line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
The RTEMS_BLKIO_SETBLKSIZE IO control expects an uint32_t parameter and
not a size_t which is 64-bits on 64-bit targets.
Update #3082.
Closes #2139
The output of the modules.html is much improved. Most
filesystem and POSIX API related groups are properly nested.
Some formatting issues were addressed as were multiple
inconsistencies.
http://www.google-melange.com/gci/task/view/google/gci2012/8120204
Patch committed with fixes for whitespace issues.
http://www.google-melange.com/gci/task/view/google/gci2012/8006220
* libfs/src/rfs/rtems-rfs-trace.c,
libfs/src/rfs/rtems-rfs-trace.h: Add inode-delete.
* libfs/src/rfs/rtems-rfs-shell.c: Fix formatting.
* libfs/src/rfs/rtems-rfs-rtems-dir.c: Use ssize_t. Fix spelling.
* libfs/src/rfs/rtems-rfs-block.c: Fix rtems_rfs_block_get_bpos to
return the position correctly. A bpos does not have any special
processing. Do no reset the buffer handle when shrinking
indirectly.
* libfs/src/rfs/rtems-rfs-inode.c: Add trace.
* libfs/src/rfs/rtems-rfs-format.c: Fix comments.
* libfs/src/rfs/rtems-rfs-group.c: Limit the inodes to the blocks
in a group so the accounting works.
* libfs/src/rfs/rtems-rfs-dir.c: PR 1705. Fix handling the offsets
when deleting an entry.
* libfs/src/rfs/rtems-rfs-buffer.h: Remove
rtems_rfs_buffer_handle_reset. It is not needed and dangerous.
PR 1556/cpukit
* libfs/src/rfs/rtems-rfs-bitmaps.h,
libfs/src/rfs/rtems-rfs-block-pos.h,
libfs/src/rfs/rtems-rfs-buffer.h,
libfs/src/rfs/rtems-rfs-file-system-fwd.h,
libfs/src/rfs/rtems-rfs-file-system.h,
libfs/src/rfs/rtems-rfs-file.h,
libfs/src/rfs/rtems-rfs-format.h,
libfs/src/rfs/rtems-rfs-group.h,
libfs/src/rfs/rtems-rfs-inode.h:
Rename "struct rtems_rfs_*_t" into "struct _rtems_rfs_*".
* libfs/src/rfs/rtems-rfs-buffer.h: Add `rtems_rfs_buffer_handle_reset'.
* libfs/src/rfs/rtems-rfs-bitmaps.c,
libfs/src/rfs/rtems-rfs-bitmaps-ut.c,
libfs/src/rfs/rtems-rfs-block.c, libfs/src/rfs/rtems-rfs-block.h,
libfs/src/rfs/rtems-rfs-buffer-bdbuf.c,
libfs/src/rfs/rtems-rfs-buffer.c,
libfs/src/rfs/rtems-rfs-buffer-devio.c,
libfs/src/rfs/rtems-rfs-buffer.h, libfs/src/rfs/rtems-rfs-data.h,
libfs/src/rfs/rtems-rfs-dir.c, libfs/src/rfs/rtems-rfs-dir.h,
libfs/src/rfs/rtems-rfs-dir-hash.c,
libfs/src/rfs/rtems-rfs-dir-hash.h,
libfs/src/rfs/rtems-rfs-file.c, libfs/src/rfs/rtems-rfs-file.h,
libfs/src/rfs/rtems-rfs-file-system.c,
libfs/src/rfs/rtems-rfs-format.c,
libfs/src/rfs/rtems-rfs-format.h, libfs/src/rfs/rtems-rfs-group.c,
libfs/src/rfs/rtems-rfs-group.h, libfs/src/rfs/rtems-rfs.h,
libfs/src/rfs/rtems-rfs-inode.c, libfs/src/rfs/rtems-rfs-inode.h,
libfs/src/rfs/rtems-rfs-link.c, libfs/src/rfs/rtems-rfs-link.h,
libfs/src/rfs/rtems-rfs-mutex.c, libfs/src/rfs/rtems-rfs-mutex.h,
libfs/src/rfs/rtems-rfs-rtems.c,
libfs/src/rfs/rtems-rfs-rtems-dev.c,
libfs/src/rfs/rtems-rfs-rtems-dir.c,
libfs/src/rfs/rtems-rfs-rtems-file.c,
libfs/src/rfs/rtems-rfs-rtems.h,
libfs/src/rfs/rtems-rfs-rtems-utils.c,
libfs/src/rfs/rtems-rfs-shell.c, libfs/src/rfs/rtems-rfs-shell.h,
libfs/src/rfs/rtems-rfs-trace.c, libfs/src/rfs/rtems-rfs-trace.h:
New.
* Makefile.am, preinstall.am, libfs/Makefile.am,
wrapup/Makefile.am: Updated with the RFS support.
* libfs/README: Updated after 10 years.
* libblock/src/flashdisk.c, libblock/src/nvdisk.c,
libblock/src/ramdisk-driver.c: Updated to the new error reporting
in libblock.
* libmisc/shell/main_ls.c, libmisc/shell/print-ls.c: Fix printing
the size in long mode.
* libnetworking/nfs/bootp_subr.c,
libnetworking/rtems/rtems_bootp.c,
libnetworking/rtems/rtems_bsdnet_internal.h: Return the BOOTP/DHCP
to the forever behaviour of 4.9 with the ability to call BOOTP and
control the process if required.
