* | Bumped version to 2.302.30 | Jiri Gaisler | 2022-10-26 | 1 | -23/+11 |
* | Support extended interrupts2.29 | Sebastian Huber | 2021-08-04 | 1 | -10/+10 |
* | Added GR740 L2 configuration register2.28 | Jiri Gaisler | 2021-07-30 | 1 | -10/+10 |
* | Added simple RISC-V PLIC functionality for NS16550 interrupt | Jiri Gaisler | 2021-06-10 | 1 | -10/+10 |
| | | | | * RTEMS spconsole01 test now passes | ||||
* | Added support for RISCV32 systems with CLINT/PLIC | Jiri Gaisler | 2020-12-15 | 1 | -10/+10 |
* | Added emulation of GR740 SOC2.25 | Jiri Gaisler | 2020-12-01 | 1 | -10/+10 |
| | | | | * Only limited functionality with standard peripherals | ||||
* | Add %asr22/23 support to leon32.24 | Jiri Gaisler | 2020-11-27 | 1 | -10/+10 |
* | Add networking support using host tap device2.23 | Jiri Gaisler | 2020-10-28 | 1 | -10/+10 |
| | | | | | | * Emulation of GRETH 10/100 Mbit MAC and PHY * Supported only on linux | ||||
* | Update to version 2.222.22 | Jiri Gaisler | 2020-09-09 | 1 | -10/+10 |
* | Update to version 2.212.21 | Jiri Gaisler | 2020-02-29 | 1 | -11/+23 |
* | Cross-platform support for async gdb break (ctrl-c) | Jiri Gaisler | 2019-11-14 | 1 | -10/+10 |
* | Support building on MinGW-W64/MSYS22.19 | Jiri Gaisler | 2019-11-09 | 1 | -10/+100 |
| | | | | * Depends on MinGW64-readline to build | ||||
* | Release version 2.182.18 | Jiri Gaisler | 2019-11-02 | 1 | -10/+10 |
* | Updated to version 2.172.17 | Jiri Gaisler | 2019-07-03 | 1 | -10/+10 |
* | Make readline conditional and add linenoise it not present. | Chris Johns | 2019-07-02 | 1 | -6/+22 |
| | | | | | | | - Readline is not present on all hosts is used on and it has not been a requirement. Rather than break all hosts that are working this patch conditionally adds linenoise a small simple realline replacement. | ||||
* | Updated version to 2.162.16 | Jiri Gaisler | 2019-06-12 | 1 | -10/+10 |
* | Made L1 cache optional through --enable-l1cache | Jiri Gaisler | 2019-05-28 | 1 | -11/+250 |
| | | | | | | | * Removed stale config.h * Updated autoconf script with relevant checks * Re-implemented leon3/grlib timer with less events * Bumped version to 2.15 | ||||
* | Standalone sis - initial commit | Jiri Gaisler | 2019-05-14 | 1 | -0/+5480 |
