* | Files only used by psxfile01, so moved there. | Joel Sherrill | 1999-11-23 | 4 | -1/+201 |
* | Patch rtems-rc-19991117-14.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1999-11-23 | 1 | -0/+42 |
| | | | | to convert the psxtests directory from Makefile.in to Makefile.am. | ||||
* | Updated copyright notice. | Joel Sherrill | 1999-11-17 | 2 | -4/+2 |
* | Minor fixes to make screen match a bit better. | Joel Sherrill | 1999-11-02 | 2 | -11/+15 |
* | Modified to ease comparison of screen to target output. | Joel Sherrill | 1999-10-25 | 2 | -111/+111 |
* | Added prints for calls into the file system. Added O_EXCL for an open that | Jennifer Averett | 1999-03-31 | 1 | -5/+28 |
| | | | | tested that the same file could not be created twice. | ||||
* | Modified file to match output. | Jennifer Averett | 1999-03-31 | 1 | -11/+38 |
* | Cleaned up test. | Jennifer Averett | 1998-12-03 | 2 | -168/+169 |
| | | | | Updated scn files to match present expected test output. | ||||
* | Added tests in support of the file system infrastructure. | Joel Sherrill | 1998-11-23 | 3 | -0/+683 |
