* | Remove (Abandoned) | Ralf Corsepius | 2010-06-17 | 11 | -609/+0 |
* | 2009-12-08 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-12-08 | 2 | -2/+7 |
| | | | | | | * tmitronsem01/system.h: Use rtems_test_assert() consistently instead of system assert(). rtems_test_assert() is designed to integrate into the RTEMS test suite infrastructure. | ||||
* | 2009-10-30 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-30 | 1 | -0/+4 |
| | | | | * include/timesys.h: Use PRId32. | ||||
* | Use PRId32. | Ralf Corsepius | 2009-10-30 | 1 | -1/+1 |
* | 2009-10-20 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-20 | 2 | -1/+5 |
| | | | | * configure.ac: Don't add -ansi -fasm to CFLAGS. | ||||
* | Eliminate _exe_/.exe. | Ralf Corsepius | 2009-04-03 | 1 | -7/+7 |
* | 2009-04-03 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-04-03 | 1 | -0/+4 |
| | | | | * tmitronsem01/Makefile.am: Makefile.am: Eliminate _exe_/.exe. | ||||
* | 2008-09-17 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-09-17 | 2 | -1/+6 |
| | | | | | * include/timesys.h: Rename STACK_CHECKER_ON to more appropriate CONFIGURE_STACK_CHECKER_ENABLED. | ||||
* | 2008-08-31 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-08-31 | 3 | -13/+19 |
| | | | | | * tmitronsem01/Makefile.am, tmitronsem01/init.c: Eliminate empty function from every benchmark timer driver. Fix spelling. | ||||
* | 2008-01-31 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-02-01 | 2 | -1/+7 |
| | | | | | | * tmitronsem01/init.c: Change TEST_INIT to CONFIGURE_INIT. Make tmacros.h available to all POSIX tests. Add a clock_settime case for < 1988. | ||||
* | 2006-12-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-12-02 | 2 | -1/+5 |
| | | | | * configure.ac: New BUG-REPORT address. | ||||
* | 2006-10-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-10-17 | 2 | -2/+6 |
| | | | | * configure.ac: Require autoconf-2.60. Require automake-1.10. | ||||
* | Eliminate scndir, docdir. Use rtems_testsdir instead. | Ralf Corsepius | 2006-07-11 | 1 | -2/+1 |
* | 2006-07-11 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-07-11 | 1 | -0/+5 |
| | | | | | * tmitronsem01/Makefile.am: Eliminate scndir, docdir. Use rtems_testsdir instead. | ||||
* | 2005-11-22 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-22 | 2 | -3/+5 |
| | | | | | * configure.ac: Remove RTEMS_ENABLE_BARE, BARE_CPU_CFLAGS, BARE_CPU_MODEL. | ||||
* | Fix my email address | Ralf Corsepius | 2005-11-13 | 1 | -5/+5 |
* | Convert to using *_PROGRAMS. | Ralf Corsepius | 2005-11-13 | 1 | -11/+8 |
* | 2005-11-13 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-13 | 1 | -0/+4 |
| | | | | * tmitronsem01/Makefile.am: Convert to using *_PROGRAMS. | ||||
* | Fix typos. | Ralf Corsepius | 2005-11-11 | 1 | -1/+1 |
* | * tmitronsem01/Makefile.am: Rework. | Ralf Corsepius | 2005-11-11 | 1 | -0/+4 |
* | Rework. | Ralf Corsepius | 2005-11-11 | 1 | -22/+6 |
* | Cosmetics. | Ralf Corsepius | 2005-11-11 | 1 | -3/+0 |
* | Eliminate TEST. | Ralf Corsepius | 2005-11-11 | 1 | -5/+4 |
* | Expand tmitrontests.am. | Ralf Corsepius | 2005-11-11 | 1 | -2/+13 |
* | Remove. | Ralf Corsepius | 2005-11-11 | 1 | -15/+0 |
* | 2005-11-11 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-11 | 1 | -0/+5 |
| | | | | | * tmitrontests.am: Remove. * tmitronsem01/Makefile.am: Expand tmitrontests.am. | ||||
* | Eliminate DOCTYPES. | Ralf Corsepius | 2005-11-10 | 1 | -2/+1 |
* | AM_CPPFLAGS += -I..../support/include. | Ralf Corsepius | 2005-11-09 | 1 | -0/+2 |
* | 2005-11-09 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-09 | 1 | -0/+4 |
| | | | | * tmitronsem01/Makefile.am: AM_CPPFLAGS += -I..../support/include. | ||||
* | 2005-11-09 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-09 | 2 | -1/+5 |
| | | | | * tmitrontests.am: Set project_bspdir=$(PROJECT_ROOT) | ||||
* | 2005-11-07 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-07 | 2 | -2/+6 |
| | | | | * tmitrontests.am: Remove LIB_VARIANT. | ||||
* | Remove SRC, PRINT_SRC. | Ralf Corsepius | 2005-11-07 | 1 | -2/+0 |
* | * tmitronsem01/Makefile.am: Remove SRC, PRINT_SRC. | Ralf Corsepius | 2005-11-07 | 1 | -0/+4 |
* | Switch back to include compile.am instead of amcompile.am | Ralf Corsepius | 2005-11-07 | 1 | -1/+1 |
* | 2005-11-07 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-07 | 2 | -2/+4 |
| | | | | * Makefile.am: Cleanup. | ||||
* | Add $(PGM): ${ARCH}/$(dirstamp). | Ralf Corsepius | 2005-11-07 | 1 | -0/+2 |
* | 2005-11-07 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-07 | 1 | -0/+6 |
| | | | | | | * tmitrontests.am: Add $(PGM): ${ARCH}/$(dirstamp). * tmitronsem01/Makefile.am: Partial conversion to automake. | ||||
* | Partial conversion to automake. | Ralf Corsepius | 2005-11-07 | 1 | -9/+6 |
* | Fix typo in previous change. | Ralf Corsepius | 2004-09-24 | 1 | -1/+1 |
* | 2004-09-24 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-09-24 | 2 | -1/+5 |
| | | | | * configure.ac: Require automake > 1.9. | ||||
* | Remove stray white spaces. | Ralf Corsepius | 2004-04-20 | 2 | -4/+4 |
* | * tmitronsem01/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. | Ralf Corsepius | 2004-04-01 | 2 | -1/+5 |
* | 2004-04-01 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-04-01 | 2 | -1/+5 |
| | | | | * tmitronsem01/system.h: Include <rtems/itron.h> instead of <itron.h>. | ||||
* | 2004-03-30 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-03-30 | 2 | -2/+6 |
| | | | | * include/timesys.h: Convert to using c99 fixed size types. | ||||
* | 2004-03-26 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-03-26 | 5 | -12/+8 |
| | | | | | | * include/Makefile.am: Remove. * Makefile.am: Merge-in include/Makefile.am. * configure.ac: Reflect changes above. | ||||
* | 2004-03-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-03-25 | 2 | -1/+5 |
| | | | | * configure.ac: Add 2nd arg to RTEMS_TOP. | ||||
* | 2004-01-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-01-14 | 2 | -0/+7 |
| | | | | | * tmitronsem01/Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES. Add PRE/TMPINSTALL_FILES to CLEANFILES. | ||||
* | 2003-12-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-18 | 2 | -4/+8 |
| | | | | * tmitrontests.am: Add dirstamp support. | ||||
* | 2003-12-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-17 | 2 | -1/+5 |
| | | | | * tmitrontests.am: Use $(mkdir_p) instead of $(mkinstalldirs). | ||||
* | 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-12 | 2 | -2/+6 |
| | | | | * configure.ac: Require automake >= 1.8, autoconf >= 2.59. |
