* | validation: Add support library | Sebastian Huber | 2021-05-14 | 1 | -1/+1 |
| | | | | | | Add a library for support functions used by validation tests. Rename tc-support.* to tx-support.* since this file does not contain test cases. | ||||
* | validation: Fix handling of N/A pre-conditions | Sebastian Huber | 2021-05-07 | 1 | -12/+3 |
| | | | | | | | In the action requirements, some pre-conditions are not applicable depending on the state of other pre-conditions. There is no particular order in the pre-conditions, so we have to check the N/A status individually. | ||||
* | validation: Use support functions | Sebastian Huber | 2021-03-23 | 1 | -46/+9 |
* | validation: Reduce source code/rodata size | Sebastian Huber | 2021-03-19 | 1 | -60/+62 |
| | | | | | Use a common wording for the tests. Use the new templates for action requirements described in the RTEMS Software Engineering manual. | ||||
* | validation: Improve wording | Sebastian Huber | 2021-03-11 | 1 | -2/+2 |
* | validation: Use common wording | Sebastian Huber | 2021-03-08 | 1 | -27/+32 |
* | validation: Format comment blocks | Sebastian Huber | 2021-03-02 | 1 | -6/+3 |
* | validation: Add comments to barrier tests | Sebastian Huber | 2021-03-01 | 1 | -0/+27 |
| | | | | Unify code sections across tests. | ||||
* | validation: Tests for barrier manager | Sebastian Huber | 2021-02-08 | 1 | -0/+451 |
