path: root/testsuites/tmitrontests (follow)
* 2000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-022-1/+5
* 2000-10-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-273-2/+8
| | | | | | * Makefile.am: ACLOCAL_AMFLAGS= -I $(RTEMS_TOPdir)/macros. Switch to GNU canonicalization. * tmitrontests.am: Remove DEFS.
* 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-052-0/+5
| | | | * tmitronsem01/Makefile.am: Include compile.am
* Patch rtems-rc-20000713-1-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-07-131-0/+2
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | that is yet another multilib-related structual cleanup patch: Changes: * Make RTEMS_TEST_NO_PAUSE a tests/ subpackage specific option. - Remove RTEMS_TEST_NO_PAUSE from custom/*.cfg, targopts.h and cpuopts.h. - Add autoconf macros RTEMS_*_RTEMS_TEST_NO_PAUSE (aclocal/rtems-test-no-pause.m4). - Add RTEMS_*_RTEMS_TEST_NO_PAUSE support to sptests/configure.ins and tmtests/configure.in. These are the only subdirectories which currently apply RTEMS_TEST_NO_PAUSE. - Add autoconf-DEFS support to all test subpackages' configure.ins below tests/. I.e. AC_DEFINES now get explicitly propagated as preprocessor defines into Makefiles, cf. AM_CPPFLAGS in tests/*/*.am, instead of using a global config-files. - Remove NDEBUG from custom/*.cfg. * AC_DEFINE POSIX_API, ITRON_API and MULTIPROCESSING in exec/configure.in, only. - All other sources now should relay on the values from cpuopts.h and should not define them themselves. - Several related changes to many configure.ins * Bug-fixes to RTEMS_*_RTEMS_DEBUG macros (Actually workarounds to quoting bugs in autoconf). Notes: * This patch is rather immature and only tested for a small subset of BSPs (requires the tests to be enabled and therefore takes an tremendous amount of disc space and time.) * The patches to *cfg were generated by a script. Expect file formating changes :)
* Merged from 4.5.0-beta3aJoel Sherrill2000-06-122-6/+8
* Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.Joel Sherrill2000-04-133-0/+17
| | | | adds .cvsignore.
* Patch rtems-rc-20000118-2.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-01-311-1/+0
| | | | | that contains cosmetical changes to the Makefile.ams below tests (removes old, now invalid comments from these Makefile.ams).
* Uncommitted remains of a previous patch from Ralf CorsepiusJoel Sherrill1999-11-302-0/+56
| | | | <corsepiu@faw.uni-ulm.de> which converted fiels to automake.
* Patch rtems-rc-19991123-rc-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1999-11-292-10/+5
| | | | | | | | | | | | | | | | | | | | | | | which (among other things) converted the mptests to automake. SUB_DIRS was used instead of SUBDIRS in some Makefile.ins (apparently a leftover from moving the start* directories) Addtional major bugs: * psxtests/include was empty (incomplete psxtests changes). * bogus handling of *.scn in itrontests (screens/sptests vs. screens/itrontests installation dirs) In addition I have added a few more changes (I couldn't resist) * automake support for itrontests * OPERATION_COUNT support in tmitrontests/ * automake support for tmitrontests * automake suppport for mptests * Some (minor) corrections to several configure.in/Makefile.ams => c/src/tests/ is completly under automake control, now. => we could start to sort out the structural issues with c/src/tests (tests/support, stubdr, tools, get "make dist" working)
* + Updated copyright information.Jennifer Averett1999-11-173-4/+5
* This patch adds the basic framework for the ITRON 3.0 API implementationJoel Sherrill1999-11-097-0/+280
for RTEMS.
