2023-05-19 | Update company name | Sebastian Huber | |
The embedded brains GmbH & Co. KG is the legal successor of embedded brains GmbH. | |||
2021-02-04 | validation: Remove prologue/epilogue in test cases | Sebastian Huber | |
2021-02-04 | validation: Add context and fixture to test case | Sebastian Huber | |
2020-08-19 | spec: Unify test attribute keys | Sebastian Huber | |
2020-08-19 | spec: Add test header to test case item type | Sebastian Huber | |
2020-08-19 | validation: Remove explicit test names | Sebastian Huber | |
2020-06-08 | spec: Rename required in mandatory attributes | Sebastian Huber | |
The term "required" is quite overloaded in the specification context. Use "mandatory" instead. Shorten the phrase "explicitly defined attributes" to "explicit attributes". | |||
2020-06-08 | spec: Canonicalize descriptions | Sebastian Huber | |
2020-05-28 | spec: Add specification of test items | Sebastian Huber | |
