2021-04-29 | spec: Use explicit constraints for acfg | Sebastian Huber | |
2020-06-08 | spec: Rename required in mandatory attributes | Sebastian Huber | |
The term "required" is quite overloaded in the specification context. Use "mandatory" instead. Shorten the phrase "explicitly defined attributes" to "explicit attributes". | |||
2020-05-28 | specdoc: Use mapper substitutions for descriptions | Sebastian Huber | |
2020-05-28 | spec: Canonicalize specification of specification | Sebastian Huber | |
2020-05-28 | Rename custom constraints attribute | Sebastian Huber | |
Uses "texts" to be in line with the "text" attribute of constraint items. | |||
2020-05-28 | Add constraint link role | Sebastian Huber | |
2020-05-28 | Rename application configuration attributes | Sebastian Huber | |
