci2012/7978208
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * ftpd/ftpd.c, libcsupport/src/geteuid.c, libcsupport/src/getgroups.c, libcsupport/src/getpgrp.c, libcsupport/src/getpid.c, libcsupport/src/getppid.c, libcsupport/src/setpgid.c, libcsupport/src/setsid.c, libcsupport/src/utsname.c, libmisc/stackchk/check.c, posix/include/rtems/posix/mqueue.h, posix/inline/rtems/posix/cond.inl, posix/inline/rtems/posix/mqueue.inl, posix/inline/rtems/posix/mutex.inl, posix/inline/rtems/posix/pthread.inl, posix/inline/rtems/posix/semaphore.inl, posix/inline/rtems/posix/timer.inl, posix/src/alarm.c, posix/src/barrierattrdestroy.c, posix/src/barrierattrgetpshared.c, posix/src/barrierattrinit.c, posix/src/barrierattrsetpshared.c, posix/src/cleanuppop.c, posix/src/cleanuppush.c, posix/src/clockgetcpuclockid.c, posix/src/clockgetenableattr.c, posix/src/clockgetres.c, posix/src/clockgettime.c, posix/src/clocksetenableattr.c, posix/src/clocksettime.c, posix/src/cond.c, posix/src/condattrdestroy.c, posix/src/condattrgetpshared.c, posix/src/condattrinit.c, posix/src/condattrsetpshared.c, posix/src/condbroadcast.c, posix/src/conddefaultattributes.c, posix/src/conddestroy.c, posix/src/condinit.c, posix/src/condsignal.c, posix/src/condsignalsupp.c, posix/src/condtimedwait.c, posix/src/condwait.c, posix/src/condwaitsupp.c, posix/src/keygetspecific.c, posix/src/keyrundestructors.c, posix/src/keysetspecific.c, posix/src/mprotect.c, posix/src/mqueue.c, posix/src/mqueuecreatesupp.c, posix/src/mqueuedeletesupp.c, posix/src/mqueuegetattr.c, posix/src/mqueuenotify.c, posix/src/mqueuereceive.c, posix/src/mqueuesend.c, posix/src/mqueuesendsupp.c, posix/src/mqueuesetattr.c, posix/src/mqueuetimedreceive.c, posix/src/mqueuetimedsend.c, posix/src/mqueuetranslatereturncode.c, posix/src/mqueueunlink.c, posix/src/mutex.c, posix/src/mutexattrdestroy.c, posix/src/mutexattrgetprioceiling.c, posix/src/mutexattrgetprotocol.c, posix/src/mutexattrgetpshared.c, posix/src/mutexattrinit.c, posix/src/mutexattrsetprioceiling.c, posix/src/mutexattrsetprotocol.c, posix/src/mutexattrsetpshared.c, posix/src/mutexdestroy.c, posix/src/mutexgetprioceiling.c, posix/src/mutexinit.c, posix/src/mutexlock.c, posix/src/mutexlocksupp.c, posix/src/mutexsetprioceiling.c, posix/src/mutextimedlock.c, posix/src/mutextrylock.c, posix/src/mutexunlock.c, posix/src/nanosleep.c, posix/src/psignal.c, posix/src/psignalchecksignal.c, posix/src/psignalclearprocesssignals.c, posix/src/psignalclearsignals.c, posix/src/psignalsetprocesssignals.c, posix/src/psignalunblockthread.c, posix/src/pthreadinitthreads.c, posix/src/rwlockattrdestroy.c, posix/src/rwlockattrgetpshared.c, posix/src/rwlockattrinit.c, posix/src/rwlockattrsetpshared.c, posix/src/semaphore.c, posix/src/semaphoredeletesupp.c, posix/src/semaphorenametoid.c, posix/src/semaphorewaitsupp.c, posix/src/semclose.c, posix/src/semdestroy.c, posix/src/semgetvalue.c, posix/src/seminit.c, posix/src/semopen.c, posix/src/sempost.c, posix/src/semtimedwait.c, posix/src/semtrywait.c, posix/src/semunlink.c, posix/src/semwait.c, posix/src/sysconf.c, posix/src/testcancel.c, posix/src/ualarm.c, rtems/src/clockgetuptime.c, rtems/src/clockset.c, rtems/src/clocksetnsecshandler.c, rtems/src/clocktick.c, rtems/src/clocktodtoseconds.c, rtems/src/clocktodvalidate.c, rtems/src/dpmem.c, rtems/src/dpmemcreate.c, rtems/src/dpmemdelete.c, rtems/src/dpmemexternal2internal.c, rtems/src/dpmemident.c, rtems/src/dpmeminternal2external.c, rtems/src/event.c, rtems/src/eventmp.c, rtems/src/eventreceive.c, rtems/src/eventseize.c, rtems/src/eventsend.c, rtems/src/eventsurrender.c, rtems/src/eventtimeout.c, rtems/src/mp.c, rtems/src/msg.c, rtems/src/msgmp.c, rtems/src/msgqallocate.c, rtems/src/msgqbroadcast.c, rtems/src/msgqcreate.c, rtems/src/msgqdelete.c, rtems/src/msgqflush.c, rtems/src/msgqgetnumberpending.c, rtems/src/msgqident.c, rtems/src/msgqreceive.c, rtems/src/msgqtranslatereturncode.c, rtems/src/msgqurgent.c, rtems/src/part.c, rtems/src/partcreate.c, rtems/src/partdelete.c, rtems/src/partgetbuffer.c, rtems/src/partident.c, rtems/src/partmp.c, rtems/src/partreturnbuffer.c, rtems/src/ratemon.c, rtems/src/ratemoncancel.c, rtems/src/ratemoncreate.c, rtems/src/ratemondelete.c, rtems/src/ratemongetstatistics.c, rtems/src/ratemongetstatus.c, rtems/src/ratemonident.c, rtems/src/ratemonperiod.c, rtems/src/ratemonresetstatistics.c, rtems/src/ratemontimeout.c, rtems/src/region.c, rtems/src/regioncreate.c, rtems/src/regiondelete.c, rtems/src/regionextend.c, rtems/src/regiongetfreeinfo.c, rtems/src/regiongetinfo.c, rtems/src/regiongetsegment.c, rtems/src/regiongetsegmentsize.c, rtems/src/regionident.c, rtems/src/regionmp.c, rtems/src/regionprocessqueue.c, rtems/src/regionresizesegment.c, rtems/src/regionreturnsegment.c, rtems/src/rtemsobjectgetclassicname.c, rtems/src/rtemstimer.c, rtems/src/sem.c, rtems/src/semcreate.c, rtems/src/semdelete.c, rtems/src/semflush.c, rtems/src/semident.c, rtems/src/semmp.c, rtems/src/semobtain.c, rtems/src/semrelease.c, rtems/src/semtranslatereturncode.c, rtems/src/signal.c, rtems/src/signalcatch.c, rtems/src/signalmp.c, rtems/src/signalsend.c, rtems/src/taskcreate.c, rtems/src/taskdelete.c, rtems/src/taskgetnote.c, rtems/src/taskident.c, rtems/src/taskinitusers.c, rtems/src/taskissuspended.c, rtems/src/taskmp.c, rtems/src/taskrestart.c, rtems/src/taskresume.c, rtems/src/tasks.c, rtems/src/tasksetnote.c, rtems/src/tasksetpriority.c, rtems/src/taskstart.c, rtems/src/tasksuspend.c, rtems/src/taskwakeafter.c, rtems/src/taskwakewhen.c, rtems/src/timercancel.c, rtems/src/timercreate.c, rtems/src/timerdelete.c, rtems/src/timerfireafter.c, rtems/src/timerfirewhen.c, rtems/src/timergetinfo.c, rtems/src/timerident.c, rtems/src/timerreset.c, rtems/src/timerserverfireafter.c, rtems/src/timerserverfirewhen.c, sapi/src/debug.c, sapi/src/extension.c, sapi/src/posixapi.c, sapi/src/rtemsapi.c, score/src/apiext.c, score/src/chain.c, score/src/corebarrier.c, score/src/corebarrierrelease.c, score/src/corebarrierwait.c, score/src/coremsgbroadcast.c, score/src/coremsgclose.c, score/src/coremsgflush.c, score/src/coremsgflushsupp.c, score/src/coremsgflushwait.c, score/src/coremsginsert.c, score/src/coremsgseize.c, score/src/coremsgsubmit.c, score/src/coremutex.c, score/src/coremutexflush.c, score/src/coremutexseize.c, score/src/corerwlock.c, score/src/corerwlockobtainread.c, score/src/corerwlockobtainwrite.c, score/src/corerwlockrelease.c, score/src/coresem.c, score/src/coresemflush.c, score/src/coresemsurrender.c, score/src/corespinlock.c, score/src/corespinlockrelease.c, score/src/corespinlockwait.c, score/src/coretod.c, score/src/coretodset.c, score/src/coretodtickle.c, score/src/heap.c, score/src/interr.c, score/src/mpci.c, score/src/objectallocate.c, score/src/objectextendinformation.c, score/src/objectfree.c, score/src/objectget.c, score/src/objectgetisr.c, score/src/objectgetnext.c, score/src/objectgetnoprotection.c, score/src/objectinitializeinformation.c, score/src/objectmp.c, score/src/objectnametoid.c, score/src/objectnametoidstring.c, score/src/objectshrinkinformation.c, score/src/rbtree.c, score/src/threaddelayended.c, score/src/threadhandler.c, score/src/threadinitialize.c, score/src/threadloadenv.c, score/src/threadmp.c, score/src/threadq.c, score/src/threadqdequeue.c, score/src/threadqdequeuefifo.c, score/src/threadqdequeuepriority.c, score/src/threadqenqueue.c, score/src/threadqenqueuefifo.c, score/src/threadqenqueuepriority.c, score/src/threadqextract.c, score/src/threadqextractfifo.c, score/src/threadqextractpriority.c, score/src/threadqextractwithproxy.c, score/src/threadqfirst.c, score/src/threadqfirstfifo.c, score/src/threadqfirstpriority.c, score/src/threadqflush.c, score/src/threadqrequeue.c, score/src/threadstackallocate.c, score/src/threadstartmultitasking.c, score/src/watchdog.c, score/src/watchdogadjust.c, score/src/watchdoginsert.c, score/src/watchdogremove.c, score/src/watchdogtickle.c: Remove /*PAGE markers which were interpreted by a long dead print script.
* Include config.h.Ralf Corsepius2005-01-271-0/+4
* Remove stray white spaces.Ralf Corsepius2004-04-181-1/+1
* Remove stray white spaces.Ralf Corsepius2004-04-171-1/+1
* Remove stray white spaces.Ralf Corsepius2004-04-151-1/+0
* 2003-09-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-041-1/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * include/rtems/debug.h, include/rtems/seterr.h, include/rtems/system.h, include/rtems/score/address.h, include/rtems/score/apiext.h, include/rtems/score/apimutex.h, include/rtems/score/bitfield.h, include/rtems/score/chain.h, include/rtems/score/context.h, include/rtems/score/copyrt.h, include/rtems/score/coremsg.h, include/rtems/score/coremutex.h, include/rtems/score/coresem.h, include/rtems/score/heap.h, include/rtems/score/interr.h, include/rtems/score/isr.h, include/rtems/score/mpci.h, include/rtems/score/mppkt.h, include/rtems/score/object.h, include/rtems/score/objectmp.h, include/rtems/score/priority.h, include/rtems/score/stack.h, include/rtems/score/states.h, include/rtems/score/sysstate.h, include/rtems/score/thread.h, include/rtems/score/threadmp.h, include/rtems/score/threadq.h, include/rtems/score/tod.h, include/rtems/score/tqdata.h, include/rtems/score/userext.h, include/rtems/score/watchdog.h, include/rtems/score/wkspace.h, inline/rtems/score/address.inl, inline/rtems/score/chain.inl, inline/rtems/score/coremsg.inl, inline/rtems/score/coremutex.inl, inline/rtems/score/coresem.inl, inline/rtems/score/heap.inl, inline/rtems/score/isr.inl, inline/rtems/score/mppkt.inl, inline/rtems/score/object.inl, inline/rtems/score/objectmp.inl, inline/rtems/score/priority.inl, inline/rtems/score/stack.inl, inline/rtems/score/states.inl, inline/rtems/score/sysstate.inl, inline/rtems/score/thread.inl, inline/rtems/score/threadmp.inl, inline/rtems/score/tod.inl, inline/rtems/score/tqdata.inl, inline/rtems/score/userext.inl, inline/rtems/score/watchdog.inl, inline/rtems/score/wkspace.inl, macros/rtems/score/address.inl, macros/rtems/score/chain.inl, macros/rtems/score/coremsg.inl, macros/rtems/score/coremutex.inl, macros/rtems/score/coresem.inl, macros/rtems/score/heap.inl, macros/rtems/score/isr.inl, macros/rtems/score/mppkt.inl, macros/rtems/score/object.inl, macros/rtems/score/objectmp.inl, macros/rtems/score/priority.inl, macros/rtems/score/stack.inl, macros/rtems/score/states.inl, macros/rtems/score/sysstate.inl, macros/rtems/score/thread.inl, macros/rtems/score/threadmp.inl, macros/rtems/score/tod.inl, macros/rtems/score/tqdata.inl, macros/rtems/score/userext.inl, macros/rtems/score/watchdog.inl, macros/rtems/score/wkspace.inl, src/apiext.c, src/chain.c, src/coremsg.c, src/coremsgbroadcast.c, src/coremsgclose.c, src/coremsgflush.c, src/coremsgflushsupp.c, src/coremsgflushwait.c, src/coremsginsert.c, src/coremsgseize.c, src/coremsgsubmit.c, src/coremutex.c, src/coremutexflush.c, src/coremutexseize.c, src/coremutexsurrender.c, src/coresem.c, src/coresemflush.c, src/coresemseize.c, src/coresemsurrender.c, src/coretod.c, src/coretodset.c, src/coretodtickle.c, src/coretodtoseconds.c, src/coretodvalidate.c, src/heap.c, src/heapallocate.c, src/heapextend.c, src/heapfree.c, src/heapgetinfo.c, src/heapsizeofuserarea.c, src/heapwalk.c, src/interr.c, src/isr.c, src/iterateoverthreads.c, src/mpci.c, src/object.c, src/objectallocate.c, src/objectallocatebyindex.c, src/objectclearname.c, src/objectcomparenameraw.c, src/objectcomparenamestring.c, src/objectcopynameraw.c, src/objectcopynamestring.c, src/objectextendinformation.c, src/objectfree.c, src/objectget.c, src/objectgetbyindex.c, src/objectgetisr.c, src/objectgetnext.c, src/objectgetnoprotection.c, src/objectidtoname.c, src/objectinitializeinformation.c, src/objectmp.c, src/objectnametoid.c, src/objectshrinkinformation.c, src/thread.c, src/threadchangepriority.c, src/threadclearstate.c, src/threadclose.c, src/threadcreateidle.c, src/threaddelayended.c, src/threaddispatch.c, src/threadevaluatemode.c, src/threadget.c, src/threadhandler.c, src/threadidlebody.c, src/threadinitialize.c, src/threadloadenv.c, src/threadmp.c, src/threadq.c, src/threadqdequeue.c, src/threadqdequeuefifo.c, src/threadqdequeuepriority.c, src/threadqenqueue.c, src/threadqenqueuefifo.c, src/threadqenqueuepriority.c, src/threadqextract.c, src/threadqextractfifo.c, src/threadqextractpriority.c, src/threadqextractwithproxy.c, src/threadqfirst.c, src/threadqfirstfifo.c, src/threadqfirstpriority.c, src/threadqflush.c, src/threadqtimeout.c, src/threadready.c, src/threadreset.c, src/threadresettimeslice.c, src/threadrestart.c, src/threadresume.c, src/threadrotatequeue.c, src/threadsetpriority.c, src/threadsetstate.c, src/threadsettransient.c, src/threadstackallocate.c, src/threadstackfree.c, src/threadstart.c, src/threadstartmultitasking.c, src/threadsuspend.c, src/threadtickletimeslice.c, src/threadyieldprocessor.c, src/userext.c, src/watchdog.c, src/watchdogadjust.c, src/watchdoginsert.c, src/watchdogremove.c, src/watchdogtickle.c, src/wkspace.c: URL for license changed.
* Split core message queue and watchdog handler objects into separate files.Joel Sherrill1999-11-021-0/+71
