line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Define ARM_CP15_TEXT_SECTION to BSP_START_TEXT_SECTION so that the
start code is in the right section.
Invalidate entire branch predictor array.
Enable SCU only on the boot processor.
Add arm_a9mpcore_start_enable_smp_in_auxiliary_control().
Add arm_a9mpcore_start_on_secondary_processor(). Rely on error checks
in _SMP_Start_multitasking_on_secondary_processor().
Move the RTEMS_SMP conditional compilation to the detection method of arm erratum 764369
Execute the SCU part of the workaround of arm erratum 764368 after the SCU was enabled.
Rename rtems_smp_process_interrupt() into
_SMP_Inter_processor_interrupt_handler(). Delete unused header file
<rtems/bspsmp.h>.
Rename rtems_smp_secondary_cpu_initialize() into
_SMP_Start_multitasking_on_secondary_processor(). Move declaration to
<rtems/score/smpimpl.h>.
Use the Global Timer for the Cortex-A9 MPCore clock driver instead of
the Private Timer. This enables a consistent nanoseconds since last
context switch value across all processors.
