Enable the SMP configuration by default in case SMP is enabled. Add
configuration option CONFIGURE_DISABLE_SMP_CONFIGURATION to disable it
explicitly.
Add CONFIGURE_DISABLE_SMP_CONFIGURATION to all test which would fail
otherwise.
Update #3001.
Fix things broken by commit d5154d0f6a04f3b7ed59d9a09038576fe2640756.
Update #2493.
Notepads where a feature of RTEMS' tasks that simply functioned in
the same way as POSIX keys or threaded local storage (TLS). They were
introduced well before per task variables, which are also deprecated,
and were barely used in favor of their POSIX alternatives.
In addition to their scarce usage, Notepads took up unnecessary memory.
For each task:
- 16 32-bit integers were allocated.
- A total of 64 bytes per task per thread.
This is especially critical in low memory and safety-critical applications.
They are also defined as uint32_t, and therefore are not guaranteed to
hold a pointer.
Lastly, they are not portable solutions for SMP and uniprocessor systems,
like POSIX keys and TLS.
updates #2493.
Use of deprecated notepads in sp07 needs further work.
Updates #2305.
Deprecate Classic API Notepads. Mark task_set/get_note() with
the deprecated attribute, and also mark the notepads field.
Replace disable with enable option for notepads in confdefs.h,
and make notepads disabled by default. The previous option
CONFIGURE_DISABLE_CLASSIC_API_NOTEPADS is now unused and
will emit a compile-time warning. A new option
CONFIGURE_ENABLE_CLASSIC_API_NOTEPADS is available to turn
on notepads, but it also will emit a compile-time warning
to indicate that notepads are deprecated.
Closes #2265
Do not use sprintf() in thread dispatch critical sections to avoid
corruption of profiling samples. Update test to reflect thread the life
cycle changes.
Correct the sp02.doc, sp05.doc, sp06.doc, sp07.doc, sp08.doc files.
for details.
Date and ownership determined from file history.
PR 1589/build
sp10/Makefile.am, sp11/Makefile.am, sp12/Makefile.am,
sp13/Makefile.am, sp14/Makefile.am, sp15/Makefile.am,
sp16/Makefile.am, sp17/Makefile.am, sp18/Makefile.am,
sp19/Makefile.am, sp20/Makefile.am, sp2038/Makefile.am,
sp27/Makefile.am, sp27a/Makefile.am, sp28/Makefile.am,
sp29/Makefile.am, sp30/Makefile.am, sp31/Makefile.am,
sp32/Makefile.am, sp33/Makefile.am, sp34/Makefile.am,
sp35/Makefile.am, sp36/Makefile.am, sp37/Makefile.am,
sp38/Makefile.am, sp39/Makefile.am, sp40/Makefile.am,
sp41/Makefile.am, sp42/Makefile.am, sp43/Makefile.am,
sp44/Makefile.am, sp45/Makefile.am, sp46/Makefile.am,
sp47/Makefile.am, sp48/Makefile.am, sp49/Makefile.am,
sp50/Makefile.am, sp51/Makefile.am, sp52/Makefile.am,
sp53/Makefile.am, sp54/Makefile.am, sp55/Makefile.am,
sp56/Makefile.am, sp57/Makefile.am, sp58/Makefile.am,
sp59/Makefile.am, sp60/Makefile.am, sp62/Makefile.am,
sp63/Makefile.am, sp64/Makefile.am, sp65/Makefile.am,
sp66/Makefile.am, sp67/Makefile.am, sp68/Makefile.am,
sp69/Makefile.am, sp70/Makefile.am, sp71/Makefile.am,
sp72/Makefile.am, sp73/Makefile.am, sp74/Makefile.am,
sp75/Makefile.am, sp76/Makefile.am, spassoc01/Makefile.am,
spcbssched01/Makefile.am, spcbssched02/Makefile.am,
spcbssched03/Makefile.am, spchain/Makefile.am,
spclockget/Makefile.am, spcoverage/Makefile.am,
spedfsched01/Makefile.am, spedfsched02/Makefile.am,
spedfsched03/Makefile.am, sperror01/Makefile.am,
sperror02/Makefile.am, sperror03/Makefile.am, spfatal01/Makefile.am,
spfatal02/Makefile.am, spfatal03/Makefile.am, spfatal04/Makefile.am,
spfatal05/Makefile.am, spfatal06/Makefile.am, spfatal07/Makefile.am,
spfatal08/Makefile.am, spfatal09/Makefile.am, spfatal10/Makefile.am,
spfatal11/Makefile.am, spfatal12/Makefile.am, spfatal13/Makefile.am,
spfatal14/Makefile.am, spfatal15/Makefile.am, spfatal16/Makefile.am,
spfatal17/Makefile.am, spfatal18/Makefile.am, spfatal19/Makefile.am,
spfatal20/Makefile.am, spfatal21/Makefile.am, spfatal22/Makefile.am,
spfatal23/Makefile.am, spfatal24/Makefile.am, spfatal25/Makefile.am,
spfifo01/Makefile.am, spfifo02/Makefile.am, spfifo03/Makefile.am,
spfifo04/Makefile.am, spfifo05/Makefile.am, spheapprot/Makefile.am,
spintrcritical01/Makefile.am, spintrcritical02/Makefile.am,
spintrcritical03/Makefile.am, spintrcritical04/Makefile.am,
spintrcritical05/Makefile.am, spintrcritical06/Makefile.am,
spintrcritical07/Makefile.am, spintrcritical08/Makefile.am,
spintrcritical09/Makefile.am, spintrcritical10/Makefile.am,
spintrcritical11/Makefile.am, spintrcritical12/Makefile.am,
spintrcritical13/Makefile.am, spintrcritical14/Makefile.am,
spintrcritical15/Makefile.am, spintrcritical16/Makefile.am,
spintrcritical17/Makefile.am, spmkdir/Makefile.am,
spmountmgr01/Makefile.am, spnotepad01/Makefile.am,
spnsext01/Makefile.am, spobjgetnext/Makefile.am,
spprintk/Makefile.am, spprivenv01/Makefile.am,
sprbtree01/Makefile.am, spsimplesched01/Makefile.am,
spsimplesched02/Makefile.am, spsimplesched03/Makefile.am,
spsize/Makefile.am, spstkalloc/Makefile.am, spthreadq01/Makefile.am,
spwatchdog/Makefile.am, spwkspace/Makefile.am: Remove obsolete
optional manager capability.
* sp04/tswitch.c, sp07/task1.c, sp07/task2.c, sp09/screen07.c,
sp11/task1.c, sp11/task2.c, sp12/pridrv.c, sp12/pritask.c,
sp13/task1.c, sp14/asr.c, sp14/task1.c, sp19/first.c, sp19/fptask.c,
sp19/inttest.h, sp19/task1.c, sp20/task1.c, sp25/task1.c,
sp26/task1.c, sp28/init.c, sp29/init.c, sp31/task1.c, sp32/init.c,
sp33/init.c, sp34/changepri.c, sp36/strict_order_mut.c, sp37/init.c,
sp43/init.c, sp44/init.c, sp48/init.c, sp54/init.c, sp59/init.c,
sp65/init.c, sp68/init.c, spchain/init.c, spclockget/init.c,
spfatal03/testcase.h, spfatal07/testcase.h, spfatal_support/init.c:
Do not line length exceed 80 columns.
* sp07/init.c: Improve coverage.
char arrays.
* sp07/init.c, sp07/sp07.scn, sp09/init.c, sp09/screen01.c,
sp09/sp09.scn, sp28/init.c, sp62/init.c, sp62/sp62.scn, sp64/init.c,
sp64/sp64.scn: Add more test cases highlighted on SPARC at -O2, x86
at -Os and m68k at -Os. Fix typos.
* sp04/tswitch.c, sp07/system.h, sp07/taskexit.c, sp07/tdelete.c,
sp07/tstart.c, spfatal_support/init.c, spfatal_support/system.h:
Eliminate use of deprecated rtems_extension.
* sp04/system.h, sp04/task1.c, sp04/tswitch.c, sp07/init.c,
sp12/init.c, sp13/putbuff.c, sp13/system.h, sp13/task1.c,
sp15/init.c, sp16/system.h, sp19/fptask.c, sp25/system.h,
sp26/task1.c, sp27/init.c, sp28/init.c, sp29/init.c, sp31/task1.c,
sp33/init.c, sp34/changepri.c, sp35/priinv.c, sp37/init.c,
sp38/init.c, sp39/init.c, sp41/init.c, sp42/init.c, sp43/init.c,
sp44/init.c, sp45/init.c, sp46/init.c, sp47/init.c, sp48/init.c,
spfatal03/testcase.h, spfatal05/testcase.h, spfatal06/testcase.h,
spfatal_support/system.h, spobjgetnext/init.c, spsize/getint.c,
spsize/size.c: Fix warnings.
* sp07/init.c, sp12/init.c, sp12/pridrv.c, sp12/pritask.c,
sp12/system.h, sp16/system.h, sp25/system.h, sp26/task1.c,
sp28/init.c, sp29/init.c, sp35/priinv.c, sp42/init.c: Run all tests
successfully with maxixum number of priorities as 16 instead of 256.
This was done by temporarily modifying the score priority.h maximum.
This allowed testing of all API code to ensure that it worked
properly with a reduced number of priorities. Most modifications were
to switch from hard-coded maximum to using the API provided methods
to determine maximum number of priority levels.
* sp07/system.h, sp07/tcreate.c: Convert to bool type.
* sp01/init.c, sp02/init.c, sp03/init.c, sp04/init.c, sp05/init.c,
sp06/init.c, sp07/init.c, sp08/init.c, sp09/init.c, sp11/init.c,
sp12/init.c, sp13/init.c, sp14/init.c, sp15/init.c, sp16/init.c,
sp17/init.c, sp19/init.c, sp20/init.c, sp21/init.c, sp22/init.c,
sp23/init.c, sp24/init.c, sp25/init.c, sp26/init.c, sp28/init.c,
sp30/init.c, sp31/init.c, sp32/init.c, sp33/init.c, sp37/init.c,
sp38/init.c, sp39/init.c, sp40/init.c, sp41/init.c, sp43/init.c,
spfatal/init.c, spfatal_support/init.c, spsize/init.c: Change
TEST_INIT to CONFIGURE_INIT. Make tmacros.h available to all POSIX
tests. Add a clock_settime case for < 1988.
* sp07/task1.c, sp34/changepri.c, sp35/priinv.c: Add rtems_task_self()
directive instead of violating RTEMS internals.
* sp07/init.c, sp07/system.h, sp07/tdelete.c, sp07/sp07.scn:
Add test cases for User Extension Manager to improve code coverage.
* sp21/task1.c: Fix spelling error.
* sp07/init.c, sp07/sp07.scn, sp07/task1.c: Add tests for
using notepad with the current task's ID or SELF
* sp09/screen02.c, sp09/screen04.c, sp09/sp09.scn: Add
test missing test cases for clock_get.
* sp07/sp07.scn, sp07/task1.c, sp09/screen01.c, sp09/screen05.c,
sp09/screen07.c, sp09/screen10.c, sp09/screen12.c, sp09/screen14.c,
sp09/sp09.scn, sp25/sp25.scn, sp25/task1.c: Added several test cases
to improve test coverage.
sp07/Makefile.am, sp07/tdelete.c, sp08/Makefile.am, sp09/Makefile.am,
sp35/Makefile.am, spfatal/Makefile.am, spsize/Makefile.am,
spsize/size.c: Add optional managers to Makefiles. Clean up test
cases so last output line follows END OF pattern. Make sure test case
all run. All tests appeared ok on sis.
* sp02/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp03/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp04/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp05/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp06/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp07/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp08/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp09/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp11/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp12/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp13/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp14/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp15/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp16/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp17/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp19/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp20/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp21/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp22/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp23/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp24/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp25/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp26/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp27/init.c: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp28/init.c: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp29/init.c: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp30/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp31/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp32/init.c: Include <rtems/confdefs.h> instead of <confdefs.h>.
* spfatal/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* spsize/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp07/buffered_io.c: Include <rtems/ringbuf.h> instead of <ringbuf.h>.
* sp07/buffered_io.c: Remove warning.
* sp01/Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES.
* sp02/Makefile.am: Ditto.
* sp03/Makefile.am: Ditto.
* sp04/Makefile.am: Ditto.
* sp05/Makefile.am: Ditto.
* sp06/Makefile.am: Ditto.
* sp07/Makefile.am: Ditto.
* sp08/Makefile.am: Ditto.
* sp09/Makefile.am: Ditto.
* sp11/Makefile.am: Ditto.
* sp12/Makefile.am: Ditto.
* sp13/Makefile.am: Ditto.
* sp14/Makefile.am: Ditto.
* sp15/Makefile.am: Ditto.
* sp16/Makefile.am: Ditto.
* sp17/Makefile.am: Ditto.
* sp19/Makefile.am: Ditto.
* sp20/Makefile.am: Ditto.
* sp21/Makefile.am: Ditto.
* sp22/Makefile.am: Ditto.
* sp23/Makefile.am: Ditto.
* sp24/Makefile.am: Ditto.
* sp25/Makefile.am: Ditto.
* sp26/Makefile.am: Ditto.
* sp27/Makefile.am: Ditto.
* sp28/Makefile.am: Ditto.
* sp29/Makefile.am: Ditto.
* sp30/Makefile.am: Ditto.
* sp31/Makefile.am: Ditto.
* sp32/Makefile.am: Ditto.
* spfatal/Makefile.am: Ditto.
* spsize/Makefile.am: Ditto.
PR 544/tests
* sp07/Makefile.am, sp07/init.c, sp07/system.h, sp07/task4.c,
sp07/tcreate.c, sp07/tdelete.c, sp07/trestart.c, sp07/tstart.c,
sp09/system.h, sp19/system.h, sp20/system.h: Various modifications to
make tests account for resources and not print at inappropriate
times.
* sp07/buffered_io.c: New file.
* sp01/Makefile.am: Remove all-local: $(ARCH).
* sp02/Makefile.am: Remove all-local: $(ARCH).
* sp03/Makefile.am: Remove all-local: $(ARCH).
* sp04/Makefile.am: Remove all-local: $(ARCH).
* sp05/Makefile.am: Remove all-local: $(ARCH).
* sp06/Makefile.am: Remove all-local: $(ARCH).
* sp07/Makefile.am: Remove all-local: $(ARCH).
* sp08/Makefile.am: Remove all-local: $(ARCH).
* sp09/Makefile.am: Remove all-local: $(ARCH).
* sp11/Makefile.am: Remove all-local: $(ARCH).
* sp12/Makefile.am: Remove all-local: $(ARCH).
* sp13/Makefile.am: Remove all-local: $(ARCH).
* sp14/Makefile.am: Remove all-local: $(ARCH).
* sp15/Makefile.am: Remove all-local: $(ARCH).
* sp16/Makefile.am: Remove all-local: $(ARCH).
* sp17/Makefile.am: Remove all-local: $(ARCH).
* sp19/Makefile.am: Remove all-local: $(ARCH).
* sp20/Makefile.am: Remove all-local: $(ARCH).
* sp21/Makefile.am: Remove all-local: $(ARCH).
* sp22/Makefile.am: Remove all-local: $(ARCH).
* sp23/Makefile.am: Remove all-local: $(ARCH).
* sp24/Makefile.am: Remove all-local: $(ARCH).
* sp25/Makefile.am: Remove all-local: $(ARCH).
* sp26/Makefile.am: Remove all-local: $(ARCH).
* sp27/Makefile.am: Remove all-local: $(ARCH).
* sp28/Makefile.am: Remove all-local: $(ARCH).
* sp29/Makefile.am: Remove all-local: $(ARCH).
* sp30/Makefile.am: Remove all-local: $(ARCH).
* sp31/Makefile.am: Remove all-local: $(ARCH).
* sp32/Makefile.am: Remove all-local: $(ARCH).
* spfatal/Makefile.am: Remove all-local: $(ARCH).
* spsize/Makefile.am: Remove all-local: $(ARCH).
