Close #3250.
Close #4081.
The testsuites/ada/sptests/sp19/Makefile was added to document how
sptest.adb is generated. However, this Makefile is in the way of
./bootstrap -c. Add an exception.
Include all cpukit/*/header.am files in cpukit/Makefile.am. This gets
rid of all subtree Makefile.am and the sudirs hack.
closes #3509.
Update #3285.
On POSIX compliant shells, echo does not have the -e option.
This causes the "-e" to be echoed as well, causing potential buggy
build processes.
Example shell session:
-> % sh
$ echo -e "foo bar"
-e foo bar
According to POSIX, "\$" should be fine regardless due to the use of
double-quotes[1]. However, since printf is recommended over echo anyway,
we replace "echo -e" with printf where required.
[1] http://pubs.opengroup.org/onlinepubs/009695399/utilities/xcu_chap02.html#tag_02_02_03
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Updates #3520.
Closes #2965.
closes #2812.
Sorting removed the variations across different host operating systems
and file systems.
These modifications were required by hand after running the script.
In some cases, the file names did not match patterns. In others,
the format of the file did not match any common patterns.
* depcomp, compile, texinfo.tex, mdate-sh: New.
* bootstrap (-c): Don't remove depcomp, compile, texinfo.tex,
mdate-sh.
* bootstrap: Add -g option.
Switch default to autoreconf.
* bootstrap: Use find . ... preinstall.am for portability reasons.
* bootstrap: Add -p (regenerate preinstall.ams).
PR 882/make_build
* bootstrap: Only remove bspopts.h.in instead of bspopts.h*.
* bootstrap: RTEMS_CHECK_BSPDIR(RTEMS_BSP_FAMILY).
* .cvsignore: Remove mkinstalldirs.
* bootstrap: Remove compile during "clean".
* bootstrap: Use $RTEMS_BSP_FAMILY instead of RTEMS_BSP_ALIAS in
c/src/lib/libbsp/*/acinclude.m4.
* config.sub: Remove (Automatically added by automake, again).
* bootstrap: Reflect change above.
* configure.ac: Require automake >= 1.7.6.
* bootstrap: Reflect having added config.sub.
* bootstrap: Remove attempts to detect autoconf and automake using
"which" (PR 325).
* bootstrap: Require autoconf 2.54 or 2.57.
Require automake-1.7.2.
* bootstrap: Allow autoconf-2.57.
* bootstrap: Allow autoconf-2.56.
* bootstrap: Allow autoconf > 2.52, automake > 1.6.
* bootstrap: Add generate_bspdir_acinclude to automatically update
c/src/lib/libbsp/<cpu>/acinclude.m4.
Use #! /bin/sh instead of #!/bin/sh.
Remove autom4te*.cache during ./bootstrap --clean.
* bootstrap: Add autoconf/automake version checks by popular demand.
[FWIW: I dislike this.]
* aclocal/version.m4: New file.
* aclocal/rtems-top.m4: Add RTEMS_VERSIONING, replace VERSION w/
aclocal/version.m4.
* bootstrap: Use aclocal/version.m4 instead of VERSION.
* configure.ac: Use aclocal/version.m4 instead of VERSION.
* aclocal/sysv-ipc.m4: Use 3-args AC_DEFINE for autoconf-2.5x
compatibility.
* bootstrap: Let --clean remove texinfo.tex.
* bootstrap: Run autoheader when configure.ac contains
RTEMS_BSP_CONFIGURE. Remove bspopts.h* files.
* bootstrap: remove/add automake added files.
* .cvsignore: reflect changes to bootstrap.
* configure.in: autoupdate to autoconf-2.52.
* bootstrap: Add handling for configure.ac, make autoheader verbose,
fix auto*tool invocation order.
* aclocal/rtems-test-no-pause.m4: Introduce AC_HELP_STRING.
* aclocal/enable-bare.m4: Introduce AC_HELP_STRING.
* aclocal/enable-cxx.m4: Introduce AC_HELP_STRING.
* aclocal/enable-gcc28: Introduce AC_HELP_STRING.
* aclocal/enable-inlines.m4: Introduce AC_HELP_STRING.
* aclocal/enable-itron.m4: Introduce AC_HELP_STRING.
* aclocal/enable-libcdir.m4: Introduce AC_HELP_STRING.
* aclocal/enable-multiprocessing.m4: Introduce AC_HELP_STRING.
* aclocal/enable-networking.m4: Introduce AC_HELP_STRING.
* aclocal/enable-posix.m4: Introduce AC_HELP_STRING.
* aclocal/enable-rdbg.m4: Introduce AC_HELP_STRING.
* aclocal/enable-rtemsbsp.m4: Introduce AC_HELP_STRING.
* aclocal/enable-tests.m4: Introduce AC_HELP_STRING.
* aclocal/env-rtemsbsp.m4: Add AC_ARC_VAR(RTEMS_BSP), apply true in
RTEMS_CONFIG_PER_BSP conditional.
* aclocal/multilib.m4: Introduce AC_HELP_STRING.
* aclocal/rtems-debug.m4: Introduce AC_HELP_STRING.
* aclocal/rtems-top.m4: Add AC_PREFIX_DEFAULT(/opt/rtems).
<corsepiu@faw.uni-ulm.de> to evaluate ACLOCAL_AMFLAGS in
Makefile.ams before running aclocal.
Remark: This patch is in preparation to switching to Cygnus/GNU
canonicalization. I plan to introduce to an alternate aclocal macros
directory which shall contain Cygnus/GNU conforming macros only,
soon.
<corsepiu@faw.uni-ulm.de> which does the following:
This is the configuration cleanup patch:
Main changes:
* TARGET_ARCH removed
* target.cfg.in moved to c/make/target.cfg.in (Only configured once for
all BSPs of a target)
* BARE_XXX variables appended to bsp.cfg.in
* autogen renamed to bootstrap
* removed stray variables from make/custom/*.cfg
rm c/src/make/target.cfg.in
cp autogen bootstrap
mkdir c/make
cp make/target.cfg.in c/make/target.cfg.in
rm make/target.cfg.in
rm autogen
patch -p1 < rtems-rc-19991105-1.diff
