Update #3170.
Update #3199.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
call to printk.
Updates #3170.
With global stdio streams, a freopen() would close the global stream
object.
Update #3012.
This reduces the average node size.
Add and use IMFS_GENERIC_INITIALIZER().
