* support/include/tmacros.h:
Remove fatal_posix_service_pointer_minus_one (unused).
* psxmsgq01/init.c: Introduce fatal_posix_mqd.
Replace fatal_posix_service_pointer_minus_one with fatal_posix_mqd.
* psxsem01/init.c: Introduce fatal_posix_sem.
Replace fatal_posix_service_pointer_minus_one with fatal_posix_sem.
* psxreaddir/test.c: Remove bogus casts.
Fix fprintf format strings.
* psxfile01/test.c: Remove local redeclaration of IMFS_dump.
* malloc04/init.c: Define p1, p2, p3, p4 extern (Avoid warnings).
* psxtmbarrier01/init.c, psxtmbarrier02/init.c, psxtmbarrier03/init.c,
psxtmkey01/init.c, psxtmkey02/init.c, psxtmmq01/init.c,
psxtmmutex01/init.c, psxtmmutex02/init.c, psxtmmutex03/init.c,
psxtmmutex04/init.c, psxtmmutex05/init.c, psxtmmutex06/init.c,
psxtmmutex07/init.c, psxtmnanosleep01/init.c, psxtmnanosleep02/init.c,
psxtmrwlock01/init.c, psxtmrwlock02/init.c, psxtmrwlock03/init.c,
psxtmrwlock04/init.c, psxtmrwlock05/init.c, psxtmrwlock06/init.c,
psxtmrwlock07/init.c, psxtmsem01/init.c, psxtmsem02/init.c,
psxtmsem03/init.c, psxtmsem04/init.c, psxtmsem05/init.c,
psxtmsleep01/init.c, psxtmsleep02/init.c, psxtmthread03/init.c:
Use benchmark_timer_t for benchmark_timer values (Avoid 64bit
arch issues).
* mrfs_support/fs_support.c: Resolved name conflict that was causing a
compiler error.
* fileio/init.c: Explictly consts in size_t initializers
(avoid overflows on 16bit-int targets).
* tm26/fptest.h: Use PRIu32 to print uint32_t.
* psxhdrs/pthread01.c, psxhdrs/pthread02.c, psxhdrs/pthread03.c,
psxhdrs/pthread04.c, psxhdrs/pthread05.c, psxhdrs/pthread06.c,
psxhdrs/pthread07.c, psxhdrs/pthread09.c, psxhdrs/pthread10.c,
psxhdrs/pthread11.c, psxhdrs/pthread12.c, psxhdrs/pthread13.c,
psxhdrs/pthread14.c, psxhdrs/pthread15.c, psxhdrs/pthread16.c,
psxhdrs/pthread17.c, psxhdrs/pthread18.c, psxhdrs/pthread19.c,
psxhdrs/pthread20.c, psxhdrs/pthread21.c, psxhdrs/pthread22.c,
psxhdrs/pthread23.c, psxhdrs/pthread24.c, psxhdrs/pthread25.c,
psxhdrs/pthread26.c, psxhdrs/pthread27.c, psxhdrs/pthread28.c,
psxhdrs/pthread29.c, psxhdrs/pthread30.c, psxhdrs/pthread34.c,
psxhdrs/pthread35.c, psxhdrs/pthread36.c, psxhdrs/pthread37.c,
psxhdrs/pthread38.c, psxhdrs/pthread39.c, psxhdrs/pthread40.c:
Let test() return values (avoid warnings).
* psxhdrs/cond01.c, psxhdrs/cond02.c, psxhdrs/cond03.c,
psxhdrs/cond04.c, psxhdrs/cond05.c, psxhdrs/cond06.c,
psxhdrs/cond07.c, psxhdrs/cond08.c, psxhdrs/cond09.c,
psxhdrs/cond10.c: Let test() return values (avoid warnings).
* psxhdrs/mutex01.c, psxhdrs/mutex02.c, psxhdrs/mutex03.c,
psxhdrs/mutex04.c, psxhdrs/mutex05.c, psxhdrs/mutex06.c,
psxhdrs/mutex07.c, psxhdrs/mutex08.c, psxhdrs/mutex09.c,
psxhdrs/mutex10.c, psxhdrs/mutex11.c, psxhdrs/mutex12.c,
psxhdrs/mutex13.c, psxhdrs/mutex14.c, psxhdrs/mutex15.c,
psxhdrs/mutex16.c: Let test() return values (avoid warnings).
* psxhdrs/proc01.c, psxhdrs/proc02.c, psxhdrs/proc03.c,
psxhdrs/proc04.c, psxhdrs/proc05.c, psxhdrs/proc06.c,
psxhdrs/proc07.c, psxhdrs/proc08.c, psxhdrs/proc09.c,
psxhdrs/proc10.c, psxhdrs/proc11.c, psxhdrs/proc12.c,
psxhdrs/proc13.c, psxhdrs/proc14.c:
* psxhdrs/sched01.c, psxhdrs/sched02.c, psxhdrs/sched03.c,
psxhdrs/sched04.c, psxhdrs/sched05.c, psxhdrs/sched06.c,
psxhdrs/sched07.c, psxhdrs/sched08.c:
* psxhdrs/signal01.c, psxhdrs/signal02.c, psxhdrs/signal03.c,
psxhdrs/signal04.c, psxhdrs/signal05.c, psxhdrs/signal06.c,
psxhdrs/signal07.c, psxhdrs/signal08.c, psxhdrs/signal09.c,
psxhdrs/signal10.c, psxhdrs/signal11.c, psxhdrs/signal12.c,
psxhdrs/signal13.c, psxhdrs/signal14.c, psxhdrs/signal15.c,
psxhdrs/signal16.c, psxhdrs/signal17.c, psxhdrs/signal18.c,
psxhdrs/signal19.c, psxhdrs/signal20.c, psxhdrs/signal21.c,
psxhdrs/signal22.c, psxhdrs/signal23.c:
* psxhdrs/key01.c, psxhdrs/key02.c, psxhdrs/key03.c,
psxhdrs/key04.c: Let test() return values (avoid warnings).
* psxhdrs/clock01.c, psxhdrs/clock02.c, psxhdrs/clock03.c,
psxhdrs/clock04.c, psxhdrs/clock05.c, psxhdrs/clock06.c:
* psxhdrs/signal23.c: Add comment to denote test as obsolete.
* configure.ac: Check for size of mode_t.
* psxfile01/test.c, psxstat/test.c: Include "primode.h".
Use PRIomode_t to print mode_t.
* support/include/primode.h: New.
* Makefile.am: Add support/include/primode.h
* psxaio01/system.h, psxaio02/system.h, psxaio03/system.h: Do not use
the stack checker.
* psxhdrs/sync01.c, psxhdrs/sync02.c: Let test() return values
(avoid warnings).
* psxhdrs/time01.c, psxhdrs/time02.c, psxhdrs/time03.c,
psxhdrs/time04.c, psxhdrs/time05.c, psxhdrs/time06.c,
psxhdrs/time07.c, psxhdrs/time08.c, psxhdrs/time09.c,
psxhdrs/time10.c, psxhdrs/time11.c, psxhdrs/time12.c,
psxhdrs/time13.c: Let test() return values (avoid warnings).
* psxhdrs/timer01.c, psxhdrs/timer02.c, psxhdrs/timer03.c,
psxhdrs/timer04.c, psxhdrs/timer05.c, psxhdrs/timer06.c,
psxhdrs/timer07.c: Let test() return values (avoid warnings).
* capture/init.c: Declare notification only if being used.
* sp2038/.cvsignore: New file.
PR 1922
* spcbssched02/system.h, spcbssched03/system.h, spedfsched02/system.h,
spedfsched02/task1.c, spedfsched03/system.h: EDF and CBS scheduler:
extern declarations fix.
* fsrdwr/init.c: Use %zd to print size_t.
* fserror/test.c, fslink/test.c, fspatheval/test.c,
fspermission/test.c, fsrdwr/init.c, fssymlink/test.c,
fstime/test.c, support/fstest_support.c, support/ramdisk_support.c:
Explicitly include "pmacros.h".
* support/fstest.h: Don't include "pmacros.h".
* support/include/tmacros.h: Remove PRItime_t.
* nsecs/init.c: Include "pritime.h".
Use PRIdtime_t to print time_t.
* psx01/init.c, psx07/init.c, psx09/init.c, psx12/init.c,
psxclock/init.c, psxtimer01/psxtimer.c: Include "pritime.h".
* sp50/init.c, spclockget/init.c: Include "pritime.h".
* support/include/pritime.h: New.
* Makefile.am: Add support/include/pritime.h
* configure.ac: Check for size of time_t.
* psx16/init.c, psxclassic01/init.c, psxeintr_join/init.c:
Add HAVE_CONFIG_H.
* sp75/init.c, spcbssched01/init.c, spcbssched01/task1.c
spcbssched02/init.c, spcbssched02/task_periodic.c,
spcbssched03/init.c, spcbssched03/tasks_aperiodic.c,
spcbssched03/tasks_periodic.c, spedfsched01/init.c,
spedfsched01/task1.c, spedfsched02/getall.c, spedfsched02/init.c,
spedfsched02/task1.c, spedfsched03/init.c,
spedfsched03/tasks_aperiodic.c, spedfsched03/tasks_periodic.c,
sprbtree01/init.c: Add HAVE_CONFIG_H.
* psxtmsem03/init.c: Add HAVE_CONFIG_H.
* smp05/init.c, smp06/init.c, smp07/init.c, smp09/init.c:
Add HAVE_CONFIG_H.
* mouse01/init.c, mouse01/msmouse.c, mouse01/serial_mouse_config.c:
Add HAVE_CONFIG_H.
* sp2038/init.c: More test cases.
* sp2038/Makefile.am, sp2038/init.c, sp2038/sp2038.doc,
sp2038/sp2038.scn: New files.
* Makefile.am, configure.ac: Reflect changes above.
* spfatal07/testcase.h: Print end of test if test is not applicable.
PR 1923/testing
* spcbssched02/spcbssched02.scn, spcbssched02/system.h,
spcbssched03/init.c, spcbssched03/system.h, spedfsched02/system.h,
spedfsched03/system.h, sprbtree01/init.c: Improve coverage.
PR 1916/testing
* spcbssched02/init.c, spcbssched02/spcbssched02.scn,
spcbssched02/system.h, spcbssched02/task_periodic.c,
spedfsched03/init.c, spedfsched03/system.h,
spedfsched03/tasks_aperiodic.c: Improve coverage.
