path: root/testsuites/tmitrontests (follow)
* 2003-12-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-182-4/+8
| | | | * tmitrontests.am: Add dirstamp support.
* 2003-12-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-172-1/+5
| | | | * tmitrontests.am: Use $(mkdir_p) instead of $(mkinstalldirs).
* 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-122-2/+6
| | | | * configure.ac: Require automake >= 1.8, autoconf >= 2.59.
* 2003-12-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-013-3/+6
| | | | | * include/Makefile.am: Reformat. * tmitronsem01/Makefile.am: Remove all-local: $(ARCH).
* 2003-11-10 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-11-102-1/+5
| | | | * configure.ac: Reflect having moved to testsuites/.
* 2003-10-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-10-222-1/+4
| | | | * configure.ac: Remove RTEMS_CANONICAL_HOST.
* 2003-10-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-10-022-1/+4
| | | | * configure.ac:Remove RTEMS_CHECK_CPU.
* 2003-09-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-045-4/+9
| | | | | * include/timesys.h, tmitronsem01/init.c, tmitronsem01/system.h, tmitronsem01/tmitronsem01.doc: URL for license changed.
* 2003-08-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-182-1/+5
| | | | * Makefile.am: Reflect having moved aclocal/.
* Fix broken ChangeLog entries.Ralf Corsepius2003-08-171-3/+3
* 2003-08-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-164-6/+12
| | | | | | Makefile.am: Reflect having moved automake. include/Makefile.am: Reflect having moved automake. tmitronsem01/Makefile.am: Reflect having moved automake.
* 2003-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-112-1/+5
| | | | * configure.ac: Use rtems-bugs@rtems.com as bug report email address.
* 2003-05-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-05-272-2/+5
| | | | | * configure.ac: Remove CC_CFLAGS_DEBUG_V. CC_CFLAGS_DEFAULT (obsolete).
| | | | | * configure.ac: Remove CC_CFLAGS_PROFILE_V. Remove CC_LDFLAGS_PROFILE_V.
* Merger from rtems-4-6-branch.Ralf Corsepius2003-03-112-1/+4
* 2003-02-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-02-112-1/+5
| | | | * configure.ac: AM_INIT_AUTOMAKE([1.7.2]).
| | | | * configure.ac: AC_PREREQ(2.57).
* 2002-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-10-212-3/+9
| | | | | | * .cvsignore: Reformat. Add autom4te*cache. Remove autom4te.cache.
* 2002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-112-1/+5
| | | | * tmitronsem01/Makefile.am: Use .$(OBJEXT) instead of .o.
* 2002-08-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-08-022-1/+12
| | | | | | | | | | | * Per PR47 add support for buffered test output. This involved adding defines to redirect output to a buffer and dump it when full, at "test pause", and at exit. To avoid problems when redefining exit(), all tests were modified to call rtems_test_exit(). Some tests, notable psxtests, had to be modified to include the standard test macro .h file (pmacros.h or tmacros.h) to enable this support. * tmitronsem01/init.c: Modified.
* 2002-04-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-162-2/+4
| | | | * configure.ac: Remove ENABLE_GCC28.
* 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-03-285-5/+11
| | | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * include/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * tmitronsem01/Makefile.am: Remove AUTOMAKE_OPTIONS.
* 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-121-0/+47
| | | | | * .cvsignore: Add autom4te.cache for autoconf > 2.52. * configure.in: Remove.
* 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-112-0/+7
* 2001-09-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-242-1/+5
| | | | * tmitrontests.am: Use TMPINSTALL_FILES = to make automake-1.5 happy.
* 2001-09-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-192-1/+5
| | | | * tmitronsem01/Makefile.am: include leaf.am instead of leaf.cfg.
* 2001-05-10 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-05-101-0/+4
| | | | * configure.in: Use RTEMS_PROG_CC_FOR_TARGET([-ansi -fasm]).
* 2000-11-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-092-1/+5
* 2000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-022-1/+5
* 2000-10-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-273-2/+8
| | | | | | * Makefile.am: ACLOCAL_AMFLAGS= -I $(RTEMS_TOPdir)/macros. Switch to GNU canonicalization. * tmitrontests.am: Remove DEFS.
* 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-052-0/+5
| | | | * tmitronsem01/Makefile.am: Include compile.am
* Patch rtems-rc-20000713-1-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-07-131-0/+2
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | that is yet another multilib-related structual cleanup patch: Changes: * Make RTEMS_TEST_NO_PAUSE a tests/ subpackage specific option. - Remove RTEMS_TEST_NO_PAUSE from custom/*.cfg, targopts.h and cpuopts.h. - Add autoconf macros RTEMS_*_RTEMS_TEST_NO_PAUSE (aclocal/rtems-test-no-pause.m4). - Add RTEMS_*_RTEMS_TEST_NO_PAUSE support to sptests/configure.ins and tmtests/configure.in. These are the only subdirectories which currently apply RTEMS_TEST_NO_PAUSE. - Add autoconf-DEFS support to all test subpackages' configure.ins below tests/. I.e. AC_DEFINES now get explicitly propagated as preprocessor defines into Makefiles, cf. AM_CPPFLAGS in tests/*/*.am, instead of using a global config-files. - Remove NDEBUG from custom/*.cfg. * AC_DEFINE POSIX_API, ITRON_API and MULTIPROCESSING in exec/configure.in, only. - All other sources now should relay on the values from cpuopts.h and should not define them themselves. - Several related changes to many configure.ins * Bug-fixes to RTEMS_*_RTEMS_DEBUG macros (Actually workarounds to quoting bugs in autoconf). Notes: * This patch is rather immature and only tested for a small subset of BSPs (requires the tests to be enabled and therefore takes an tremendous amount of disc space and time.) * The patches to *cfg were generated by a script. Expect file formating changes :)
* Merged from 4.5.0-beta3aJoel Sherrill2000-06-122-6/+8
* Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.Joel Sherrill2000-04-133-0/+17
| | | | adds .cvsignore.
* Patch rtems-rc-20000118-2.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-01-311-1/+0
| | | | | that contains cosmetical changes to the Makefile.ams below tests (removes old, now invalid comments from these Makefile.ams).
* Uncommitted remains of a previous patch from Ralf CorsepiusJoel Sherrill1999-11-302-0/+56
| | | | <corsepiu@faw.uni-ulm.de> which converted fiels to automake.
* Patch rtems-rc-19991123-rc-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1999-11-292-10/+5
| | | | | | | | | | | | | | | | | | | | | | | which (among other things) converted the mptests to automake. SUB_DIRS was used instead of SUBDIRS in some Makefile.ins (apparently a leftover from moving the start* directories) Addtional major bugs: * psxtests/include was empty (incomplete psxtests changes). * bogus handling of *.scn in itrontests (screens/sptests vs. screens/itrontests installation dirs) In addition I have added a few more changes (I couldn't resist) * automake support for itrontests * OPERATION_COUNT support in tmitrontests/ * automake support for tmitrontests * automake suppport for mptests * Some (minor) corrections to several configure.in/Makefile.ams => c/src/tests/ is completly under automake control, now. => we could start to sort out the structural issues with c/src/tests (tests/support, stubdr, tools, get "make dist" working)
* + Updated copyright information.Jennifer Averett1999-11-173-4/+5
* This patch adds the basic framework for the ITRON 3.0 API implementationJoel Sherrill1999-11-097-0/+280
for RTEMS.
