2022-09-02 | spec: Add external interfaces to a group | Sebastian Huber | |
Remove interface container item type. | |||
2020-06-08 | spec: Rename required in mandatory attributes | Sebastian Huber | |
The term "required" is quite overloaded in the specification context. Use "mandatory" instead. Shorten the phrase "explicitly defined attributes" to "explicit attributes". | |||
2020-05-28 | specdoc: Use mapper substitutions for descriptions | Sebastian Huber | |
2020-05-28 | spec: Add interface domain items | Sebastian Huber | |
2020-05-28 | spec: Add specification of interface items | Sebastian Huber | |
