CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
call to printk.
Updates #3170.
This makes the new Termios devices independent of device major/minor
numbers. It enables BSP independent Termios device drivers which may
reside in the cpukit domain. These drivers require an IMFS and do not
work with the device file system. However, the device file system
should go away in the future.
Remove miniIMFS. Statically initialize the root IMFS.
Add configuration options to disable individual
features of the root IMFS, e.g.
o CONFIGURE_IMFS_DISABLE_CHOWN,
o CONFIGURE_IMFS_DISABLE_FCHMOD,
o CONFIGURE_IMFS_DISABLE_LINK,
o CONFIGURE_IMFS_DISABLE_MKNOD,
o CONFIGURE_IMFS_DISABLE_MOUNT,
o CONFIGURE_IMFS_DISABLE_READLINK,
o CONFIGURE_IMFS_DISABLE_RENAME,
o CONFIGURE_IMFS_DISABLE_RMNOD,
o CONFIGURE_IMFS_DISABLE_SYMLINK,
o CONFIGURE_IMFS_DISABLE_UNMOUNT, and
o CONFIGURE_IMFS_DISABLE_UTIME.
This reduces the average node size.
Add and use IMFS_GENERIC_INITIALIZER().
ftruncate() and open() with O_TRUNC shall upon successful completion
mark for update the st_ctime and st_mtime fields of the file.
truncate() shall upon successful completion, if the file size is
changed, mark for update the st_ctime and st_mtime fields of the file.
The POSIX standard "The Open Group Base Specifications Issue 7", IEEE
Std 1003.1, 2013 Edition says nothing about the behaviour of truncate()
if the file size remains unchanged.
Future directions of the standard may mandate the behaviour specified in
ftruncate():
http://austingroupbugs.net/view.php?id=489
for details.
o A new data structure rtems_filesystem_global_location_t was
introduced to be used for
o the mount point location in the mount table entry,
o the file system root location in the mount table entry,
o the root directory location in the user environment, and
o the current directory location in the user environment.
During the path evaluation global start locations are obtained to
ensure that the current file system instance will be not unmounted in
the meantime.
o The user environment uses now reference counting and is protected
from concurrent access.
o The path evaluation process was completely rewritten and simplified.
The IMFS, RFS, NFS, and DOSFS use now a generic path evaluation
method. Recursive calls in the path evaluation have been replaced
with iteration to avoid stack overflows. Only the evaluation of
symbolic links is recursive. No dynamic memory allocations and
intermediate buffers are used in the high level path evaluation. No
global locks are held during the file system instance specific path
evaluation process.
o Recursive symbolic link evaluation is now limited by
RTEMS_FILESYSTEM_SYMLOOP_MAX. Applications can retrieve this value
via sysconf().
o The device file system (devFS) uses now no global variables and
allocation from the workspace. Node names are allocated from the
heap.
o The upper layer lseek() performs now some parameter checks.
o The upper layer ftruncate() performs now some parameter checks.
o unmask() is now restricted to the RWX flags and protected from
concurrent access.
o The fchmod_h and rmnod_h file system node handlers are now a file
system operation.
o The unlink_h operation has been removed. All nodes are now destroyed
with the rmnod_h operation.
o New lock_h, unlock_h, clonenod_h, and are_nodes_equal_h file system
operations.
o The path evaluation and file system operations are now protected by
per file system instance lock and unlock operations.
o Fix and test file descriptor duplicate in fcntl().
o New test fstests/fsnofs01.
PR 1589/build
psx13/Makefile.am, psx14/Makefile.am, psx15/Makefile.am,
psx16/Makefile.am, psxaio01/Makefile.am, psxaio02/Makefile.am,
psxaio03/Makefile.am, psxalarm01/Makefile.am,
psxautoinit01/Makefile.am, psxautoinit02/Makefile.am,
psxbarrier01/Makefile.am, psxcancel/Makefile.am,
psxcancel01/Makefile.am, psxchroot01/Makefile.am,
psxclassic01/Makefile.am, psxcleanup/Makefile.am,
psxcleanup01/Makefile.am, psxclock/Makefile.am,
psxcond01/Makefile.am, psxeintr_join/Makefile.am,
psxenosys/Makefile.am, psxfatal01/Makefile.am,
psxfatal02/Makefile.am, psxfchx01/Makefile.am, psxfile01/Makefile.am,
psxfile02/Makefile.am, psxfilelock01/Makefile.am,
psxgetrusage01/Makefile.am, psxid01/Makefile.am,
psximfs01/Makefile.am, psximfs02/Makefile.am,
psxintrcritical01/Makefile.am, psxitimer/Makefile.am,
psxkey01/Makefile.am, psxkey02/Makefile.am, psxkey03/Makefile.am,
psxmount/Makefile.am, psxmsgq01/Makefile.am, psxmsgq02/Makefile.am,
psxmsgq03/Makefile.am, psxmsgq04/Makefile.am,
psxmutexattr01/Makefile.am, psxobj01/Makefile.am,
psxpasswd01/Makefile.am, psxpasswd02/Makefile.am,
psxpipe01/Makefile.am, psxrdwrv/Makefile.am, psxreaddir/Makefile.am,
psxrwlock01/Makefile.am, psxsem01/Makefile.am,
psxsignal01/Makefile.am, psxsignal02/Makefile.am,
psxsignal03/Makefile.am, psxsignal04/Makefile.am,
psxsignal05/Makefile.am, psxsignal06/Makefile.am,
psxspin01/Makefile.am, psxspin02/Makefile.am, psxstack01/Makefile.am,
psxstack02/Makefile.am, psxstat/Makefile.am, psxsysconf/Makefile.am,
psxtime/Makefile.am, psxtimer01/Makefile.am, psxtimer02/Makefile.am,
psxtimes01/Makefile.am, psxualarm/Makefile.am, psxusleep/Makefile.am:
Remove obsolete optional manager capability.
* psxfile01/test.c: Remove local redeclaration of IMFS_dump.
* configure.ac: Check for size of mode_t.
* psxfile01/test.c, psxstat/test.c: Include "primode.h".
Use PRIomode_t to print mode_t.
PR 1839/filesystem
* psxfchx01/init.c, psxfchx01/psxfchx01.scn, psxfile01/psxfile01.scn,
psxfile01/test.c: Update test to reflect new status codes.
* psxfile01/test.c, psxmsgq01/init.c, psxreaddir/test.c: Fix tests
broken in warning pass.
* psx04/task3.c, psxfile01/test.c, psxhdrs/Makefile.am,
psxmsgq01/init.c, psxreaddir/test.c, psxsignal01/init.c,
psxtimes01/init.c, psxualarm/init.c: Remove warnings.
PR 1654/testing
* psx13/test.c, psx13/psx13.scn: Test case to improve testing of
dup2 routine.
* psxfile01/test.c, psxfile01/psxfile01.scn: New test to improve
testing of fcntl routine.
* psximfs01/init.c, psximfs01/psximfs01.scn: Improve testing of
imfs routines.
* psximfs02/init.c, psximfs02/psximfs02.scn: Improve coverage of
imfs routines.
* psxpasswd02/init.c, psxpasswd02/psxpasswd02.scn: New tests to
improve coverage of getpwent.c.
PR 1623/testing
* psx13/test.c, psx13/psx13.scn: New cases to improve coverage of
utime() and fpathconf().
* psxfile01/test.c, psxfile01/psxfile01.scn: New cases to improve
coverage of rmdir(), unlink(), mknod(), link(), open(), read(),
write().
* psxstat/test.c, psxstat/psxstat.scn: New case to improve
coverage of readlink().
* psxfile01/test.c: Avoid NULL pointer access.
PR 1617/testing
* psxfile01/test.c, psxfile01/psxfile01.scn: Added new cases to
exercise_link_r and _unlink_r
* psxstat/test.c, psxstat/psxstat.scn: Added new cases to exercise
_lstat_r and _stat_r.
* psxtime/test.c, psxtime/psxtime.scn: Added new cases to exercise
_gettimeofday.
PR 1608/testing
* psxfile01/init.c: Add a simple test case: Open file as read-only
and attemp to truncate. Improves coverage.
* psxfile01/test_cat.c: Does not need posix specific macros.
* psxfile01/Makefile.am, psxfile01/psxfile01.scn, psxfile01/test.c:
Remove tests which put NULL entries in file handlers.
psx13/Makefile.am, psx14/Makefile.am, psxalarm01/Makefile.am,
psxcleanup/Makefile.am, psxcleanup01/Makefile.am,
psxclock/Makefile.am, psxcond01/Makefile.am, psxenosys/Makefile.am,
psxfatal01/Makefile.am, psxfatal02/Makefile.am,
psxfile01/Makefile.am, psxintrcritical01/Makefile.am,
psxitimer/Makefile.am, psxkey01/Makefile.am, psxkey02/Makefile.am,
psxkey03/Makefile.am, psxmount/Makefile.am, psxmsgq01/Makefile.am,
psxmsgq02/Makefile.am, psxmsgq03/Makefile.am, psxmsgq04/Makefile.am,
psxpasswd01/Makefile.am, psxrdwrv/Makefile.am,
psxreaddir/Makefile.am, psxrwlock01/Makefile.am,
psxsem01/Makefile.am, psxsignal01/Makefile.am,
psxsignal02/Makefile.am, psxsignal03/Makefile.am,
psxsignal04/Makefile.am, psxsignal05/Makefile.am,
psxstat/Makefile.am, psxsysconf/Makefile.am, psxtime/Makefile.am,
psxualarm/Makefile.am, psxusleep/Makefile.am: Revert accidentally
committed patch.
* Makefile.am, configure.ac, psx01/Makefile.am, psx02/Makefile.am,
psx03/Makefile.am, psx04/Makefile.am, psx05/Makefile.am,
psx06/Makefile.am, psx07/Makefile.am, psx08/Makefile.am,
psx09/Makefile.am, psx10/Makefile.am, psx11/Makefile.am,
psx12/Makefile.am, psx13/Makefile.am, psx14/Makefile.am,
psxalarm01/Makefile.am, psxautoinit01/Makefile.am,
psxautoinit02/Makefile.am, psxbarrier01/Makefile.am,
psxcancel/Makefile.am, psxcancel01/Makefile.am,
psxchroot01/Makefile.am, psxcleanup/Makefile.am,
psxcond01/Makefile.am, psxenosys/Makefile.am, psxfatal01/Makefile.am,
psxfatal02/Makefile.am, psxfile01/Makefile.am, psxfile02/init.c,
psxfile02/psxfile02.doc, psxfile02/psxfile02.scn,
psxualarm/Makefile.am, psxusleep/Makefile.am: Add test for fd greater
than number of file descriptors configured.
* psxfile01/test.c: Update for IMFS API changes.
* psxfile01/test.c, psxmount/test.c, psxreaddir/test.c,
psxstat/test.c: Update to the new mount API.
* psxfile01/test.c, psxfile01/psxfile01.scn: This file now
exercises the _rename_r in libcsupport. For now, it also
provides two fsmount_me_h handlers to enable certain error
checking paths
* psxfile01/test.c: Add check for errno on chdir(NULL).
* include/pmacros.h, psx01/task.c, psx02/init.c, psx02/task.c,
psx03/init.c, psx03/task.c, psx04/init.c, psx04/task1.c,
psx04/task2.c, psx04/task3.c, psx05/init.c, psx05/task.c,
psx05/task2.c, psx05/task3.c, psx06/init.c, psx06/task.c,
psx06/task2.c, psx07/init.c, psx08/init.c, psx08/task2.c,
psx08/task3.c, psx09/init.c, psx10/init.c, psx10/task.c,
psx10/task2.c, psx10/task3.c, psx11/init.c, psx11/task.c,
psx12/init.c, psxalarm01/init.c, psxbarrier01/test.c,
psxcancel01/init.c, psxchroot01/test.c, psxclock/init.c,
psxfile01/test.c, psxfile01/test_cat.c, psxfile01/test_extend.c,
psxfile01/test_write.c, psxitimer/init.c, psxkey01/task.c,
psxkey02/init.c, psxkey03/init.c, psxmount/test.c, psxmsgq01/init.c,
psxmsgq03/init.c, psxmsgq04/init.c, psxreaddir/test.c,
psxrwlock01/test.c, psxsem01/init.c, psxsignal01/init.c,
psxsignal01/task1.c, psxsignal02/init.c, psxsignal03/init.c,
psxsignal05/init.c, psxspin01/test.c, psxspin02/test.c,
psxstack01/init.c, psxstat/test.c, psxtime/test.c, psxualarm/init.c:
Use rtems_test_assert() consistently instead of system assert().
rtems_test_assert() is designed to integrate into the RTEMS test
suite infrastructure.
* psxfile01/test.c: Remove obsure #ifdef's.
Apply PRI* macros to print struct stat fields.
* psxfile01/test.c, psxstat/test.c, psxtime/test.c: Eliminate test
routines TICKS_PER_SECOND and get_ticks_per_second() in favor of new
rtems_clock_get_ticks_per_second().
* psxfile01/test.c: Change from int to size_t.
* psxfile01/test.c: truncate on /dev/console now works.
* include/pmacros.h, psx01/init.c, psx01/system.h, psx13/main.c,
psxbarrier01/main.c, psxchroot01/main.c, psxfatal_support/init.c,
psxfile01/main.c, psxfile01/test.c, psxmount/main.c, psxrdwrv/main.c,
psxreaddir/main.c, psxrwlock01/main.c, psxspin01/main.c,
psxstat/main.c, psxtime/main.c: Change TEST_INIT to CONFIGURE_INIT.
Make tmacros.h available to all POSIX tests. Add a clock_settime case
for < 1988.
