2020-11-15 | bsps/a53_*: Fix typo in qemu optionsHEADmaster | Vijay Kumar Banerjee | |
2020-10-15 | rtems-bsps-tiers.ini: Delete removed PowerPC BSPs | Joel Sherrill | |
2020-10-05 | tester: Prevent crash with json output | Kinsey Moore | |
This fixes an issue with json report output that causes a crash due to the incorrect object member being accessed for test-too-long. This also changes treatment of fatal errors to match how they are displayed in the tester log output and changes "fatal error" to "fatal-error" to better match the naming of all the other failure types. | |||
2020-10-05 | tester: Add a53_ilp32_qemu.ini | Kinsey Moore | |
2020-10-05 | tester: Add a53_lp64_qemu.ini | Kinsey Moore | |
2020-09-26 | rtemstoolkit/dwarf: Dump the DIE offset | Chris Johns | |
2020-09-26 | rtemstoolkit/configuration: Treat an empty variable as an empty list | Chris Johns | |
2020-09-26 | Move all python commands to use env python | Chris Johns | |
- If you host does not provide a python command consult the User manual for ways you can run the python commands. - Full package paths are being used to avoid namespace pollution and crosstalk. | |||
2020-09-18 | linkers: Update due to API changes | Sebastian Huber | |
2020-09-15 | linker/exeinfo: Optionally output full flags when listing object files | Chris Johns | |
- Start adding support to dump configuration tables | |||
2020-09-11 | linkers/exeinfo: Output TLS data | Chris Johns | |
Updates #4074 | |||
2020-09-11 | linker/rap: Ignore relocation records with no section | Chris Johns | |
Uodates #4096 | |||
2020-09-08 | tester: Add support for test-too-long | Chris Johns | |
- A test that loops generating output did not timeout. Monitor the the session time and set a maximum test period. | |||
2020-09-07 | tester: Fix the install with the new TFTP server | Chris Johns | |
2020-09-07 | tester: Fix TFTP server Python2 issues. | Chris Johns | |
- Add a --show-backtrace option to make it easier for users to get an exception backtrace if something goes wrong. - Fix the --packet-trace option so it actually decodes the packets | |||
2020-09-01 | tester: Change to a simpler TFTP server | Chris Johns | |
- Add a simpler TFTP to allow parallel test hardware - Remove the imported tftpy server Closes #4063 | |||
2020-07-23 | trace: Use c++14 instead of c++11 if possible | Christian Mauderer | |
llvm version 10 uses features from c++14 standard in the headers. With that, the record/record-main-lttng.cc doesn't build any more. This patch makes sure that c++14 is used if it is available. | |||
2020-07-03 | Remove support for epiphany target | Sebastian Huber | |
Update #3941. | |||
2020-06-30 | Change version to RTEMS 6 | Sebastian Huber | |
Update #4020. | |||
2020-06-17 | rtems-test: target_exe_filter fails when there is no filter | Chris Johns | |
Closes #4006 | |||
2020-05-05 | linkers/ld: Output all reloc records to the RAP file | Chris Johns | |
Updates #3969 | |||
2020-04-28 | Allow build with i686-w64-mingw32 | kaidoho | |
Closes #3630 | |||
2020-04-09 | rtems-tester: Add rv64imafdc_medany for QEMU | Hesham Almatary | |
2020-04-05 | bsps: Deletes erc32-run.ini | Cláudio Maia | |
2020-04-03 | tester: Add configuration pc-qemu.ini | Jan Sommer | |
2020-03-30 | rtemstoolkit/execute: Handle unicode input on python2 | Chris Johns | |
- Allow unicode as a type on python2. The unicode type is not present on python3 so make the support conditional. - Add some more diag prints to aid debugging. Closes #3964 | |||
2020-03-30 | tester/gdb: Add lock timing and remote fetching registers. | Chris Johns | |
- Add timing for the locks to aid performance profiling - Remove fetching registers as the MI parser is slow on pyton2 Updates #3864 | |||
2020-03-20 | gdbarmsim: Remove all variants | Joel Sherrill | |
Updates #3911. | |||
2020-03-19 | execute.py: fix long line | Gedare Bloom | |
2020-03-17 | record: Increase input buffer and alignment | Sebastian Huber | |
Update #3904. | |||
2020-03-17 | record: Add support for zlib compressed input | Sebastian Huber | |
Update #3904. | |||
2020-03-17 | record: Add zlib filter class | Sebastian Huber | |
Update #3904. | |||
2020-03-17 | record: Add support for base64 encoded input | Sebastian Huber | |
Update #3904. | |||
2020-03-17 | record: Add base64 filter class | Sebastian Huber | |
Update #3904. | |||
2020-03-17 | record: Add filter base class | Sebastian Huber | |
Update #3904. | |||
2020-03-17 | record: Add option to print config default values | Sebastian Huber | |
Update #3904. | |||
2020-03-17 | record: Add support for user defined event names | Sebastian Huber | |
2020-03-17 | record: Add INI file parser | Sebastian Huber | |
Import from: https://github.com/benhoyt/inih commit 351217124ddb3e3fe2b982248a04c672350bb0af Author: Stephan Lachnit <stephanlachnit@protonmail.com> Date: Sun Mar 1 07:31:28 2020 +0100 r48 release (#100) * Bump copyright to 2020 * Remove makefile for static library * meson: version 48 Signed-off-by: Stephan Lachnit <stephanlachnit@protonmail.com> Update #3904. | |||
2020-03-17 | record: Format file header | Sebastian Huber | |
Update #3904. | |||
2020-03-17 | record: Guard config.h include | Sebastian Huber | |
Update #3904. | |||
2020-03-17 | record: Fix format | Sebastian Huber | |
Update #3904. | |||
2020-03-17 | Improve Python 3 compatibility | Sebastian Huber | |
2020-03-07 | Move mkimage.py to install_files so chmod is preserved and installed in bin/ | Amar Takhar | |
2020-03-05 | psim-device-tree: Rework so devices do not conflict with 256MB RAM | Joel Sherrill | |
closes #3849. | |||
2020-03-05 | rtemstoolkit: Detect native SPARCV9 ELF arch | Sebastian Huber | |
2020-03-05 | rtemstoolkit: Use multiprocessing.cpu_count() | Sebastian Huber | |
The previous implementation does not work on some Linux distributions, e.g. Debian on sparc64. Use a standard function instead. | |||
2020-03-05 | rtemstoolkit: Support more Linux distributions | Sebastian Huber | |
The platform.dist() function is not always available. | |||
2020-03-04 | Add print statement similar to the original mkimage. | Amar Takhar | |
This is limited to Python 2.6+ | |||
2020-03-04 | Fix to work under Pyhon 2 and Python 3. | Amar Takhar | |
Also changed 'python2' to 'python' in the shebang. | |||
2020-03-04 | Convert optparse to argparse. | Amar Takhar | |
* Fix exceptions and print exception message. * Also add myself to copyright. |
