brains GmbH.
The previous SMP multitasking start assumed that the initial heir thread of a
processor starts execution in _Thread_Handler(). The _Thread_Handler() sets
the interrupt state explicitly by _ISR_Set_level() before it calls the thread
entry. Under certain timing conditions, processors may perform an initial
context switch to a thread which already executes its thread body (see
smptests/smpstart01). In this case, interrupts are disabled after the context
switch on targets which do not save/restore the interrupt state during a
context switch (aarch64, arm, and riscv).
Close #4627.
Updates #3053.
The __builtin_unreachable() cannot be used with current GCC versions to
tell the compiler that a function does not return to the caller, see:
https://gcc.gnu.org/bugzilla/show_bug.cgi?id=99151
Add a no return variant of _CPU_Context_switch() to avoid generation of
dead code in _Thread_Start_multitasking() if RTEMS was built with SMP
support enabled.
Update #3706.
Update #3706.
There is no need to save the thread pointer in _CPU_Context_switch()
since it is a thread invariant. It is initialized once in
_CPU_Context_Initialize().
Set CPU_ENABLE_ROBUST_THREAD_DISPATCH to TRUE. In this case the
interrupts are always enabled during a context switch even after
interrupt processing (see #2751). Remove the CPSR from the context
control since it contains only volatile bits.
Close #2954.
Update #2751.
Use a processor-specific interrupt frame during context switches in case
the executing thread is longer executes on the processor and the heir
thread is about to start execution. During this period we must not use
a thread stack for interrupt processing.
Update #2809.
Use the previously unused TPIDRPRW register to get the per-CPU control
of the current processor. This avoids instructions in
GET_SELF_CPU_CONTROL which are not available in Thumb mode.
According to the C11 and C++11 memory models only a read-modify-write
operation guarantees that we read the last value written in modification
order. Avoid the sequential consistent thread fence and instead use the
inter-processor interrupt to set the thread dispatch necessary
indicator.
This floating point unit is available in Cortex-M4 processors and
defined by ARMv7-M. This adds basic support for other VFP-D16 variants.
Fix context switch on SMP for ARM, PowerPC and SPARC.
Atomically test and set the is executing indicator of the heir context
to ensure that at most one processor uses the heir context. Break the
busy wait loop also due to heir updates.
We must not alter the is executing indicator in
_CPU_Context_Initialize() since this would cause an invalid state during
a self restart.
The is executing indicator must be valid at creation time since
otherwise _Thread_Kill_zombies() uses an undefined value for not started
threads. This could result in a system life lock.
The current implementation of task migration in RTEMS has some
implications with respect to the interrupt latency. It is crucial to
preserve the system invariant that a task can execute on at most one
processor in the system at a time. This is accomplished with a boolean
indicator in the task context. The processor architecture specific
low-level task context switch code will mark that a task context is no
longer executing and waits that the heir context stopped execution
before it restores the heir context and resumes execution of the heir
task. So there is one point in time in which a processor is without a
task. This is essential to avoid cyclic dependencies in case multiple
tasks migrate at once. Otherwise some supervising entity is necessary to
prevent life-locks. Such a global supervisor would lead to scalability
problems so this approach is not used. Currently the thread dispatch is
performed with interrupts disabled. So in case the heir task is
currently executing on another processor then this prolongs the time of
disabled interrupts since one processor has to wait for another
processor to make progress.
It is difficult to avoid this issue with the interrupt latency since
interrupts normally store the context of the interrupted task on its
stack. In case a task is marked as not executing we must not use its
task stack to store such an interrupt context. We cannot use the heir
stack before it stopped execution on another processor. So if we enable
interrupts during this transition we have to provide an alternative task
independent stack for this time frame. This issue needs further
investigation.
Tested and implemented on ARM, m68k, PowerPC and SPARC. Other
architectures need more work.
Recent GCC versions use atomic operations based on load/store exclusive
in the C++ library.
The GNU assembler translates for example a
msr spsr, rN
into
msr SPSR_fc, rN
This would update only a subset of the register and leads to an
incomplete exceptions restore sequence resulting in system corruption.
Correct is this:
msr SPSR_fsxc, rN
* rtems/score/armv7m.h, armv7m-context-initialize.c,
armv7m-context-restore.c, armv7m-context-switch.c,
armv7m-exception-handler-get.c, armv7m-exception-handler-set.c,
armv7m-exception-priority-get.c, armv7m-exception-priority-set.c,
armv7m-initialize.c, armv7m-isr-dispatch.c, armv7m-isr-enter-leave.c,
armv7m-isr-level-get.c, armv7m-isr-level-set.c,
armv7m-isr-vector-install.c, armv7m-multitasking-start-stop.c: New
files.
* Makefile.am, preinstall.am: Reflect changes above.
* rtems/score/arm.h: Define ARM_MULTILIB_ARCH_V4 and
ARM_MULTILIB_ARCH_V7M.
* rtems/score/cpu.h, cpu_asm.S, cpu.c, arm_exc_abort.S,
arm_exc_handler_high.c, arm_exc_handler_low.S, arm_exc_interrupt.S:
Define CPU_HAS_HARDWARE_INTERRUPT_STACK to FALSE. Use
ARM_MULTILIB_ARCH_V4 and ARM_MULTILIB_ARCH_V7M.
* arm_exc_abort.S, arm_exc_handler_high.c, arm_exc_handler_low.S,
arm_exc_interrupt.S, cpu.c, cpu_asm.S: Add include of config.h
* rtems/asm.h: Added macro to define ARM functions.
* cpu_asm.S, arm_exc_handler_low.S: Use macro from above.
* cpu.c, score/cpu.h: Fix headers. Remove extra inline definition.
* cpu_asm.S: Note origin of Thumb support.
* cpu.c, cpu_asm.S, score/cpu.h : add support for ARM<->THUMB veneer
thumb new dir to controll CPSR/SPRS in thumb mode
2007-05-09 Ray Xu <rayx.cn@gmail.com>
* cpu.c: move do_data_abort() to libbsp/arm/shared/abort/
implement a compact do_data_abort() in simple_abort.c
* cpu.c, cpu_asm.S: Fixed ARM Data Abort handling.
* cpu_asm.S: Include <rtems/asm.h> instead of <asm.h>.
* asm.h, cpu.c, cpu_asm.S, rtems/score/arm.h, rtems/score/cpu.h,
rtems/score/cpu_asm.h, rtems/score/types.h: URL for license changed.
* cpu.c, cpu_asm.S, rtems/score/arm.h, rtems/score/cpu.h,
rtems/score/cpu_asm.h, rtems/score/types.h: ARM port works
well enough to run all sptests, tmtests, and ttcp.
In addition to general cleanup, there has been considerable
optimization to interrupt disable/enable, endian swapping,
and context switching.
* rtems/score/cpu_asm.h: Enhanced to include register offsets.
* Makefile.am: Install rtems/score/cpu_asm.h.
* cpu.c: Significantly enhanced including the implementation of
_CPU_ISR_Get_level.
* cpu_asm.S: Improved behavior of context switch and interrupt
dispatching.
* rtems/score/arm.h: Improved the CPU model name determination.
* rtems/score/cpu.h: Improved interrupt disable/enable functions.
