Signed-off-by: Charles Manning <cdhmanning@gmail.com>
Passes checkpatch.pl
Mutex is faster and init_MUTEX has been deprecated, so we'll just switch
to mutexes.
Only applies to Linux files.
__u32 -> u32 and such.
divide up test code
This all makes for a far cleaner layout of test code.
The new yaffs direct list management allows partitions to be added synamically rather than
statically. This is better for OSs that install partitions at runtime (eg. WInCE).
The nand abstraction makes it tidier to add a new nand driver to yaffs direct and test code.
The test code has been repartitioned to make porting and file management cleaner.
Refactoring the allocator allows alternate allocators to be switched in more easily
Update copyright messages.
Clean up tracing to use TSTR and KERN_DEBUG.
Remove cvs $Id.
Change /proc/yaffs_debug to /proc/yaffs_stats.
... and a few other clean ups.
This is a modified version of the patch suplied by
Jean-Loup Sabatier
