2023-05-19 | Update company name | Sebastian Huber | |
The embedded brains GmbH & Co. KG is the legal successor of embedded brains GmbH. | |||
2023-01-23 | spec: Improve build option default values | Sebastian Huber | |
Merge "default" and "default-by-variant" attributes. Use an enabled-by expression to select the default value. | |||
2021-08-30 | spec: Document build option | Sebastian Huber | |
2020-06-08 | spec: Rename required in mandatory attributes | Sebastian Huber | |
The term "required" is quite overloaded in the specification context. Use "mandatory" instead. Shorten the phrase "explicitly defined attributes" to "explicit attributes". | |||
2020-05-28 | spec: Add examples | Sebastian Huber | |
2020-05-28 | spec: Sort attributes | Sebastian Huber | |
2020-05-28 | spec: Add specification of build items | Sebastian Huber | |
