for details.
* configure.ac: Check for size of time_t.
* configure.ac: Add AC_CONFIG_HEADER(config.h).
* fileio/Makefile.am: Remove AM_CONDITIONAL(LIBCHIP).
* configure.ac: Remove AM_CONDITIONAL(LIBCHIP).
Force autoconf-2.67, automake-1.11.1.
* Makefile.am, README, configure.ac, capture/.cvsignore,
capture/Makefile.am, capture/capture.doc, capture/capture.scn,
capture/init.c, capture/system.h, capture/test1.c: Add a sample
test for the capture engine.
* Makefile.am, configure.ac: Convert from Classic API style TOD_Control
as fundamental time structure to POSIX struct timespec. Add
clock_get_uptime().
* nsecs/.cvsignore, nsecs/Makefile.am, nsecs/init.c, nsecs/nsecs.doc,
nsecs/nsecs.scn: New files.
* configure.ac: Remove RTEMS_ENABLE_BARE,
BARE_CPU_CFLAGS, BARE_CPU_MODEL.
* configure.ac: Apply RTEMS_CHECK_CPUOPTS.
* configure.ac: Add CXX-checks. New conditionals CXXTESTS, MPTESTS,
NETTESTS. Add iostream/.
* Makefile.am, base_mp/node1/Makefile.am, base_mp/node2/Makefile.am
cdtest/Makefile.am, loopback/Makefile.am, pppd/Makefile.am:
Reflect changes above.
* cdtest/main.cc: Adaptation to new C++ standards.
* configure.ac: Add 2nd arg to RTEMS_TOP.
* configure.ac: Remove -Wall -ansi to work-around non-portability of
with cdtest.
* configure.ac: Reflect having moved to testsuites/.
* configure.ac: Add AM_CONDITIONAL(LIBCHIP).
* fileio/Makefile.am: Only build if LIBCHIP is available.
* configure.ac: Remove RTEMS_CANONICAL_HOST.
* configure.ac:Remove RTEMS_CHECK_CPU.
PR 369/filesystem
* Makefile.am, configure.ac: sample application to show the use of the
DOSFS functions
* fileio/Makefile.am, fileio/fileio.doc, fileio/init.c,
fileio/system.h: New files.
* configure.ac: Add pppd.
* Makefile.am: Add pppd.
* Makefile.am, configure.ac: Added new test loopback which shows how to
use the loopback interface. Thank you Eric Norum for a portable
target independent test which exercises the TCP/IP. This should
prevent massive failures in the TCP/IP stack from reaching the
street.
* loopback/.cvsignore, loopback/Makefile.am, loopback/README,
loopback/init.c, loopback/loopback.scn: New files.
* configure.ac: Unconditionally check for CXX (Hack to bug in
autoconf > 2.54).
* base_mp/node1/Makefile.am: Remove AUTOMAKE_OPTIONS.
* base_mp/Makefile.am: Remove AUTOMAKE_OPTIONS.
* base_mp/node2/Makefile.am: Remove AUTOMAKE_OPTIONS.
* base_sp/Makefile.am: Remove AUTOMAKE_OPTIONS.
* cdtest/Makefile.am: Remove AUTOMAKE_OPTIONS.
* hello/Makefile.am: Remove AUTOMAKE_OPTIONS.
* minimum/Makefile.am: Remove AUTOMAKE_OPTIONS.
* paranoia/Makefile.am: Remove AUTOMAKE_OPTIONS.
* ticker/Makefile.am: Remove AUTOMAKE_OPTIONS.
* unlimited/Makefile.am: Remove AUTOMAKE_OPTIONS.
* configure.in: Remove.
