2023-05-19 | Update company name | Sebastian Huber | |
The embedded brains GmbH & Co. KG is the legal successor of embedded brains GmbH. | |||
2022-09-08 | spec: Add attributes to build items | Sebastian Huber | |
Update #4670. | |||
2020-10-01 | spec: Clarify stlib build attribute | Sebastian Huber | |
2020-06-08 | spec: Rename required in mandatory attributes | Sebastian Huber | |
The term "required" is quite overloaded in the specification context. Use "mandatory" instead. Shorten the phrase "explicitly defined attributes" to "explicit attributes". | |||
2020-05-28 | spec: Add examples | Sebastian Huber | |
2020-05-28 | specdoc: Use mapper substitutions for descriptions | Sebastian Huber | |
2020-05-28 | spec: Add specification of build items | Sebastian Huber | |
