path: root/testsuites/tmitrontests (follow)
* 2009-10-20 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-10-202-1/+5
| | | | * configure.ac: Don't add -ansi -fasm to CFLAGS.
* Eliminate _exe_/.exe.Ralf Corsepius2009-04-031-7/+7
* 2009-04-03 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-04-031-0/+4
| | | | * tmitronsem01/Makefile.am: Makefile.am: Eliminate _exe_/.exe.
* 2008-09-17 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-09-172-1/+6
| | | | | * include/timesys.h: Rename STACK_CHECKER_ON to more appropriate CONFIGURE_STACK_CHECKER_ENABLED.
* 2008-08-31 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-08-313-13/+19
| | | | | * tmitronsem01/Makefile.am, tmitronsem01/init.c: Eliminate empty function from every benchmark timer driver. Fix spelling.
* 2008-01-31 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2008-02-012-1/+7
| | | | | | * tmitronsem01/init.c: Change TEST_INIT to CONFIGURE_INIT. Make tmacros.h available to all POSIX tests. Add a clock_settime case for < 1988.
* 2006-12-02 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2006-12-022-1/+5
| | | | * configure.ac: New BUG-REPORT address.
* 2006-10-17 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2006-10-172-2/+6
| | | | * configure.ac: Require autoconf-2.60. Require automake-1.10.
* Eliminate scndir, docdir. Use rtems_testsdir instead.Ralf Corsepius2006-07-111-2/+1
* 2006-07-11 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2006-07-111-0/+5
| | | | | * tmitronsem01/Makefile.am: Eliminate scndir, docdir. Use rtems_testsdir instead.
* 2005-11-22 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-11-222-3/+5
| | | | | * configure.ac: Remove RTEMS_ENABLE_BARE, BARE_CPU_CFLAGS, BARE_CPU_MODEL.
* Fix my email addressRalf Corsepius2005-11-131-5/+5
* Convert to using *_PROGRAMS.Ralf Corsepius2005-11-131-11/+8
* 2005-11-13 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-11-131-0/+4
| | | | * tmitronsem01/Makefile.am: Convert to using *_PROGRAMS.
* Fix typos.Ralf Corsepius2005-11-111-1/+1
* * tmitronsem01/Makefile.am: Rework.Ralf Corsepius2005-11-111-0/+4
* Rework.Ralf Corsepius2005-11-111-22/+6
* Cosmetics.Ralf Corsepius2005-11-111-3/+0
* Eliminate TEST.Ralf Corsepius2005-11-111-5/+4
* Expand tmitrontests.am.Ralf Corsepius2005-11-111-2/+13
* Remove.Ralf Corsepius2005-11-111-15/+0
* 2005-11-11 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-11-111-0/+5
| | | | | * tmitrontests.am: Remove. * tmitronsem01/Makefile.am: Expand tmitrontests.am.
* Eliminate DOCTYPES.Ralf Corsepius2005-11-101-2/+1
* AM_CPPFLAGS += -I..../support/include.Ralf Corsepius2005-11-091-0/+2
* 2005-11-09 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-11-091-0/+4
| | | | * tmitronsem01/Makefile.am: AM_CPPFLAGS += -I..../support/include.
* 2005-11-09 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-11-092-1/+5
| | | | * tmitrontests.am: Set project_bspdir=$(PROJECT_ROOT)
* 2005-11-07 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-11-072-2/+6
| | | | * tmitrontests.am: Remove LIB_VARIANT.
* Remove SRC, PRINT_SRC.Ralf Corsepius2005-11-071-2/+0
* * tmitronsem01/Makefile.am: Remove SRC, PRINT_SRC.Ralf Corsepius2005-11-071-0/+4
* Switch back to include compile.am instead of amcompile.amRalf Corsepius2005-11-071-1/+1
* 2005-11-07 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-11-072-2/+4
| | | | * Makefile.am: Cleanup.
* Add $(PGM): ${ARCH}/$(dirstamp).Ralf Corsepius2005-11-071-0/+2
* 2005-11-07 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-11-071-0/+6
| | | | | | * tmitrontests.am: Add $(PGM): ${ARCH}/$(dirstamp). * tmitronsem01/Makefile.am: Partial conversion to automake.
* Partial conversion to automake.Ralf Corsepius2005-11-071-9/+6
* Fix typo in previous change.Ralf Corsepius2004-09-241-1/+1
* 2004-09-24 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-09-242-1/+5
| | | | * configure.ac: Require automake > 1.9.
* Remove stray white spaces.Ralf Corsepius2004-04-202-4/+4
* * tmitronsem01/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.Ralf Corsepius2004-04-012-1/+5
* 2004-04-01 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-04-012-1/+5
| | | | * tmitronsem01/system.h: Include <rtems/itron.h> instead of <itron.h>.
* 2004-03-30 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-03-302-2/+6
| | | | * include/timesys.h: Convert to using c99 fixed size types.
* 2004-03-26 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-03-265-12/+8
| | | | | | * include/Makefile.am: Remove. * Makefile.am: Merge-in include/Makefile.am. * configure.ac: Reflect changes above.
* 2004-03-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-03-252-1/+5
| | | | * configure.ac: Add 2nd arg to RTEMS_TOP.
* 2004-01-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-142-0/+7
| | | | | * tmitronsem01/Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES. Add PRE/TMPINSTALL_FILES to CLEANFILES.
* 2003-12-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-182-4/+8
| | | | * tmitrontests.am: Add dirstamp support.
* 2003-12-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-172-1/+5
| | | | * tmitrontests.am: Use $(mkdir_p) instead of $(mkinstalldirs).
* 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-122-2/+6
| | | | * configure.ac: Require automake >= 1.8, autoconf >= 2.59.
* 2003-12-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-013-3/+6
| | | | | * include/Makefile.am: Reformat. * tmitronsem01/Makefile.am: Remove all-local: $(ARCH).
* 2003-11-10 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-11-102-1/+5
| | | | * configure.ac: Reflect having moved to testsuites/.
* 2003-10-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-10-222-1/+4
| | | | * configure.ac: Remove RTEMS_CANONICAL_HOST.
* 2003-10-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-10-022-1/+4
| | | | * configure.ac:Remove RTEMS_CHECK_CPU.
