Roll in NCB's patch and some other changes for Linux 3.0.
Also fix a dumb type retired_writes->retried_writes
Signed-off-by: Charles Manning <cdhmanning@gmail.com>
Was returning ENOMEM.
Clean up a whole lot of code issues raised by Ryan.
Some further reformatting etc to be mor kernel friendly.
Minor types.
Passes checkpatch.pl
Coverity checks raised some issues, particularly with NULL checks.
Fix them.
These wrapping helped nothing. Out... out!
Make the tracing a whole lot easier on the eye.
Taking onboard some comments from LKML.
Since the /proc/yaffs-stats has been removed, we now suck stats from
/proc/yaffs for running the erased space plotting script.
There was not much point in having the yaffs version as it is
functionally equivalent to the kernel one.
This also gets rid of using BKL in yaffs2.
Make some checkpt messages conditional.
Fix up trace table screwed up by lindent.
These have been removed from Linux as their use is discouraged except
for debugging purposes.
The logic has also changed for SHORT_NAMES_IN_RAM. This is now negative
logic. Set CONFIG_YAFFS_NO_SHORT_NAMES to **disable** short names.
If a conditional has braces then all paths have braces even if they only
have one statement.
Mutex is faster and init_MUTEX has been deprecated, so we'll just switch
to mutexes.
Only applies to Linux files.
__u32 -> u32 and such.
