The addition of the entire *utime*() family of functions resulted
in this call returning ENOENT not ENXIO. This is better aligned
with the POSIX definition of the methods.
Improved tests for utime() and utimes() and update license.
Close #4399
This adds a rtems_mutex_try_lock and a rtems_recursive_mutex_try_lock.
Update #4440.
Close #4413.
telnetd01 test cannot be run without a network stack, so this test is being
moved to the rtems-net-legacy repository.
Close #4410.
Add a library for support functions used by validation tests. Rename
tc-support.* to tx-support.* since this file does not contain test
cases.
Add a parameter to _TOD_Validate() to disable the validation of the
ticks member.
There are two reasons for this change. Firstly, in
rtems_task_wake_when() was a double check for time_buffer == NULL (one
in rtems_task_wake_when() and one in _TOD_Validate()). Secondly, the
ticks member is ignored by rtems_task_wake_when(). This was done with a
write of zero to the ticks member and thus a modification of the
user-provided structure. Now the structure is no longer modified.
Using a mask parameter is quite efficient. You just have to load an
immediate value and there are no additional branches in _TOD_Validate().
Close #4406.
This patch fixes bug #4403. Directives
* rtems_timer_fire_when()
* rtems_timer_server_fire_when()
* rtems_task_wake_when()
are documented to return RTEMS_INVALID_ADDRESS when their time-of-day
argument is NULL. But actually they return RTEMS_INVALID_CLOCK. To fix
the issue this patch changes _TOD_Validate() to return a
status code instead of just true/false.
Close #4403
In the action requirements, some pre-conditions are not applicable
depending on the state of other pre-conditions. There is no particular
order in the pre-conditions, so we have to check the N/A status
individually.
In POSIX, zero size memory allocations are implementation-defined
behaviour. The implementation has two options:
https://pubs.opengroup.org/onlinepubs/9699919799/functions/malloc.html
https://pubs.opengroup.org/onlinepubs/9699919799/functions/posix_memalign.html
Linux and FreeBSD return a unique pointer for zero size memory
allocations. Return NULL on RTEMS to more likely catch the use of a
zero size memory area by erroneous applications.
Update #4390.
In case the processor set is not large enough to contain the processor
set owned by the scheduler return RTEMS_INVALID_SIZE instead of
RTEMS_INVALID_NUMBER. This is more in line with other directives since
the issue is related to the size of an object.
Close #4401.
Added conditionals to ensure that long double function tests were only
built when newlib has long double math functions.
The zero size allocations had no consistent behaviour in RTEMS. For
example, malloc( 0 ) returned NULL and posix_memalign( &p, align, 0 )
returned in p a unique pointer (or NULL if no memory is available). In
allocations. Use this approach for RTEMS as well throughout the memory
allocation directives
Close #4390.
Flexible array members must not appear in the middle of a structure.
Close #3866.
Changed the way the tests were structured, added rtems_test_assert()'s,
updated psx13.scn and the license.
Update #3899
affinity set of the task return RTEMS_INVALID_SIZE instead of
Close #4393.
Since there are already excessive NULL pointer checks in the Classic
API, do this also in rtems_task_construct().
Update #3959.
API, do this also in rtems_message_queue_construct().
Update #4007.
This patch fixes issue #4338 by changing _TOD_Validate()
to only accept years till 2105. This requires another patch
to change the documentation of rtems_clock_set() and other
affected API functions (indicating the end date is 2105 not 2514).
I tried to support till year 2514 but it turned out that
this needs changing the Timer Manager too. That in turn
would mean to change _TOD_Seconds_since_epoch( void )
from 32 to 64 bit. Sebastian pointed out that a naive extension
leads to trouble with 32 bit processors. He deemed a safe
re-implementation too costly performance wise considering
that year 2106 is far away and current binaries using RTEMS
Classic API are unlikely to be in use by 2106.
The constant TOD_SECONDS_AT_2100_03_01_00_00 in
cpukit/rtems/src/clocktodtoseconds.c happens to be wrong by
1 hour. When setting the date 2100-Feb-28 23:59:59 and then
reading the date again you will find yourself in 2100-Feb-27.
Update #4338
The multiplication to calculate the length of the memory area to
allocate may overflow. Return NULL in case of an overflow.
Close #4389.
* On some SMP platforms, all cpus are started by the
boot-loader. We need to block the secondary cpus or they
will clobber the test output.
This reverts commit 3299dda2454a8847c670a732f6c12ef1f2cc5dd0.
Update #3850
Update #3850
Update #3850
Fix warning:
testsuites/validation/tc-signal-send.c:634:21: warning: unused variable
'sc' [-Wunused-variable]
Fix warning:
testsuites/libtests/block14/init.c:198:8: warning: 'sc' may be used
uninitialized in this function [-Wmaybe-uninitialized]
Update #3689.
Do not adjust the stack area begin address since this may confuse the
stack allocator and result in failed stack frees.
Account for the alignment overhead in the stack space size estimate.
Check that the stack size is in the expected interval.
Adds a peek function that allows (for example) a file system to suggest
the next blocks that should be used for read ahead. This can increase
the read speed of fragmented files.
Update #3689
Use a common wording for the tests. Use the new templates for action
requirements described in the RTEMS Software Engineering manual.
Rejecting initially locked MrsP semaphores was due to a limitiation of
the early limitiation of the MrsP protocol. This limitation no longer
exists.
MrsP semaphores are a generalization of the priority ceiling semaphores
for SMP configurations. Priority ceiling semaphores are required to use
the priority task wait queue discipline. Require this discipline also
for MrsP semaphores.
Close #4347.
Close #4343.
Run the task create/construct tests also on validation test suite 1
which has exactly one processor configured.
Signed-off-by: Eshan Dhawan <eshandhawan51@gmail.com>
Ensure that CONFIGURE_MAXIMUM_THREAD_LOCAL_STORAGE_SIZE meets the task
storage alignment requirement.
Closes #4179.
In uniprocessor configurations, we can simplify rtems_signal_catch().
Add a validation test for the SMP special case.
