summaryrefslogtreecommitdiff
path: root/spec/spec/interface-enumerator-role.yml (follow)
AgeCommit message (Collapse)Author
2023-05-19Update company nameSebastian Huber
The embedded brains GmbH & Co. KG is the legal successor of embedded brains GmbH.
2020-06-08spec: Rename required in mandatory attributesSebastian Huber
The term "required" is quite overloaded in the specification context. Use "mandatory" instead. Shorten the phrase "explicitly defined attributes" to "explicit attributes".
2020-05-28spec: Add specification of interface itemsSebastian Huber
