2015-05-19 | rtems_yaffs: RTEMS API changes (fsmount_me_h) | Sebastian Huber | |
2015-01-22 | rtems_yaffs: RTEMS API changes (node_type_h) | Sebastian Huber | |
2014-06-06 | rtems_yaffs: RTEMS API changes (chmod) | Sebastian Huber | |
2013-01-11 | rtems_yaffs: Add dev field to OS context | Sebastian Huber | |
2012-10-09 | rtems_yaffs: Update due to RTEMS API changes | Sebastian Huber | |
2012-05-15 | rtems_yaffs: Update due to RTEMS API changes | Sebastian Huber | |
2012-05-14 | rtems_yaffs: don't set offset when write file | Xiangfu | |
2012-05-14 | Update rtems_yaffs due to rtems rtems_libio_tt changed | Xiangfu | |
2012-03-13 | Update due to API changes | Sebastian Huber | |
2012-02-24 | Remove fpathconf | Sebastien Bourdeauducq | |
2011-09-22 | Fixed return value of ycb_file_lseek(). | Sebastian Huber | |
2011-09-21 | Fixed double offset update. | Sebastian Huber | |
The write() function updates the offset. | |||
2011-09-14 | C++ compatibility. | Sebastian Huber | |
2011-09-08 | Flush during close (similar to yaffs_close()). | Sebastian Huber | |
2011-09-07 | Use UNIX time instead of seconds since boot. | Sebastian Huber | |
2011-09-07 | Changed seek mechanic. | Sebastian Huber | |
The seek mechanic is now more in line with other file systems on RTEMS. Concurrent write access may lead to confusion if a seek at the file end will be performed. | |||
2011-09-07 | Check the device read-only property during mount. | Sebastian Huber | |
2011-09-07 | Implemented data synchronization. | Sebastian Huber | |
2011-09-07 | Avoid NULL pointer access. | Sebastian Huber | |
2011-09-07 | Moved memory management. | Sebastian Huber | |
2011-07-30 | Add memory management | Sebastien Bourdeauducq | |
2011-07-30 | Compile needed yaffs_summary | Sebastien Bourdeauducq | |
2011-07-30 | Remove references to non-existing bits | Sebastien Bourdeauducq | |
2011-07-22 | RTEMS support patch by Sebastian Huber | Sebastien Bourdeauducq | |
