PR 1922
* spcbssched02/system.h, spcbssched03/system.h, spedfsched02/system.h,
spedfsched02/task1.c, spedfsched03/system.h: EDF and CBS scheduler:
extern declarations fix.
* fsrdwr/init.c: Use %zd to print size_t.
* fserror/test.c, fslink/test.c, fspatheval/test.c,
fspermission/test.c, fsrdwr/init.c, fssymlink/test.c,
fstime/test.c, support/fstest_support.c, support/ramdisk_support.c:
Explicitly include "pmacros.h".
* support/fstest.h: Don't include "pmacros.h".
* support/include/tmacros.h: Remove PRItime_t.
* nsecs/init.c: Include "pritime.h".
Use PRIdtime_t to print time_t.
* psx01/init.c, psx07/init.c, psx09/init.c, psx12/init.c,
psxclock/init.c, psxtimer01/psxtimer.c: Include "pritime.h".
* sp50/init.c, spclockget/init.c: Include "pritime.h".
* support/include/pritime.h: New.
* Makefile.am: Add support/include/pritime.h
* configure.ac: Check for size of time_t.
* psx16/init.c, psxclassic01/init.c, psxeintr_join/init.c:
Add HAVE_CONFIG_H.
* sp75/init.c, spcbssched01/init.c, spcbssched01/task1.c
spcbssched02/init.c, spcbssched02/task_periodic.c,
spcbssched03/init.c, spcbssched03/tasks_aperiodic.c,
spcbssched03/tasks_periodic.c, spedfsched01/init.c,
spedfsched01/task1.c, spedfsched02/getall.c, spedfsched02/init.c,
spedfsched02/task1.c, spedfsched03/init.c,
spedfsched03/tasks_aperiodic.c, spedfsched03/tasks_periodic.c,
sprbtree01/init.c: Add HAVE_CONFIG_H.
* psxtmsem03/init.c: Add HAVE_CONFIG_H.
* smp05/init.c, smp06/init.c, smp07/init.c, smp09/init.c:
Add HAVE_CONFIG_H.
* mouse01/init.c, mouse01/msmouse.c, mouse01/serial_mouse_config.c:
Add HAVE_CONFIG_H.
* sp2038/init.c: More test cases.
* sp2038/Makefile.am, sp2038/init.c, sp2038/sp2038.doc,
sp2038/sp2038.scn: New files.
* Makefile.am, configure.ac: Reflect changes above.
* spfatal07/testcase.h: Print end of test if test is not applicable.
PR 1923/testing
* spcbssched02/spcbssched02.scn, spcbssched02/system.h,
spcbssched03/init.c, spcbssched03/system.h, spedfsched02/system.h,
spedfsched03/system.h, sprbtree01/init.c: Improve coverage.
PR 1916/testing
* spcbssched02/init.c, spcbssched02/spcbssched02.scn,
spcbssched02/system.h, spcbssched02/task_periodic.c,
spedfsched03/init.c, spedfsched03/system.h,
spedfsched03/tasks_aperiodic.c: Improve coverage.
* monitor/monitor.scn, termios/termios.scn: New files.
* monitor/init.c, termios01/init.c: Use rtems_shell_wait_for_input().
* fileio/fileio.scn: New file.
* capture/init.c, fileio/init.c: Use rtems_shell_wait_for_input().
* spcbssched01/Makefile.am, spcbssched02/Makefile.am,
spcbssched03/Makefile.am: Formatting.
PR 1907/testing
* Makefile.am, configure.ac: Add tests for the CBS (Constant Bandwidth
Server) scheduler.
* spcbssched01/.cvsignore, spcbssched01/Makefile.am,
spcbssched01/init.c, spcbssched01/spcbssched01.doc,
spcbssched01/spcbssched01.scn, spcbssched01/system.h,
spcbssched01/task1.c, spcbssched02/.cvsignore,
spcbssched02/Makefile.am, spcbssched02/init.c,
spcbssched02/spcbssched02.doc, spcbssched02/spcbssched02.scn,
spcbssched03/.cvsignore, spcbssched03/Makefile.am,
spcbssched03/cbsparams.h, spcbssched03/init.c,
spcbssched03/spcbssched03.doc, spcbssched03/spcbssched03.scn,
spcbssched03/system.h, spcbssched03/tasks_aperiodic.c,
spcbssched03/tasks_periodic.c: New files.
* spnsext01/init.c: Use correct API.
* spedfsched01/Makefile.am, spedfsched02/Makefile.am,
spedfsched03/Makefile.am: Use all managers.
PR 1897/testing
* Makefile.am, configure.ac: Add tests for Earliest Deadline First
(EDF) Scheduling Algorithm implementation.
* spedfsched01/.cvsignore, spedfsched01/Makefile.am,
spedfsched01/init.c, spedfsched01/spedfsched01.doc,
spedfsched01/spedfsched01.scn, spedfsched01/system.h,
spedfsched01/task1.c, spedfsched02/.cvsignore,
spedfsched02/Makefile.am, spedfsched02/getall.c, spedfsched02/init.c,
spedfsched02/spedfsched02.doc, spedfsched02/spedfsched02.scn,
spedfsched02/system.h, spedfsched02/task1.c, spedfsched03/.cvsignore,
spedfsched03/Makefile.am, spedfsched03/edfparams.h,
spedfsched03/init.c, spedfsched03/spedfsched03.doc,
spedfsched03/spedfsched03.scn, spedfsched03/system.h,
spedfsched03/tasks_aperiodic.c, spedfsched03/tasks_periodic.c: New
files.
* sp03/sp03.scn, sp05/sp05.scn, sp23/sp23.scn, sp27/sp27.scn,
sp27a/sp27a.scn, sp39/sp39.scn: Update.
* sptests/sp68/init.c: Avoid CPU_STRUCTURE_ALIGNMENT.
* imfs_support/fs_supprot.h, support/fstest.h,
support/ramdisk_support.h: Don't include config.h.
Add config-header support.
* support/fstest.h: Include "pmacros.h".
* fserror/fserror.doc, fserror/test.c, fslink/fslink.doc,
fslink/test.c, fspatheval/patheval.doc, fspatheval/test.c,
fspermission/fspermission.doc, fspermission/test.c,
fsrdwr/fsrdwr.doc, fsrdwr/init.c, fssymlink/fssymlink.doc,
fssymlink/test.c, fstime/fstime.doc, fstime/test.c,
imfs_support/fs_config.h, imfs_support/fs_support.c,
imfs_support/fs_supprot.h, mdosfs_support/fs_config.h,
mdosfs_support/fs_support.c, mimfs_support/fs_config.h,
mimfs_support/fs_support.c, mrfs_support/fs_config.h,
mrfs_support/fs_support.c, support/fstest.h,
support/fstest_support.c, support/fstest_support.h,
support/ramdisk_support.c, support/ramdisk_support.h:
Fix CVS-Ids.
* spfatal01/spfatal01.scn, spfatal02/spfatal02.scn,
spfatal13/spfatal13.scn, spfatal14/spfatal14.scn,
spfatal15/spfatal15.scn, spfatal16/spfatal16.scn,
spfatal17/spfatal17.scn, spfatal18/spfatal18.scn,
spfatal19/spfatal19.scn, spfatal20/spfatal20.scn,
spfatal_support/init.c: Print proper begin message.
* psxfatal01/psxfatal01.scn, psxfatal01/testcase.h,
psxfatal02/psxfatal02.scn, psxfatal02/testcase.h,
psxfatal_support/init.c: Print proper begin and end message.
* stackchk/init.c, stackchk/system.h, stackchk/stackchk.scn: Print end
of test message.
* sp40/init.c: Avoid unsupported test cases.
* ticker/system.h: Remove unneeded include.
PR 1903/testing
* Makefile.am, configure.ac, psxtmtests_plan.csv: Add test for message
queues which covers most open, close, unlink cases as well as
send/receive which do not involve task state changes.
* psxtmmq01/.cvsignore, psxtmmq01/Makefile.am, psxtmmq01/init.c,
psxtmmq01/psxtmmq01.doc: New files.
* spfatal13/testcase.h: Fixed test name.
* spfatal05/testcase.h: Increased wait time for slow hardware.
* spfatal_support/init.c: Print test name at end of test.
spfatal03/spfatal03.scn, spfatal04/spfatal04.scn,
spfatal05/spfatal05.scn, spfatal06/spfatal06.scn,
spfatal07/spfatal07.scn, spfatal08/spfatal08.scn,
spfatal09/spfatal09.scn, spfatal10/spfatal10.scn,
spfatal11/spfatal11.scn, spfatal12/spfatal12.scn,
spfatal21/spfatal21.scn, spfatal22/spfatal22.scn,
spfatal23/spfatal23.scn, spfatal24/spfatal24.scn,
spfatal25/spfatal25.scn: Reflect changes from above.
PR 1899/testing
* spfatal14/Makefile.am: Adjust number of semaphores to consume to
trigger fatal error.
PR 1899/testing
* spfatal14/Makefile.am, spfatal15/Makefile.am, spfatal16/Makefile.am:
Adjust number of semaphores to consume to trigger fatal error.
PR 1886/cpukit
* sprbtree01/init.c, sprbtree01/sprbtree01.scn: This patch enables
inserting duplicate keys into rbtree. It is possible to turn on this
feature when initializing the tree.
PR 1890/cpukit
* psxmsgq01/init.c: POSIX says msg_prio is allowed to be NULL.
* psxfatal_support/init.c: Ensure that _Thread_BSP_context is
initialized.
* spfatal_support/init.c: Ensure that _Thread_BSP_context is
initialized.
* psxtmtests_plan.csv: update.
PR 1888/tests
* Makefile.am, configure.ac, psxtmtests_plan.csv: Add benchmark of
pthread_rwlock_unlock - thread waiting, preempt.
* psxtmrwlock07/.cvsignore, psxtmrwlock07/Makefile.am,
psxtmrwlock07/init.c, psxtmrwlock07/psxtmrwlock07.doc: New files.
PR 1887/tests
pthread_rwlock_unlock - thread waiting, no preempt.
* psxtmrwlock06/.cvsignore, psxtmrwlock06/Makefile.am,
psxtmrwlock06/init.c, psxtmrwlock06/psxtmrwlock06.doc: New files.
* psxtmrwlock01/init.c, psxtmrwlock01/psxtmrwlock01.doc: Update.
