brains GmbH.
In SMP configurations, check that we run on a configured processor. If not,
then there is not much that can be done since we do not have a stack available
for this processor. Just loop forever in this case. Do this in assemlby to
ensure that no stack memory is used.
Maybe this helps to ensure that the object is properly aligned.
Update #4658.
Disable the linker relaxation in start.S to work around an issue described
here:
https://mail.gnu.org/archive/html/bug-binutils/2021-03/msg00164.html
The real issue is probably in the linker command file or the linker itself.
Update #4658.
The Microchip PolarFire SoC support is implemented as a
riscv BSP variant to boot with any individual hart(cpu core)
or SMP based on the boot HARTID configurable and support
components are 4 CPU Cores (U54), Interrupt controller (PLIC),
Timer (CLINT), UART.
This is required for ISA 2.0 support, see chapter
"Zicsr", Control and Status Register (CSR) Instructions, Version 2.0
in
RISC-V Instruction Set Manual, Volume I: RISC-V User-Level ISA
Use a far jump to avoid errors like this:
relocation truncated to fit: R_RISCV_JAL against symbol `boot_card'
Update #3678.
