PR 1964
* spchain/init.c, spchain/spchain.scn: Add testcases for chain is first
and last
* sp04/tswitch.c, sp07/task1.c, sp07/task2.c, sp09/screen07.c,
sp11/task1.c, sp11/task2.c, sp12/pridrv.c, sp12/pritask.c,
sp13/task1.c, sp14/asr.c, sp14/task1.c, sp19/first.c, sp19/fptask.c,
sp19/inttest.h, sp19/task1.c, sp20/task1.c, sp25/task1.c,
sp26/task1.c, sp28/init.c, sp29/init.c, sp31/task1.c, sp32/init.c,
sp33/init.c, sp34/changepri.c, sp36/strict_order_mut.c, sp37/init.c,
sp43/init.c, sp44/init.c, sp48/init.c, sp54/init.c, sp59/init.c,
sp65/init.c, sp68/init.c, spchain/init.c, spclockget/init.c,
spfatal03/testcase.h, spfatal07/testcase.h, spfatal_support/init.c:
Do not line length exceed 80 columns.
* spchain/init.c: Improve coverage testing.
* spchain/init.c: Added test case.
* spchain/init.c, spchain/spchain.scn: More test cases.
* spchain/init.c: Attempt to improve coverage.
* spchain/init.c, spwatchdog/task1.c: Do not violate chain API.
* spchain/init.c, spchain/spchain.doc, spchain/spchain.scn: New test
cases.
* sp51/init.c, sp54/Makefile.am, sp55/Makefile.am, sp56/Makefile.am,
sp57/Makefile.am, spchain/Makefile.am, spfatal10/Makefile.am,
spfatal11/Makefile.am, spfatal12/Makefile.am: Remove unneeded
USE_TIMER_SERVER which was copied fomr other Makefile.am's.
* spchain/init.c, spchain/spchain.scn: Clean up test.
* Makefile.am, configure.ac: Add new test to cover bodies of some chain
routines whose bodies are not used by RTEMS itself.
* spchain/.cvsignore, spchain/Makefile.am, spchain/init.c,
spchain/spchain.doc, spchain/spchain.scn: New files.
